what audio format - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-03-2013, 07:02 PM - Thread Starter
bob2194's Avatar
I live in a small town in Oklahoma. One of the channels does not broadcast in dolby digital. What is the perfered audio format when you can't get dolby digital. I was using direct but the I read that direct does not use bass management, and sets front speakers to full. So what would you use?
Is there a way to keep whatever I chose permanent. I have changed it, but it always goes back to direct. Will it when, I change channels go back to dolby digital if that is the format being used on that channel?
Thank you Bob
bob2194 is offline
post #2 of 2 Old 03-04-2013, 10:44 AM
Alan P's Avatar
Quoted: 5084 Post(s)
Liked: 3772
The answer is - depends on your receiver. Which one are you using?
Alan P is offline
