AVR-1911 White Noise and Standby - AVS Forum | Home Theater Discussions And Reviews
Old 03-17-2013, 04:38 AM - Thread Starter
nutthatch's Avatar
Over the last few weeks I have had an issue with my receiver which is symptomised as follows.
I get intense white noise from my left mid surround speaker (I have a 7.1 setup) this lasts from a few seconds to several minutes the receiver then goes into standby mode. The receiver can then be re-started with no further issues for some time simply by pressing the On/Off/Standby button.
This is becoming more frequent.
Any suggestions please
nutthatch is offline
Old 03-17-2013, 06:00 AM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
Try swapping the L/R "side" surround speakers to confirm it's not a speaker issue.
jdsmoothie is offline
Old 03-28-2013, 02:39 PM - Thread Starter
nutthatch's Avatar
Yes, I tried that. The problem stays with the channel not the speaker
Old 03-28-2013, 05:26 PM
jdsmoothie's Avatar
Liked: 5548
Check to make sure you don't have any loose speaker stands touching another speaker post. Or if you have in-wall wiring, check the integrity of that wire with an ohm meter. Otherwise, try resetting the microprocessor (p. 80 OM). If still no joy, you're likely out of the 2 year warranty period, so if purchased with a credit card, check with the issuer to see if they will extend the warranty an extra year (AMEX will as will some MC/Visa).
Denon Avr 1911 Receiver
