Can't get video to my TV through Denon 2313ci...Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-02-2013, 03:49 PM - Thread Starter
norskybh8's Avatar
Hi there,
Brand new install here and I'm getting very frustrated. I cannot get video out to my TV from either my DTV DVR or my PS3 through my receiver. I can get sound through both, but no video to my Panny U50. Please help.
norskybh8 is offline
post #2 of 8 Old 03-02-2013, 04:17 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How are these devices connected to your receiver?
Does the Denon On Screen display work?
Afro GT
afrogt is offline
post #3 of 8 Old 03-02-2013, 04:29 PM - Thread Starter
norskybh8's Avatar
The DTV and PS3 are connected through HDMI cables to the Denon 2313 and then an HDMI from the AVR (monitor 1) to my TV. I don't get the on screen start up guide. Can't figure out what is going on. I changed "HDMI Control" to ON and "Control Monitor" to Monitor 1 through the GUI.
post #4 of 8 Old 03-02-2013, 04:47 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
On the PS3 try setting the "Deep Color Output" setting to OFF and for the DTV box, connect the HDMI directly to the TV with optical from the DTV box to the AVR.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread#user_L11
jdsmoothie is online now
post #5 of 8 Old 03-02-2013, 04:55 PM
afrogt's Avatar
Liked: 755
If you get the GUI then the Denon On screen display does work! You can go thru the setup assistant by pressing the setup button on the remote and then selecting Setup Assistant from the menu choices.
You dont' need HDMI control to be on.
What resolution is your DirecTV DVR set to? You may have to plug it in directly to the TV to change the settings.
Afro GT
afrogt is offline
post #6 of 8 Old 03-02-2013, 04:58 PM
dta721's Avatar
Not sure if this helps, but wonder if you need to select the source on your Panny U50 (remote) to that of the AVR, then even recycle the AVR power if it does not work the 1st time?
dta721 is offline
post #7 of 8 Old 06-22-2013, 08:05 AM
dhectorg's Avatar
I purchased a refubished AVR-2313 and had this same issue, although I couldn't even get the setup menu on screen. After a couple calls to Denon support, I decided to return it for a replacement, which I have yet to receive. This is my 1st true home theater receiver, so if anyone can point me in the direction of other AVR-2313 'help' discussions, I'd greatly appreciate it. On a side note, I'm not pleased with Denon's return service. It's been 2 weeks with my awesome projector setup that I haven't been able to use because of this receiver debacle.
Any thread suggestions are greatly appreciated!
Don
dhectorg is offline
post #8 of 8 Old 06-22-2013, 12:13 PM
jdsmoothie's Avatar
Liked: 5502
Refer to posts 1-6 in the "2012 Denon AVR-XX13 Models" thread linked in my sig and post in that thread with any additional questions.
Denon Avr 2313ci Receiver
