Harmon Kardon AVR 110 humm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-11-2013, 06:52 AM - Thread Starter
johnjack11's Avatar
Good morning,
I am finishing up a basement remodel, and was able to get my tv, speakers, PC and receiver setup yesterday. The receiver is an old Harmon Kardon avr 110 from 2000.
When I turned it on, I noticed a slight hum on all the speakers. The hum does not really change much when I up the volume. It is not a huge deal when volume is up with music or a movie.
There are brand new outlets in the basement, and I tried with the receiver using a simple surge protector and without. Hum is same either way.
Not sure if it is noise from the house electric or not. I will see if I can borrow a line conditioner from someone at work.
The sound is really good from the old receiver, so I would hate to give up on it. Any ideas or suggestions? I build my own computers, and am not adverse to tinkering with the receiver itself with good instructions.
Is this receiver worth the effort to fix? As I said the sound does seem quite impressive, but I have nothing to really compare it to.
Thank you,
Jack
johnjack11 is offline
post #2 of 4 Old 03-11-2013, 11:33 AM - Thread Starter
johnjack11's Avatar
early afternoon bump for help.
post #3 of 4 Old 03-11-2013, 12:20 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
Do you have a cable box or satellite tuner connected??..
If YES disconnect its coax cable and see what happens?
M Code is offline
post #4 of 4 Old 03-11-2013, 01:51 PM - Thread Starter
johnjack11's Avatar
No cable, the pc has hdmi out to the tv, and optical to the receiver.
Thanks for the reply!
