cant get tv audio with new denon 1312 receiver and LG Smart TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-08-2013, 10:24 PM - Thread Starter
tyso143's Avatar
Currently I have a new denon reciever connected via high speed hdmi and fibre optic cable to a new denon 1312 receiver and I cant get sound for the life of me. I have selected "External Speakers" on the TV input and the denon is factory default at the moment. Can anybody help?
tyso143 is offline
post #2 of 12 Old 03-08-2013, 10:51 PM
flyingvfreak's Avatar
why the Optical, remove it all you should need is the HDMI, if you want to use optical, then you need to switch the input that Optical is assigned too
flyingvfreak is offline
post #3 of 12 Old 03-09-2013, 12:07 AM - Thread Starter
tyso143's Avatar
ok - I have removed optical but this still does not give me the tv audio through the receiver
tyso143 is offline
post #4 of 12 Old 03-09-2013, 12:46 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Factory defaults probably aren't the right settings. Do your TV and receiver both support Audio Return Channel? If so, are you using an ARC capable port on the TV? Have you enabled HDMI CEC on both devices, which is necessary for ARC to work. Optical is generally easier to configure than ARC. What content are you trying to hear and what device is acquiring that content?
BIslander is offline
post #5 of 12 Old 03-09-2013, 02:41 AM - Thread Starter
tyso143's Avatar
Thanks for your help.
TV definitely supports ARC, im not sure about the Denon 1312 receiver. I am using the ARC port on the TV and I am using the Monitor out port on the receiver. I am trying to hear regular TV station audio through my surround sound. Any other device plugged into the receiver works perfectly on the surround sound (eg Apple TV). It seems like a setting issue on the Denon but my issue is I just cant find it.
tyso143 is offline
post #6 of 12 Old 03-09-2013, 03:12 AM - Thread Starter
tyso143's Avatar
ok so I just realised the Denon 1312 doesnt support ARC. So looks like I am back to the Optical cable from receiver to tv...
tyso143 is offline
post #7 of 12 Old 03-09-2013, 03:18 AM
jdsmoothie's Avatar
Quoted: 12085 Post(s)
Liked: 5502
Correct. The 1312 is a very basic model with no Setup Wizard, no ARC, no HDMI standby pass through, no HDMI Control, and no Audyssey. It also features a 3.5mm input on the front panel vice USB. If you review post #2 in the Denon AVR-XX12 Owner's thread linked in my sig, you'll note the 1612 is the lowest model we recommend which does have all of the features listed above.
jdsmoothie is online now
post #8 of 12 Old 03-09-2013, 06:20 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
How do you get your TV signal - by that I mean, is it through the TV tuner or from a set top box?
post #9 of 12 Old 03-09-2013, 04:26 PM - Thread Starter
tyso143's Avatar
It's from the TV tuner
tyso143 is offline
post #10 of 12 Old 03-09-2013, 06:09 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
So, run optical from the TV to the AVR, enable the TV's optical output (if needed), and select the correct input on the AVR. You should be good to go.
post #11 of 12 Old 03-09-2013, 08:16 PM - Thread Starter
tyso143's Avatar
Finally found the correct input on the receiver!!! Thanks for the help Bislander!!
tyso143 is offline
post #12 of 12 Old 03-09-2013, 08:31 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Sure thing. Glad you got it working.
Denon Avr 1312 Receiver
