NEED HELP!!! pioneer vsx-1022-k - AVS Forum | Home Theater Discussions And Reviews
Old 03-24-2013, 05:15 PM - Thread Starter
dfi85's Avatar
i just bought the 1022-k today and i'm having trouble setting it up. i only have 5.1 surround sound and no room for any more speakers, at least not in this house. anyways, my problem is that i had a yamaha receiver connected to a samsumg bluray player with hdmi to tv and toslink, to receiver. i wanted to upgrade to get dts-master/ddtrueHD. on my yamaha i could cycle thru matrix 6.1 and enhanced surround with the dts light on, on the receiver it self. on the pioneer ive run it all thru the hdmi. but when my br player is set to pcm i see no indication on the receiver what format i'm in. so i played with the settings to bitstream and bitstream audiophile, and with audiophile bitstream, seems to be the only way to get the dts-mastr audio to light up. Its in the bottom left corner of the display (DTS-HD). now can i cycle thru the modes it says it has multiple dts modes and multiple dolby modes? how to do i go about setting everything up i've trying for the last 3 hours and i'm going to pull my hair out. the manual is no help. Also on my yamaha it displayed all the speakers when i was in dts mode, does this pioneer receiver do that aswell? how do i make it do that?
dfi85 is offline
Old 03-24-2013, 05:22 PM
Socketman's Avatar
Quoted: 146 Post(s)
Liked: 151
In your bluray player setup, turn off mixed audio, also called secondary audio that should fix it up for you.
Socketman is offline
Old 03-24-2013, 05:28 PM - Thread Starter
dfi85's Avatar
there is pcm down sampling on/off and dynamic compression on/off and downmixing mode surround compatible and stereo? and do i need to go to PCM or bitstream (re-encode) or bitstream audiophile???
dfi85 is offline
Old 03-24-2013, 05:47 PM
Socketman's Avatar
Quoted: 146 Post(s)
Liked: 151
whats the exact model of BR player
Old 03-24-2013, 05:48 PM - Thread Starter
dfi85's Avatar
samsung bd-p3600
dfi85 is offline
Old 03-24-2013, 05:52 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi dfi85, with the Samsung blu-ray player connected to 1022-k via HDMI, set it to bitstream audiophile.
JChin is offline
Old 03-24-2013, 05:58 PM
Socketman's Avatar
Quoted: 146 Post(s)
Liked: 151
Read page 39 of the manual. Bitstream audiophile is what you want.
