Yamaha RX-V 75 Series owners thread - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 224Likes
post #3091 of 3120 Old 08-19-2016, 01:09 PM
m. zillch's Avatar
Quoted: 1230 Post(s)
Liked: 776
It should be 120 Hz and it is good it is non-adjustable.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #3092 of 3120 Old 08-19-2016, 01:45 PM
kriktsemaj99's Avatar
Quoted: 628 Post(s)
Liked: 344
^ That's what I've always assumed, but don't know for sure.
PlasmaPZ80U likes this.
kriktsemaj99 is offline
post #3093 of 3120 Old 08-19-2016, 02:26 PM
PlasmaPZ80U's Avatar
Quoted: 1790 Post(s)
Liked: 513
And should the slope be 24dB per octave?
PlasmaPZ80U is online now
post #3094 of 3120 Old 08-19-2016, 02:29 PM
m. zillch's Avatar
Liked: 776
Since there is nobody that thinks it should be tampered with, nor do we think it can be (with most Yamahas at least), why all the interest in something you shouldn't touch?
post #3095 of 3120 Old 08-19-2016, 02:38 PM
Liked: 513
Originally Posted by m. zillch View Post
Since there is nobody that thinks it should be tampered with, nor do we thinking it can be (with most Yamahas at least), why all the interest in something you shouldn't touch?
...because when I do sub EQ with REW+UMIK-1+MiniDSP 2x4, having the LFE channel measured response fit the intended target line is important (I want a smooth rolloff at the top end of sub's response for LFE channel that is consistent with the LPF applied via AVR)... and the 375 doesn't do sub EQ, BTW.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony Core Bookshelf (SS-CS5) Side Surrounds, Rythmik LV12R; PS4, Xbox One, Motorola RNG150N
post #3096 of 3120 Old 08-19-2016, 02:48 PM
m. zillch's Avatar
Liked: 776
Oh I see, despite the fact that all experts are in universal agreement that it should not be tampered with, under any circumstances, and that the other [non-Yamaha] companies which offer user control over it were dead wrong to have done so, you actually know better. You are on your own kid.
post #3097 of 3120 Old 08-19-2016, 02:59 PM
Liked: 513
Oh I see, despite the fact that all experts are in universal agreement that it should not be tampered with and that the other [non-Yamaha] companies which offer user control over it were dead wrong to have done so, you actually know better. You are on your own kid.
It seems you have misunderstood what I said entirely... I'm not tampering with it, I'm preserving it.
If I was to use a horizontal, flat line as the target, I would get an uneven and sharp cutoff in the 100Hz to 200Hz region. By having a rolloff in the target line that matches the AVR's LPF for LFE (not an extra or different LPF just a target line for auto generated PEQ filters), I would get a even, smooth rolloff that would be a match to the result I would get with one of Yamaha's better AVRs.
You seem to think my goal is the change the LPFs frequency or slope... if that were true, why would I ask about the LPF the AVR is applying?
...really, give someone the benefit of the doubt before being so harsh.
post #3098 of 3120 Old 08-19-2016, 03:08 PM
m. zillch's Avatar
Liked: 776
Sorry if I was harsh.
I suspect you are mistakenly thinking the LPF of the LFE channel is synonymous with the LPF of your receiver's subwoofer output. As I understand it, these aren't the same thing but boy do they often get confused with each other.
post #3099 of 3120 Old 08-19-2016, 03:23 PM
Liked: 513
Well, I'm referring to the LPF applied to the LFE channel, not the LPF half of the (bass managed speaker channels') global crossover.
The reason for this is the measurement I take in REW is of the LFE channel and since the AVR is already applying LPF for the LFE channel (albeit fixed and not specified in specs), I want the target line in REW for PEQ filters to match the AVR's LPF for LFE channel corner frequency and slope. While 120Hz is obviously the right frequency, I want to confirm the slope as well as REW offers 12dB per octave and 24dB per octave as choices for the target line. Though when I hover over the setting there is a tool tip that says usually 24dB per octave.
