XPA-1s for use with B&W 804s? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 03-11-2013, 05:10 PM - Thread Starter
win200's Avatar
I'm currently running an OPPO 105 directly into a Primare A30.5 via the multichannel outs. I'm looking to improve my amp stage from the Primare, and I was thinking of snagging three Emotiva XPA-1s to use for the L, C, and R channels, then using some stereo amp for the rears. Any thoughts? I've never used Emotiva, so I don't have much sense as to the quality. I'm listen 80% to movies, 20% to music--mostly jazz. Any thoughts or other suggestions appreciate. Thanks!
TV: LG OLED65B6P
Processor: Classe Sigma
Amp: Classe CAV-500
Player: OPPO UDP-203
Speakers: B&W 804s, B&W HTM3s
Sub: JL Audio F110
win200 is offline
post #2 of 19 Old 03-11-2013, 05:27 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
A friend of mine uses XPA-1's to power his 803Ds and center (the big B&W 800-series center, not sure the model #). Sounds good to me...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 19 Old 03-11-2013, 06:50 PM
Kilian.ca's Avatar
Liked: 37
Do you really need 500W RMS per channel for the 804S? Surely overkill with max. power rating 200W. My N803s are only driven by a meagre 175WPC.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #4 of 19 Old 03-11-2013, 06:55 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Have you got a 20 amp circuit to plug those monsters into?
David
crussader is offline
post #5 of 19 Old 03-16-2013, 05:32 PM - Thread Starter
win200's Avatar
Hmm. Not sure. I'm moving into a new home next month, and I'm starting to think about gear for the movie room. My guess, offhand, would be no.
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #6 of 19 Old 03-16-2013, 05:36 PM - Thread Starter
win200's Avatar
That's a good point. My Primare is 120wpc, and going up to 500 probably isn't necessary. Maybe three XPA-100s instead? Essentially, I'm trying to get an upgrade from my Primare A30.5, both in terms of power and sound quality, at a reasonable price. If you've got any ideas beyond Emotiva, I'd be grateful.
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #7 of 19 Old 03-16-2013, 05:46 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Outlaw 7500 is a killer deal and a very good amp.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #8 of 19 Old 03-16-2013, 06:30 PM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1445
If you are going to spend $1350 for three XPA-100s I would suggest the XPR-5 for $2k. That way you have a killer five channel one box amp with 400 wpc @ 8ohms. I personally would never have a need for anything over 200 wpc but some like the additional power.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #9 of 19 Old 03-16-2013, 06:57 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
A lot of new construction is wired with 12/2 Romex. Older construction post 1996 to 2008 will have a white sheath and post 2008 construction will use a yellow sheath. Lights are still wired using white 14/2. Receptacles will most-likely be 15 amp with a slot neutral slightly larger than the slot hot. A 20 amp receptacle will have a T-shaped neutral tilted at a 90° angle. It your wire is 12/2, you can change your 15 amp receptacles to 20 amp provided you also have 20 amp breakers installed. IF your house is to code and you had competent builders, a 20 amp breaker SHOULD also indicate 12/2 wiring even though the receptacles might only be 15 amp. They do this mainly for cost-savings.
You'll first need to determine if you have more than one circuit in the room. Again. If the electricians that built your house are worth their salt, they would have wired a living room with two circuits AND staggered the receptacles so that no two adjacent receptacles would be on the same circuit. My house was built by Mexicans, so the wiring was crap. I basically rewired my entire A/V room and dropped in an extra 100 amps ( 5 x 20 amps ) for good measure.
It is easy to calculate maximum load. It is -- Volts x Amps = Watts. Most of your gear will either list Volts and Amps or Wattage ( Volt/Amps.) Emotiva lists wattage on the back of their amps, so the XPR-5 is 1700 watts maximum, which would be 1700 watts / 115 volts = roughly 15 amps. This should be on its OWN 15 amp circuit and should not be over 12 amps continuous. Sunfire 7201 is 1440 watts, which is roughly 12 amps. I'd put the XPR-2 on its own 20 amp with maybe some other smaller stuff in the room and put the Sunfire on another 20 amp with the rest of your gear. Any subwoofers should also have their own circuit.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #10 of 19 Old 03-16-2013, 07:04 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Bill
Refurbished XPR-5's were $1300 at EmoFest. The regular sale price was $1600 at EmoFest.
jevans64 is offline
post #11 of 19 Old 03-16-2013, 08:10 PM - Thread Starter
win200's Avatar
Great, thanks for the tips! Any idea how the Emotiva / Outlaw gear would stack up against the SQ of stuff like Rotel / Primare / etc.? I just don't have much familiarity with the internet direct stuff. Price points are great, obviously, but I'm just hoping it stacks up sound-wise. Thanks!
