iPhone 5 docking station for older Analog Denon Amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-03-2013, 08:43 PM - Thread Starter
bweier's Avatar
Can anyone recommend a quality docking station for my iPhone 5 that I can use with my old Dennon analog amp to get the "best" quality reproduction from my iTunes library and for Pandora? RCA cables (r/l) are my only option on the back of the amp.
*EDIT My Dennon amp is DRA-835R
Thanks!!
bweier is offline
post #2 of 5 Old 03-03-2013, 09:47 PM
turboswede95's Avatar
http://www.pure.com/product/i-20-vl-61429/
and you'll need this to adapt the new iphone 5 usb to the old apple usb
http://www.tvc-mall.com/details/Apple-Lightning-to-30-pin-Adapter-Converter-for-iPhone-5-Black-MCH-446A/
not sure how well this will work without a preamp in the mix
turboswede95 is offline
post #3 of 5 Old 03-04-2013, 05:34 AM
bommai's Avatar
Quoted: 192 Post(s)
Liked: 48
I would say get an apple airport express and connect an analog cable to it and the receiver. Then use Airplay to send music to it. That way you can still hold on to your phone. If you want a digital connection get an outboard dac that can convert optical to analog.
bommai is offline
post #4 of 5 Old 03-04-2013, 06:45 AM - Thread Starter
bweier's Avatar
OK. So since the old Dennon amp has no digital processing capabilities, I need a DAC that converts the digital signal from my iPhone into an analog signal that the Dennon amp can process correct? If so, it seems like the Pure i-20 option gets me on the right track. From the Pure i-20 to the amp is just a set of rca cables correct?
bweier is offline
post #5 of 5 Old 03-04-2013, 07:25 AM - Thread Starter
bweier's Avatar
I just had a thought. I have an old Vista laptop that I could use for my iTune library and Pandora as well. The only way I could think to get this signal from the laptop to the amp would be from a single pin from the headphones jack to a "splitter" that switches to r/l RCA cables. It seems like the iPhone 5 as the source would be better sounding (assuming an external DAC that bypasses the iPhone internal) rather than jumping the audio from the headphone jack on my laptop.
Thoughts?
bweier is offline
