Denon AVR-2807 volume clips (mutes) for no reason - AVS Forum | Home Theater Discussions And Reviews
Old 03-20-2013, 09:19 PM - Thread Starter
navidband's Avatar
Have a Denon AVR-2807 and, often times, while watching video from my TiVo Premiere connected with HDMI, the volume on this source clips, but video remains. Sometimes a power cycle fixes it, sometimes it doesn't.
Have ruled out the TiVo and the second zone is off when this happens.
Any clue what might be the source of this problem?
Really annoying. Please help!
navidband is offline
Old 03-21-2013, 07:13 PM
jdsmoothie's Avatar
Quoted: 12142 Post(s)
Liked: 5531
If it's connected via HDMI, could be another HDMI handshake issue which is generally resolved by connecting the HDMI directly to the TV with optical from the TiVo to the AVR. Or with no video problems, you could simply add an optical cable from the TiVo to the AVR and change the INPUT MODE to DIGITAL (ensuring both inputs are assigned to the same source name).
jdsmoothie is offline
Old 03-21-2013, 08:19 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 421
Before throwing things overboard...
Make sure each component has the latest firmware updates installed.
Also you might try the following order of powering up the system components..
1. The HD video display
2. The AVR
3. The source components
Just my $0..02... 👍😉
M Code is offline
Old 03-23-2013, 09:53 AM - Thread Starter
navidband's Avatar
To make matters worse, now there is not even any volume control; so when I turn the volume dial, the display doesn't even register the command and nothing happens! Looks like a goner.
Old 03-23-2013, 02:20 PM
jdsmoothie's Avatar
Liked: 5531
See if either unplugging the AVR for a few minutes or a microprocessor reset (p. 42 OM) will resolve the issue.
Denon Avr 2807 A V Surround Receiver
