volume control gets lower when receiver is turned off and back on fisher 2 channel receiver need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-02-2013, 06:59 PM - Thread Starter
keyboardcat's Avatar
Do some receivers do this? I mean is it normal? i got it used a few months ago so I wasn't sure. None of my other receivers do it though. please someone help me figure out what this means. I will have it loud when it's on but when it turns back on much lower volume then where I started at.
keyboardcat is offline
post #2 of 15 Old 03-02-2013, 07:03 PM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1910
It probably has a minimum volume setting. That is so that if you have it very loud when you turn it off it wont come back on and damage the speakers or make you crap yourself. smile.gif What kind of receiver do you have?
Licence to Kill
Bond 007 is online now
post #3 of 15 Old 03-02-2013, 07:24 PM - Thread Starter
I like the tiger on your profile. it is rs 717 studio standard. Since it has been doing that right now I have pioneer speakers hooked up to vc rx 250 playing through the computer using shoutcast.com
post #4 of 15 Old 03-02-2013, 07:29 PM
Bond 007's Avatar
Liked: 1910
Thanks about the tiger. Does the avr come on at the same volume each time?
Licence to Kill
post #5 of 15 Old 03-02-2013, 07:39 PM - Thread Starter
yes it does so some receivers just do that then?
post #6 of 15 Old 03-02-2013, 07:40 PM - Thread Starter
since you like tigers you should go to cincinatti zoo and see the famous cheetah run. I tried to go to it, but missed it by about two or three hours. the zoo was still fun though.
post #7 of 15 Old 03-02-2013, 07:40 PM
Bond 007's Avatar
Liked: 1910
Yes. If you read the manual I bet you can set that volume to be whatever you want. It will be a minimum volume setting of some type.
Licence to Kill
post #8 of 15 Old 03-02-2013, 07:43 PM - Thread Starter
ok thanks. I wish I had the manual lol. I got it from goodwill for 13 dollars.
post #9 of 15 Old 03-02-2013, 07:48 PM
Bond 007's Avatar
Liked: 1910
You can probably find it on the internet.
Licence to Kill
post #10 of 15 Old 03-02-2013, 07:55 PM
Bond 007's Avatar
Liked: 1910
I just made a quick search and couldnt find it except one for sale. Just go into the settings and see what you can find.
Licence to Kill
post #11 of 15 Old 03-02-2013, 07:57 PM - Thread Starter
would you use jbl speakers and sansui with a rotel power amp or a heath pre amp and heath power amp. I have both brand speakers. I don't know which amps would sound better with the speakers.
post #12 of 15 Old 03-02-2013, 08:01 PM
Bond 007's Avatar
Liked: 1910
I have no clue but most amps sound the same. Most of the experts here will tell you that an external amp will not improve sound quality in most cases. Use the best speakers.
Licence to Kill
post #13 of 15 Old 03-02-2013, 08:24 PM - Thread Starter
just curious what amps do you use bond?
post #14 of 15 Old 03-02-2013, 09:09 PM
Bond 007's Avatar
Liked: 1910
Only the one in my Yamaha RX-V671 surround receiver.
Licence to Kill
post #15 of 15 Old 03-02-2013, 09:42 PM - Thread Starter
I have a older yamaha surround receiver also with a problem. it sounds fine on cd players, but the sound cuts out when hooked up to my hp all in one pc in the livingroom. I haven't used the yamaha in a few months. the nad ended up going in the livingroom instead. I wonder what is making the sound cut on when I hook the 3.5mm cable with the red and white cables on it. the nad has no problem playing sound through the headphone port. the yamaha will work fine with iphone hooked up to it using the 3.5mm plug but won't on the pc.
