Yamaha A3020 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-06-2013, 03:24 AM - Thread Starter
riverphoenix123's Avatar
When watching 3d with the glasses on, the writing in the amp's window display is slightly flickering constantly almost like a pulse, for example dts master. Is there a setting to adjust or is this a fault.
riverphoenix123 is offline
post #2 of 2 Old 03-06-2013, 03:15 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
I'm assuming you're using active shutter glasses...? There is no setting, nor is it a fault. Perfectly normal. Why are you staring at the AVR's display anyway, you should be looking at the pretty 3D images on your screen! biggrin.gifwink.gif
EDIT: Wait a sec, there is a setting that might help - FRONT DISPLAY 'OFF'. biggrin.gif
Alan P is offline
