how to achieve true surround? connecting question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2013, 05:32 PM - Thread Starter
steve kha's Avatar
Television: Samsung UN55B8000 LED
Receiver: SAony STR-K740P with stock 5 speakers and sub
DVD: Panasonic DMP-BDT220P
i have no cable box and this set up is for watching dvd s only.
tv to bl player connection is hdmi. bl player sound connection is regular component cables, red and white and a separate video component wire. from what i have been reading to achieve 5.1 i also have to connect an optical cable from bl player to the receiver. is this correct? do i leave component and video cables in place? if it helps, if you familiar with receiver, on its display there are icons for every speaker that are lit up, but two of my surround speakers are not , leading me to believe im not getting true surround. any input will be appreciated
steve kha is offline
post #2 of 3 Old 03-02-2013, 06:03 PM - Thread Starter
steve kha's Avatar
post #3 of 3 Old 03-02-2013, 06:51 PM
afrogt's Avatar
Quoted: 1063 Post(s)
Liked: 769
If the Blu Ray player is connected directly to the TV why do you have std audio/video cables connected to the receiver at all?
You'll need to connect an optical cable from Panasonic player to your receiver for audio. that way you'll get 5.1 surround. You'll also have to change the settings for the audio output. Its in the Panasonic manual.
If you don't have an optical cable, get one here.
http://www.amazon.com/Premium-Optical-Receiver-Cablebox-Feet-2Meter/dp/B0027ZGN2A/ref=sr_1_5?ie=UTF8&qid=1362275517&sr=8-5&keywords=optical+cable
Take off the clear plastic cap before trying to plug into the optical port.
Afro GT
afrogt is offline
