LSi9 amp or no amp?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-05-2013, 08:49 AM - Thread Starter
rocejize's Avatar
Hi guys, fairly new poster here.
So unless another option is presented I am bound and determined to buy some LSi9 for my PC setup. I only want 2.1 (even though i hear the LSi9 have suberb bass) for now and once i integrate a projector will want a 7.1/2 setup, so for the time being all i need is to power some LSi9.
I understand that the Polk LSi9 require much more power running at 200w 4ohm, which is hard to provide for on a receiver standpoint, but with an amp it is covered nicely. However when you add an amp into the mix (~$200+) then a receiver (~$400) and the LSi9 (~$450) you rack up quite a bill. I don't have a lot of money to work with and would be sitting on a MAX budget of ~$800.
Does anyone have any suggestions on how to drive these LSi9 or maybe a comparable bookshelf pair for 2.1 PC setup?
Thanks!!
-Ross
rocejize is offline
post #2 of 3 Old 03-05-2013, 09:11 AM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
Have you looked at the Paradigm Shift speakers? They are self powered and can be incorporated with your PC using a 3.5 MM plug. I own these and they are truly amazing speakers and should fit into your budget.
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #3 of 3 Old 03-05-2013, 10:08 AM
JHAz's Avatar
Quoted: 306 Post(s)
Liked: 271
I looked at the LSi9s on the Polk site. The recommended power is 20 to 200 watts. They're rated at 88 dB sensitivity. So 88 dB at one watt one mets. 20 watts would drive them to 101 dB at one watt, one meter. 40 would get them to 104 dB, almost the max for "reference>" In room SPL levels will differ some, but there's unlikely to be a need to have a 200 watt amp in a normal house sized room unless you routinely listen at very high levels at a significant distance from the speakers.
BTW, I'd take the 200 watt number to represent the max the speaker can take without heat-induced failure, and in general it's fair to assume that speakers are compressing (not getting as much louder as input voltage would call for) by half their max rated power, so if you NEED the volume 200 watts would provide, you also need different speakers to actually reproduce that full volume . . .
JHAz is offline