So, I'm thinking 120Hz 24dB per octave are the parameters to input into the REW target line so the end result is an LFE channel response that is ideal. And so the bass managed channels also get improved indirectly as the MiniDSP is applying the filters to the whole signal the sub gets from the AVR.
post #3100 of 3120 Old 08-19-2016, 03:31 PM
m. zillch's Avatar
Liked: 776
Not sure if this helps, but for nitty gritty detailed specs you might want to sign up for an account here:
http://www.milleraudioresearch.com/avtech/index.html
Here are some screen shots I grabbed for you of another Yamaha receiver they once measured in 2008:
[To make things even more confusing when they say "LFE output" they might actually mean "the subwoofer output", but I'm not sure]
Notice the steep roll off of the LPF. I think this is to ensure you they can push the frequency up pretty high yet we won't accidentally hear male voice from the sub.
Name:	Screen Shot 08-19-16 at 03.17 PM.PNG
ID:	1612481   Click image for larger version
Name:	Screen Shot 08-19-16 at 03.20 PM.PNG
post #3101 of 3120 Old 08-19-2016, 03:48 PM
Liked: 513
Notice the steep roll off of the LPF. I think this is to ensure you they can push your frequency up pretty high yet won't accidentally hear male voice from your sub.
Well, I'll have to read it in more detail but it seems if REW has 2 choices, 24dB per octave is the safer bet.
Regarding that comment about male voices, that is for bass management, right? I don't think they would include any portion of dialogue in the Low Frequency Effects channel... unless maybe it's for an effect like with Batman's voice changer in Batman vs. Superman.
post #3102 of 3120 Old 08-19-2016, 04:19 PM
m. zillch's Avatar
Liked: 776
Except for bizarre alien or super being scenarios, I can't think of why we'd ever want male voices to come from the sub. Way back before we got calibration mics and computers to figure these things out with better accuracy than we can, a fairly standard test was to crank the sub up until all male voices sounded like Darth Vader, and then slowly turn down the sub level, bit by bit, until only Darth Vader sounded like Darth Vader. That's how you determined sub level!
post #3103 of 3120 Old 08-19-2016, 04:38 PM
Liked: 513
interesting, I guess voices like the Hulk and the like would qualify as effects instead of dialogue since it is outside the normal vocal range of male voices
post #3104 of 3120 Old 08-19-2016, 04:54 PM
m. zillch's Avatar
Liked: 776
Super beings don't count. For all I know they might come at you from all 5.1 speakers simultaneously even though they clearly are visually front and center on screen. . . You know, like God.
You can't use mythical sounds or mythical images to adjust/calibrate audio or video because there is no real-world reference for what is correct and accurate. This is why using cartoon or CGI images to adjust video displays is silly, just like using electronic instruments is for adjusting sound:
"I didn't like Shrek's skin tone at all. It looked off to me, so I adjusted my TV until it was the correct value of green."
is the same as:
"I thought the electric guitar in the Jimi Hendrix song sounded thin and tinny so I tweaked my EQ until it sounded accurate."
What these dumb people don't understand is they are adjusting for an arbitrary level they happen to prefer, not what is necessarily accurate or what the artists intended. Shrek doesn't exist so he doesn't have a true color and that Hendrix guitar has at the very least one if not more rotary tone controls right on the front surface which can give it thousands of different tonalities. Only Jimi knows what setting he used.
post #3105 of 3120 Old 08-23-2016, 02:35 PM
ChromeJob's Avatar
Quoted: 488 Post(s)
Liked: 159
Maybe the Borg in STAR TREK: FIRST CONTACT would qualify for subwoofer voice calibration. All channels, some (lots?) of sub-low register.
But still. Human voices start at what, 3000Hz or so? Maybe lower, like 2000Hz? If you're hearing harmonics of a voice from the sub, look for the name Michael Bay on the disc cover.
So back to the real world ... no one has feedback on the new firmware?
ChromeJob is offline
post #3106 of 3120 Old 08-23-2016, 03:01 PM
m. zillch's Avatar
Liked: 776
Originally Posted by ChromeJob View Post
Maybe the Borg in STAR TREK: FIRST CONTACT would qualify for subwoofer voice calibration?
Just like there is no such thing as Shrek, so you have no idea what exact shade of green he should be, there's no such thing as Borg, so you don't know what they should sound like. You've never met one in real life.
