Denon Amp 1312 + Wii - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-08-2013, 12:12 AM - Thread Starter
markboro19's Avatar
Hi All,
I recently bout a Denon Amp which works fine with all HDMIs connected through it. However, I also have a Wii which uses component (red, white and yellow). I can hear the sound but cannot get a picture when I plug the component cables into the back of the amp. My tv is a Samsung LED series 5.
Can anyone give me advice on how to get it work (in simplified terms) please!
Thanks in advance
markboro19 is offline
post #2 of 6 Old 03-08-2013, 12:34 AM
jdsmoothie's Avatar
Quoted: 12615 Post(s)
Liked: 5777
The 1312 does not feature analog --> HDMI video conversion (lowest model with this feature is the 1912) so you must either also connect a "composite" video (yellow) cable from the 1312 to the TV or purchase a Wii2HDMI.
Also note there is a dedicated thread for Denon AVR-XX12 Owners linked in my sig. For more information, refer to posts #3-6 in that thread.
jdsmoothie is offline
post #3 of 6 Old 03-08-2013, 12:40 AM - Thread Starter
markboro19's Avatar
Thanks for the reply. That's what I thought. However, I have connected an additional yellow cable from Monitor out (correct?!) to the tv and still nothing! Any ideas?
post #4 of 6 Old 03-08-2013, 12:48 AM
jdsmoothie's Avatar
Liked: 5777
If you are also using the HDMI jack with the same source name as used for the Wii (ie. DVD or SAT/CBL), then it is likely conflicting with the Wii video so unplug that HDMI cable and use another HDMI jack if available, otherwise purchase the Wii2HDMI.
post #5 of 6 Old 03-08-2013, 01:02 AM - Thread Starter
markboro19's Avatar
Thanks for the reply lads. It was plugged in through the v-aux. Think it could be a problem with the tv as when I plug the video component into the tv, it doesn't seem to be recognising it. Think the wii2hdmi is the only option.
Thanks again
post #6 of 6 Old 03-08-2013, 01:38 AM
jdsmoothie's Avatar
Liked: 5777
Right. If it doesn't work when the Wii is connected directly to the TV, then it's likely a setting on the Wii that is at issue. Get it to work connected to the TV and then it should work connected to the AVR.
