Pandora issue - AVS Forum | Home Theater Discussions And Reviews
Old 03-03-2013, 06:22 PM - Thread Starter
barry313's Avatar
I mainly use my receiver for listening to music outdoors 90 % on Pandora .The music will start to fade in or out then I change the channel and sometimes that will fix it sometimes not .Nothing else that is web based fades just Pandora .Any one else have that issue or maybe a suggestion for a fix ?
Barry
barry313 is offline
Old 03-03-2013, 07:43 PM
thebard's Avatar
Quoted: 86 Post(s)
Liked: 50
What equipment are you listening on? Is the Pandora on your receiver itself or from another source?
Projectors: Where there's a wall, there's a way.
http://www.avsforum.com/forum/110-di...een-build.html
thebard is offline
Old 03-03-2013, 08:07 PM
newtohometheate's Avatar
I had a similar problem with pandora when streaming it through my ps3; I tried it with xbox 360 and it worked without a hitch. I think the xbox has a better internet browser.
newtohometheate is offline
Old 03-30-2013, 01:19 PM - Thread Starter
barry313's Avatar
On my iphone I turn the receiver on and select pandora .Then when it starts to fade I will select internet radio ....no fade
barry313 is offline
Old 03-30-2013, 01:20 PM - Thread Starter
barry313's Avatar
Im sorry yes its on the receiver
barry313 is offline
