pioneer sc-1222 and no 5.1 on netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-14-2013, 07:25 PM - Thread Starter
eggie's Avatar
Quoted: 20 Post(s)
can someone please tell me why i cant get 5.1 decoded with netflix, just 2ch it started when i switched from a onkyo ht-180 to the pioneer sc-1222 ,please help..
eggie is offline
post #2 of 5 Old 03-15-2013, 02:55 AM - Thread Starter
eggie's Avatar
Quoted: 20 Post(s)
anyone
eggie is offline
post #3 of 5 Old 03-15-2013, 05:54 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
What device acquires Netflix and how is it connected? Is this the same device and connection you used with your old receiver?
BIslander is offline
post #4 of 5 Old 03-15-2013, 06:03 AM - Thread Starter
eggie's Avatar
Quoted: 20 Post(s)
roku box,yes it is the same device and connection with old receive, it does not decode burned dvd movies anymore
eggie is offline
post #5 of 5 Old 03-15-2013, 06:50 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
If the Roku is set to output DD 5.1 and you are playing content with DD 5.1, then check the input setting on the AVR. Is it set to stereo? Also, the AVR display should tell you the format of the audio it is receiving.