Sure, you can adjust your system to make these things appear/sound however you personally like, that's indeed what most people errantly do, but you will never be able to prove that your system is more accurate than another because the calibration test tone/image you used is simply a mental construct you've formed in your mind, not a real thing that we've actually experienced in the flesh.
Male voice can range from individual to individual [think Pee-wee Herman vs. James Earl Jones] however this graphic might be of averages:
Of course with processing such as Autotune or even just an equalizer male voices an be adjusted to be even lower, however some (real) male voices can even venture into subwoofer territory, say around 85 Hz or so.
post #3107 of 3120 Old 08-23-2016, 03:13 PM
Bond 007's Avatar
Quoted: 1922 Post(s)
Liked: 1672
My 675 is in the closet. I replaced it with a 740.
ChromeJob likes this.
Bond 007 is online now
post #3108 of 3120 Old 08-23-2016, 06:54 PM
ChromeJob's Avatar
Quoted: 488 Post(s)
Liked: 159
That's where my 663 is....
“What a funny, dirty little mind you have.”
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
post #3109 of 3120 Old 08-29-2016, 11:23 AM
NateDM's Avatar
I have a tricky question that I wanted to see if anyone could help me out with. I have an RX-V-375 and have recently upgraded my PC with a GeForce 1070 that will be going through HDMI to the receiver then the TV which is a Samsung SUHD JS8500 (4k and HDR). The problem is that when the signal is sent to the AVR first it limits the refresh rate to 30hz in 1440p. In 4k I can get the 60hz but that is just too high for this card to effectively run. I cannot find confirmation that the receiver should support or at least pass through this 1440p signal at 60hz. Does anyone know if I am out of luck with this receiver? My ideal setup would be to have audio and video hit the AVR first through HDMI from the PC to get full quality sound while having the video pass through to the TV at 1440p 60hz.
For now, I have the PC going to the TV directly to get 1440p at 60hz and then audio coming through optical back to the receiver but that leaves me with stereo sound instead of 5.1. I have also tried to use the ARC for audio but couldn't get it to sync. Thanks for any guidance!
NateDM is offline
post #3110 of 3120 Old 08-29-2016, 06:20 PM
rmjb's Avatar
Quoted: 67 Post(s)
Liked: 6
Maybe send video only to the TV and audio only to the AVR?
You could get one of those HDMI splitter boxes that can do this, or you can add a digital audio out to your PC.
This unit might be able to do that:
Behringer UCA202 Audio Interface https://www.amazon.com/dp/B000KW2YEI..._I6nXxb3MEE77Z
Sent from my A0001 using Tapatalk
NateDM likes this.
rmjb is offline
post #3111 of 3120 Old 08-30-2016, 12:05 PM
TonyApuzzo's Avatar
Originally Posted by NateDM View Post
... My ideal setup would be to have audio and video hit the AVR first through HDMI from the PC to get full quality sound while having the video pass through to the TV at 1440p 60hz...
I was able to get 2560x1600 @ 44hz passing through my rx-v475 from my ancient 8800GTX to my Dell U3011 by creating a custom resolution profile in the nVidia control panel. I would guess you could get 2560x1440 @ 60hz, or close to it with that approach. You will probably need to fiddle with the blanking timing to get an optimized refresh rate.
ChromeJob and NateDM like this.
TonyApuzzo is offline
post #3112 of 3120 Old 08-31-2016, 12:38 PM
NateDM's Avatar
Thanks I got it working! Strangely I did try this before posting but it would not display anything when I set the custom resolution to 1440p at 60hz. This time I set it again after having it at 1080p60hz then changed the color mode on the TV to UHD/HDR and changed the output from Nvidia's control panel to CMYK from RGB. Something in that change made the 1440p60hz pass the 'test' in the Nvidia control panel. Seems glitchy but I was able to get it working. Thanks for your help!
