Yamaha RX-V673 vs Onkyo TX-SR705 - AVS Forum | Home Theater Discussions And Reviews
Old 03-03-2013, 12:11 AM - Thread Starter
Braehole's Avatar
The Yamaha RX-V673 says 7.2-Channel Powerful Surround Sound with 105W per Channel but Output Wattage: 90 Watts. I don't get it... Will I be able to tell a difference between the Yamaha RX-V673 if I up grade from the Onkyo TX-SR705? The Onkyo puts out 100W and the Yamaha only does 90W (or 105W) per speaker. I like all the extra HDMI ports,up scaling and Air play but I'm worried about the 10W lower per speaker. Any input would really help me hit the buy button! OR should I be spending my 600 bucks on a different reciever? Thanks !
I'm running MonoPrice speakers, 3 front 7604 6-1/2 Inches Dual Woofer- Micro Flange In-Wall Speakers and 4 7605 6-1/2 Inches Dual Woofer- Micro Flange In-Ceiling Speakers.
Braehole is offline
Old 03-03-2013, 08:08 AM
JBWIII's Avatar
Liked: 42
Even assuming that those numbers are measured and represented in the same way, the answer is no, you will not be able to tell the difference.
JBWIII is offline
Old 03-03-2013, 12:10 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you're paying $600 for that receiver then you're paying $200 too much. It was just on sale for $399 3 days ago. Now that the RX-Vx75 models have been announced look for discounts on the x73 models.
By the way you wont notice the difference between 90 and 100 watts.
Afro GT
afrogt is offline
Old 03-03-2013, 12:14 PM
afrogt is offline
Old 03-03-2013, 11:26 PM - Thread Starter
Braehole's Avatar
So go with the Harman Kardon AVR 3650 for 714 bucks smile.gif The Denon AVR-1913 looks good and I can always get an amp if I want more power I guess. I dont need the 2k or 4k for a couple more years
Braehole is offline
Old 03-03-2013, 11:47 PM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
+1
Do the Denons have any DSP Modes like the Yamaha? Hall in Munich, Chamber, Cellar Club, Sports, Sci-Fi, etc.
Licence to Kill
Bond 007 is offline
Old 03-04-2013, 12:40 AM
afrogt's Avatar
Liked: 755
you can't add an amp to the Denon 1913, it doesn't have any preamp outputs!
Afro GT
afrogt is offline
Old 03-04-2013, 12:59 AM - Thread Starter
Braehole's Avatar
O... Ok well I have 20 foot ceilings so I'm afraid to lose power. I would go with the Pioneer SC-1222-K for 550 but its to tall fit under my TV. Its 6 inches taller then the Onkyo... Guess I can just change the whole set up.
Braehole is offline
Yamaha Rx V673 Receiver , Onkyo Tx Sr705 Receiver
