AV7005 HDMI strange signal problem. Please Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-25-2013, 12:07 PM - Thread Starter
Frank6500's Avatar
Hi,
I have the AV7005 for sometimes now and thoroghly enjoy it.
I recetly added a A/V component (a hard drive base karaoke player) to the av7005 and have been having singnal problem. After this new addition, there are a total of 3 A/V output attached to the AV7005. An Oppo, a PS3 and the Karaoke. All three output video singal through HDMI. The PS3 and Oppo also output audio thru. their repective HDMI but the Karaoke output audio by RCAs.
Here is the problem, the 7005 only sensed the input from the Oppo either (1) the Karaoke machine is also turned on, or (2) I disconnect the HDMI cable from the AV7005 that connect the Karaoke.
I checked all the input assignment and all are correct. There was never a problem when I only had the PS3 and Oppo connected. This only happened after I added the karaoke player. I even unplugged the power to the Karaoke and tested the effect of the Karaoke HDMI connection and it still affected the signal from the Oppo to the AV7005, ie. whenever the karaoke is connected (but not powered on) the 7005 won't output any AV signal to the amps or the projector. Howver, there was no problem playing the karaoke when all 3 HDMIs were connected.
I am so mystified by this and wonder if anyone had similar experience and can offer some advice.
Cheers,
Frank
Frank6500 is offline
Marantz Av7005 Pre Processor