NateDM is offline
post #3113 of 3120 Old 09-08-2016, 02:13 AM
Liked: 0
Originally Posted by anjenaire View Post
I recently replaced a V467 with a V675. An issue I am having is that on standby through, no audio is coming from the TV speakers (as it did with the V467). Same HDMI cord, same TV different result. In check through the various options, I noticed the display is being shown as DVI:
Attachment 129282
Attachment 129290
Not sure why this is and how I can change this. This is most likely the reason why I have no audio since the receiver perceives a video signal only even though it is connected with an HDMI cable into an HDMI port on the television. Scratching my head. #@$%^& HDCP!
well, I know the post is old and probably no longer relevant for the original poster, but since I faced the same problem today and I found a solution, it is worth to put it here for other people with the same issue. In my case the problem came up after upgrading the my V675 to firmware 1.86. The cause is definitely the fact that the TV (in my case a PS51D8000 by Samsung) is detected as DVI instead of HDMI. I tried all possible settings on both TV and AVR, switched the HDMI cable to all inputs on my TV, did factory resets on both devices, and tried to downgrade the firmware (without success): nothing would fix the issue.
Then I tried to connect another screen to the AVR, and it was correctly detected as HDMI, with passthrough working correctly. I switched back to my Samsung and voila, it is now detected again as HDMI, and audio passthrough is back... even on the HDMI/DVI input on the TV
It looks like the AVR was "stuck" in DVI, and the switch to another screen (actually a PC monitor with HDMi input, go figure) solved the deadlock...
Hope this helps somebody else out there and spares her/him the hours I lost on this silly issue!
klaatu29 is offline
post #3114 of 3120 Old 09-08-2016, 05:49 AM
Liked: 0
music play
Hi,
I have v775 and Android (6.0, non rooted!) phone with Yamaha AV.
I wonder how could I play music saved on my phone via LAN to V775? On android app, there is no icon "music play". Only AirPlay, Spotify, NET Radio, Server.
and next question: How to play music from Deezer App?
I dont have Spotify Premium. Free Spotify do not support streaming unfortunatelly (or?)
thanks
japke is offline
post #3115 of 3120 Old 09-08-2016, 09:51 AM
rmjb's Avatar
Quoted: 67 Post(s)
Liked: 6
Originally Posted by japke View Post
Hi,
thanks
I have a network capable Yamaha stereo receiver, my Yamaha AVR is not networked, but I'm assuming it is similar.
On the Android app, where you choose your sources you should see an icon at the bottom of the list with the text that represents your phone. Here's how my OnePlus One looks:
This source will let you browse the music on your phone.
I also use Deezer, but Yamaha does not support it natively, so you'll need to connect a Deezer player to one of the inputs. Check http://deezer.com/devices to see what best suits you, I use a Chromecast Audio with great success.
rmjb is offline
post #3116 of 3120 Old 09-08-2016, 11:37 PM
Liked: 0
Hi,
I know (from official Yamaha v775 page) that this icon should be there, but on my phone (and also some other samsung phones that i tried) it is not!
I dont know if this is a "country" issue or anything else?
I have my Yamaha v775 reciever connected to Router with LAN cable. I am using AV app for NET radio and everything else. Just the "My Phone" is not there?!?!
thanks...
japke is offline
post #3117 of 3120 Old 09-09-2016, 03:21 AM
Bond 007's Avatar
Liked: 1672
Hi,
thanks...
Call Yamaha.
post #3118 of 3120 Old 09-09-2016, 01:58 PM
ChromeJob's Avatar
Quoted: 488 Post(s)
Liked: 159
Hi,
Go directly to a Chromecast, do not pass GO, do not collect $200. Will work a treat, particularly if using an app that's optimized for Chromecast like Google Play Music.
post #3119 of 3120 Old 09-21-2016, 07:54 PM
rmjb's Avatar
Quoted: 67 Post(s)
Liked: 6
Hi guys, was watching Netflix and I noticed my RX-V375 display only said Dolby Digital, no Plus in there.
Is it that it is only receiving a DD signal or that it does not show DD+ at all on the front display?
The source is a slim PS3. From the audio settings it detected that the receiver supports DD5.1, DD+ and True HD.
rmjb is offline
post #3120 of 3120 Old 09-21-2016, 08:11 PM
JChin's Avatar
Quoted: 322 Post(s)
Liked: 197
Hi rmjb, PS3 was fine with DD+ until Netflix recent update to 2.26.
JChin is online now
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
