Denon 1913 over onkyo TX-NR 616 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-15-2013, 01:35 PM - Thread Starter
sdrm's Avatar
Hey guys I finally got down two for my budget but I am leaning towards the onkyo. I know Denon has the audyssey XT whereas onkyo does not. Is there a huge difference between the two especially that now onkyo has resolved most of the issues on 616 with their firmware update.
Thanks alot.
sdrm is offline
post #2 of 5 Old 03-15-2013, 01:55 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Thanks alot.
Sorry, I'm too lazy to look up the Audyssey version in the Onk 616, (I'm sure you've done that but just forgot to mention it), but if it's 2EQ, then you have to know that there is no equalization for the subwoofer channel. So, Denon is your choice if you'd like to have deep, smooth and even bass in your HT system. smile.gif
Edit: OK I got over my laziness and saw that the Onk 616 has 2EQ. It's up to you to decide (or do more research!).
mogorf is offline
post #3 of 5 Old 03-15-2013, 06:24 PM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5510
Feri,
Just a FYI .... Onkyo chose to only use 2EQ on the 515, 616, and 717 and then jumped to XT32 on the 818. eek.gif
jdsmoothie is offline
post #4 of 5 Old 03-18-2013, 02:58 AM - Thread Starter
sdrm's Avatar
Thanks guys. The denon 1913 has only the Audyssey MultEQ not the advanced version. Does that calibrate the subwoofer too.
sdrm is offline
post #5 of 5 Old 03-18-2013, 07:24 PM
jdsmoothie's Avatar
Liked: 5510
Yes. All Audyssey versions (except the most basic 2EQ on the lower Onkyo models) can EQ the subwoofer.
Onkyo Tx Nr616
