AVR Denon 983 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-03-2013, 05:47 PM - Thread Starter
JJkizak's Avatar
Quoted: 107 Post(s)
The battery went low and I had to reset the receiver. Now in the PLCII Cine position playing stereo DVD's the Left/Right front speakers are very low and the center channel is normal. Before the battery went low the left/front speakers would knock the house down. The 7.1 positon works just dandy. Of course this is after I reset all the menu stuff after resetting the AVR. Is this thing junk now?
JJK
JJkizak is offline
post #2 of 7 Old 03-04-2013, 11:49 AM
Alan P's Avatar
Quoted: 4696 Post(s)
Liked: 3322
I would guess that since you had to reset the receiver, all of your setting went *poof*.
You're gonna have to go through the set up procedure again - speaker size, distance, levels, etc.
Alan P is offline
post #3 of 7 Old 03-06-2013, 04:23 PM - Thread Starter
JJkizak's Avatar
Quoted: 107 Post(s)
I went through it all again and it seemed to be better but not like it once was. How many times must I go through this resetting and re-doing the menus?
Can the battery be replaced and where is it located?
JJK
JJkizak is offline
post #4 of 7 Old 03-06-2013, 05:33 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
What battery are you referring to?
jdsmoothie is offline
post #5 of 7 Old 03-07-2013, 08:24 AM - Thread Starter
JJkizak's Avatar
Quoted: 107 Post(s)
The battery that runs the bios of the computer section of the receiver. The words "battery low" popped up on the screen the first time I reset it.
JJK
JJkizak is offline
post #6 of 7 Old 03-07-2013, 05:18 PM
jdsmoothie's Avatar
Liked: 5502
Pop the top and look around as it may be easy to locate and replace.
post #7 of 7 Old 03-21-2013, 03:51 PM - Thread Starter
JJkizak's Avatar
Quoted: 107 Post(s)
I poped the top off and looked all around with a 5" magnifier and found a slug of fuses (all good) and the digital board but
could not find a battery, flat, round, square, cylindrical, or otherwise.
JJK
JJkizak is offline
