Anybody listened to Crown Drivecore xls 2000 and 2500 amps for 2 channel main speaker listening,versus a so called high end home amp. - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 12-15-2015, 10:47 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
[quote=red71rum;39763674]
Originally Posted by lovinthehd View Post
Well I don't believe that I can change the preout voltage level of my avr, it is fixed. Now on say a Onkyo M282 that I have connected, it has a sensitivity control on that and it is set to max.
You could use a bump box like an ART Clean Box, some do with low pre-out levels. How big a difference is/was it between the Crown at full gain vs the M282?
red71rum likes this.
lovinthehd is offline
Old 12-15-2015, 10:58 AM
red71rum's Avatar
Quoted: 56 Post(s)
[quote=lovinthehd;39765298]
I wish had known about the ART Clean Box at the time. Well I listen it was pretty big, although I got the M282 long after. I do remember having to crank the volume to something which normally would be uncomfortable with the reguar avr amp, I think -18 for just regular tv viewing. With the M282 I have the master volume at -33. I also added an AudioSource Amp 3 for my 4ohm AR 312HO's and that worked great also. I think the Art Clean box would have resolved the problem, but my wife would have not liked the added expenditure. She does not understand why I upgrade these things and is happy with the lame soundbar downstairs: )
Xbox LIVE gamertag: red71rum
red71rum is offline
Old 12-15-2015, 11:10 AM
lovinthehd's Avatar
Liked: 4775
[quote=red71rum;39765666]
Your master volume control should read the same at the same spls if you calibrate your gear....did you re-run MCACC when you added the external amps?
Old 12-15-2015, 01:47 PM
red71rum's Avatar
Quoted: 56 Post(s)
[quote=lovinthehd;39765954]
Yes, I read that you should always recal when adding a new amp.
red71rum is offline
Old 12-15-2015, 08:07 PM
ssmokeyy's Avatar
Quoted: 56 Post(s)
I was wondering two things How is the sq of these amps for klipsch towers and What would u do if u only needed one channel to drive a center channel but want the same power range as the front towers amp?
ssmokeyy is offline
Old 12-16-2015, 03:51 AM
Quoted: 189 Post(s)
Liked: 31
Not sure about SQ as i believe all amps sound the same but what i think you'll be more worried about is the hiss. Depending on how sensitive your Klipsch towers are the hiss might be more pronounced (> 93db). I have 90db sensitive towers running with XLS 1500 and i don't hear the hiss unless i am standing in front of the speakers with my ear to the tweeter.
Unfortunately you'll have to use only one channel from the amp unless you want to bi-wire/bi- amp your center channel (assuming your speakers can be bi-amped or you believe that bi-amping/biwiring makes a difference). Alternatively you can get a 3 channel amp for your LCR and you wouldn't have to worry about the hiss but they are way more expensive than pro amps.
Living Room: Pre-Pro- Marantz AV7702, Amps- Crown X1500 & XLS1000(5). Mains- RTi12, Center- CSi5, SR- RTiA1, SRB-RTi8, Atmos- 620RT(4), Sub- RBH I-12 & BIC F12, TV-LG55LB7200, PJ-Benq HT1075, Screen 106", UBD- Samsung K8500, Bluray-LGBP440, Misc- Nvidia Shield, Apple TV, Chromecast, DSTV HD PVR, Wii U, DVP-5000s.
Bedroom:AVR- Marantz SR5009, Mains-75T, TV-VIZIO E500i-B1, Bluray-iVid BD780, Misc- Fire TV, Chromecast Audio, Sennheiser RS170, DSTV HD, QNAP TS-451+.
shyyour is offline
Old 12-16-2015, 07:20 PM
ssmokeyy's Avatar
Quoted: 56 Post(s)
These towers are very sensitive at 97dB @ 2.83V / 1m and my room size is real small. I sit around 4 feet from the towers maxx laying back I'm about 6 feet. Is there any other amps about this price range that work good and don't have a hiss? The normal onkyo and denon amps seem way over priced for what you're getting..
ssmokeyy is offline
Old 12-16-2015, 07:36 PM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
I love the idea of the XLS amps and their watts/power/weight/heat ratio, but has anyone used them on very high sensitivity pro speakers (~100-103db) like the JBL 3677/3722/4722 or Klipsch 310/325/904? Hearing reports of hiss on even moderate-high sensitivity speakers makes me a little nervous. Any experiences from this group?
Davecraze is online now
Old 12-17-2015, 09:01 AM
lovinthehd's Avatar
Liked: 4775
Did you read this thread?
Old 12-17-2015, 10:28 AM
uniquepattern's Avatar
Quoted: 620 Post(s)
Liked: 567
Dont mean to thread jack, but this sorta fits....
Anyone know if there is an undefeatable HPF on the new XLS models?
XLS2502 to be specific?
uniquepattern is offline
Old 01-18-2016, 12:52 PM
gentlejax's Avatar
Quoted: 30 Post(s)
I am awaiting delivery of a ART CLEAN BOX today. Wont be able to hook up till I get some XLR cables.
I have 2 amps so what I need to know if if I can split the XLR out from the box into 4 cables so I dont have to have 2 ART boxes ?
gentlejax is offline
Old 01-18-2016, 01:01 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Yes.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Polk Audio Speakers Rti 12