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #12 of 19 Old 03-17-2013, 01:47 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
They stack up very well. I am listening to an Outlaw 7500. It is a fantastic, quiet, fully balanced amp.
I am going to order its big brother the 7900.
I found a different sound in the Sunfire 7400 and I prefer the Outlaw.
The outlaw maintains the distinct sound better a high volume levels.
After hearing this, I decided to stay with classic A/B since I think they are very linear.
I listened to some Outlaw M2200 200 WPC mono-blocks that sounded great.
They are A/B/G which rail change at about 70 watts. I have to say I was very impressed.
I am not sure you need that much amp, but I doubt any rarified amp is going to outperform those XPA-1 mono blocks.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
post #13 of 19 Old 03-17-2013, 02:31 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
I have the B&W Nautilus 804s, but use them as surrounds. Personally, I'm a bit apprehensive about the Emo amps, made in China and all. I'm not too enamored with their looks, so that's probably a good chunk of my bias.
I think the OP would be best served by either the Outlaw 7900, or ATI AT3007. I own the AT3007, and find the sound to be quite remarkable. And, it gives you more flexibility in for the future. And it takes up less space than 3 monoblocks. I used the AT3007 temporarily to power my B&W 802s, and was very impressed. It will no doubt be plenty of amp for an 804. Plus, Made in the USA biggrin.gif
Sam S is offline
post #14 of 19 Old 03-17-2013, 05:27 PM - Thread Starter
win200's Avatar
Thanks for all the great recommendations! I'll definitely give the Outlaw 77/7900 a look, as well as the ATI AT3007. I've also been glancing at the Parasound A31 for use with the mains and center (I've got a Rotel stereo amp mothballed that I could use for the rears). Any thoughts on the Parasound? Price point is right where I want it at $3k, and I've only heard raves about Parasounds amps.
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #15 of 19 Old 03-17-2013, 07:22 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
A31 is another great amp. A31 up front and an ATI AT2004 would make a great 7 channel setup.
jima4a is offline
post #16 of 19 Old 03-17-2013, 08:27 PM
Bill Mac's Avatar
Liked: 1445
I'm sure the A31 is a great amp but why not go with a one box solution such as the Outlaw or the ATI? I think one would be hard pressed to tell the differences between all of these amps. I honestly think the Outlaw and the ATI are the better choices. But I wonder if 300 watts is really needed. The A31 is $3k and an Outlaw 7500 is a little over half that at $1600. The two amps are close in power with A31 rated at 250 wpc and the 7500 at 200 wpc. But with the 7500 you get two additional channels at a much lower cost.
Bill
post #17 of 19 Old 03-17-2013, 08:42 PM - Thread Starter
win200's Avatar
Bill
Good point. I was just assuming that there was an estimable difference in SQ, given Parasound's reputation. And I don't care about the extra 50wpc. If they really are negligibly different, I'd rather save the money and invest it elsewhere... like in Fathom.
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #18 of 19 Old 03-17-2013, 09:02 PM
Bill Mac's Avatar
Liked: 1445
Parasound definitely has an excellent reputation. I had their A52 amp and 2100 preamp. Both were excellent components that comes with outstanding customer service from Parasound. It is only my opinion that the amps mentioned will sound very similar. Others might have a different opinion. I think saving a few bucks to put towards a sub would be the way to go smile.gif.
Bill
post #19 of 19 Old 03-17-2013, 09:20 PM
Emig5m's Avatar
I have B&W 804S and power them along with a HTM3S (center channel) and 685 bookshelfs (rear channels) with a Emotiva XPA-5. If doing multichannel, why not get a five channel amp? I've never once thought that the XPA-5 was lacking power with the 804S and to be honest, when crossing over to a sub it might be more steered towards overkill than not enough. I did used to drive a Yamaha 663 into protection mode with B&W 683's when running full range on heavy bass music at loud volume, that's what first sparked me to get the Emo amp, but otherwise I doubt I really needed it when crossing over to a sub. Nothing wrong with using XPA-1's for the 804, but IMO it's kinda like running high octane in a vehicle that's tuned for regular and thinking it's going to help when in fact there will be no difference in performance.
Emig5m is offline
