Audio and video drops - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-25-2013, 08:38 AM - Thread Starter
isagreg's Avatar
I am sure this has been disscussed before.
My Denon AVR-2113Ci drops audio and video signal from my cable box for a second.
HDMI control is on.
Any ideas?
isagreg is offline
post #2 of 9 Old 03-25-2013, 10:39 AM - Thread Starter
isagreg's Avatar
bump
isagreg is offline
post #3 of 9 Old 03-25-2013, 12:53 PM - Thread Starter
isagreg's Avatar
I will be more specific:
I hooked up Denon AVR-2113Ci to Panasonic G25.
The HDMI Control is On on AVR to activate Standby Pass Through.
Once in a while the sound and picture drops out for a second then comes back again, very annoing.
I found this, I don't know if it is relevant though:
http://denon.custhelp.com/app/answers/detail/a_id/439/kw/drop%20out/session/L3RpbWUvMTM2NDIzNjMyOS9zaWQvdWFoYnAzbWw%3D
It suggests to disable the TV's CEC option. Where do I find that?
There are VIERA Link settings...
Thanks in advance
isagreg is offline
post #4 of 9 Old 03-25-2013, 05:51 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
I don't have any experience with pass-through functionality, as my receiver doesn't have it, but according to this infopage by Batpig, VieraLink is Panasonic's name for CEC, so that's probably what you want to disable.
eljaycanuck is offline
post #5 of 9 Old 03-25-2013, 06:50 PM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5518
jdsmoothie is online now
post #6 of 9 Old 03-25-2013, 11:46 PM - Thread Starter
isagreg's Avatar
So you think it is a handshake problem?
I had the issue only when the AVR is off, that is when it passes the signal through.
I disabled VieraLink, we'll see how it goes.
If it doesn't help what options do I have?
One is connecting the box directly to the TV with HDMI for picture and optical to AVR for sound.
What else?
isagreg is offline
post #7 of 9 Old 03-26-2013, 04:22 AM
jdsmoothie's Avatar
Liked: 5518
Component video/optical from the box to the AVR.
Also note there is a thread dedicated to Denon AVR-XX13 Owner's linked in my sig. Review posts #3-6 for additional helpful information.
post #8 of 9 Old 03-26-2013, 10:51 AM - Thread Starter
isagreg's Avatar
What will I loose if I connect the box directly to the TV?
Doesn't component have worse picture quality than HDMI?
I remember optical did not support some DD and DTS modes.
isagreg is offline
post #9 of 9 Old 03-26-2013, 11:08 AM
Selden Ball's Avatar
Quoted: 3065 Post(s)
Liked: 1496
JDS tends to be overly concise, since most of the details are spelled out in the postings that he links to.
Cable boxes tend not to interact well with the HDMI repeaters used in receivers. When they have problems, the best workaround is to connect to the TV using HDMI (if the TV supports it) and to the receiver using S/PDIF digital audio (either optical or digital). No audio capability is lost because it isn't there to begin with. TV and cable channels use either stereo PCM or lossy Dolby Digital audio. They do not use DTS or the lossless Dolby encodings.
The major problem might be lip-sync of the audio. You might have to make adjustments in the TV or the receiver to match the audio or video delays.
Selden
Selden Ball is online now
