AVR with TRUE 3-Zone Capabilities? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-23-2013, 05:49 PM - Thread Starter
SyracuseOrange's Avatar
Hey guys, new to the forum,
I'm looking for an AVR that has true 3 Zone capabilities.
I was looking at the Denon 3313ci, but when I looked up it's owners manual, you can only send out "mono" to both Zone 2 and Zone 3 and not stereo. Who wants that? Maybe mono to Zone 3, for outdoors or something, but not BOTH zones!
Well anyways, what's a good AVR around $1000 that can stream out STEREO to Zone 2 and Zone 3?
I'm not concerned with sending out a video signal to either zone, nor an HDMI out for either zone.
I also need network capabilities for Network Streaming from my computer (like to stream FLAC file eventually), SiriusXM interface and an App to use on my android phone and tablet that could control both Zone 2 and Zone 3.
Any good receivers there out there with these requirements?
(I also posted this over in audioholics)
Thanks for the input
Main room: Sierra Towers w/RAAL fronts, Sierra 1 surrounds and center, HTM-200 surround backs, dual HSU VTF2 MK4, Pioneer SC-1222K, JRiver Media
Secondary room: JBL L5, Pioneer Elite M-91, Pioneer Elite PD-F19 CD Player
Bedroom: Pioneer SX-780, Pioneer HPM-100s
SyracuseOrange is offline
post #2 of 8 Old 03-23-2013, 08:18 PM
jdsmoothie's Avatar
Quoted: 12086 Post(s)
Liked: 5502
If you want 5.1 audio in the main zone while both Zones 2 and 3 are playing stereo (all powered by the same AVR), they you'll need a 9.1 AVR (5+2+2=9), otherwise if you don't mind the main zone cutting down to 3.1, then IIRC either Yamaha or Onkyo can do that with a 7.1 AVR although forget the model. Also note that the 3313CI has Zones 2/3 pre-outs so you could power Zone 2 from the AVR and connect another 2CH amp to power Zone 3.
http://www.amazon.com/AudioSource-AMP-100-Stereo-Power-Amplifier/dp/B00026BQJ6
jdsmoothie is offline
post #3 of 8 Old 03-23-2013, 08:22 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I'm pretty sure you can send Stereo to Zone 2 and Zone 3. It has to be analog audio though.
I never heard of any AVR that only allows MONO to other zones.
Afro GT
afrogt is offline
post #4 of 8 Old 03-23-2013, 08:52 PM
jdsmoothie's Avatar
Liked: 5502
The 3313CI is a 7.2 AVR, so with 5.1 in the main zone, and only 2 AVR powered channels left, the zone options are either (a) Zone 2 stereo, (b) Zone 3 stereo, or (c) Zone 2/3 mono.
post #5 of 8 Old 03-23-2013, 09:21 PM
afrogt's Avatar
Liked: 755
Can't you use the Zone 2 or 3 preouts and still get stereo in both zones?
Afro GT
afrogt is offline
post #6 of 8 Old 03-24-2013, 06:05 AM
jdsmoothie's Avatar
Liked: 5502
Yes, of course, however, it would appear the OP wants to use the AVR to power all three zones without any external amplification.
post #7 of 8 Old 03-24-2013, 07:53 AM - Thread Starter
Thanks for the replies guys. Yes I"m looking for an AVR to power both Zone 2 &3. It looks like what I'm looking for is a 9.2 then. I've looked around and looks like the Yamaha RX-A2020, has 9.2 and Zone 2/3 capabilities. Though it's pretty pricey,a little out of the range I'm looking to spend. I see the A2010 has pretty much the same specs but no Airplay, and I would like to have airplay.
Any recommendations other 9.2 AVR with full networking capabilities (Airplay, media server, app for android phone)?
post #8 of 8 Old 03-24-2013, 08:03 AM
jdsmoothie's Avatar
Liked: 5502
If you can still find one, look for the older Denon AVR-4311CI (9.2) which will still meet your requirements.
