Yamaha RX-V 75 Series owners thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 235Likes
post #991 of 3188 Old 04-16-2014, 08:15 AM
GMJohnson's Avatar
I will have to double check if I need to unplug the HDMI cable, or if I can just switch over the tuner. Thanks for the input. I might just turn HDMI control off and buy a Logitech Harmony or similar.
GMJohnson is offline
post #992 of 3188 Old 04-16-2014, 09:34 AM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1910
+1
Licence to Kill
Bond 007 is offline
post #993 of 3188 Old 04-16-2014, 12:26 PM
Sacc Attack's Avatar
Quoted: 13 Post(s)
Originally Posted by kriktsemaj99 View Post
I doubt it's defective, but HDMI Control is hit or miss depending on the particular combination of components. The order in which you turn things on can be important. It's usually best to turn on the display first, then the receiver, then the source. And when things don't work are you sure you can't fix it by just changing to another source (e.g. to Tuner) then back again, without physically unplugging any cables?
A good universal remote (e.g. Harmony) is the common solution for people who give up on HDMI control but still want a single button to turn on the whole system.
I dont know if it was my receiver or my tv, but i had some strange "oh no" moments when I set mine up. And after 30 seconds or so without changing anything they all seemed to figure eachother out and work.
Vizio m55
Yamaha v475
Pioneer Andrew Jones 5.0, BIC F12
PS4, AppleTV, DirecTV
Sacc Attack is offline
post #994 of 3188 Old 04-16-2014, 12:28 PM
NateDM's Avatar
I have a potentially similar question about HDMI-CEC and Standby on my V375.  When the AVR is in standby - sending a signal from the connected PS4, Chromecast etc will turn the receiver on and switch the input to the appropriate channel.  The issue is that no sound will play.  Even after changing the input away and then back to the appropriate input there is no sound.  The only way to 'reset' this is to turn the receiver off entirely and start it up again manually.
Is there any way to have the AVR come out of standby and actually play sound from an input?  Is this an HDMI handshake issue?  I am new to AVR tech so I could be missing something simple here.  Thanks for any help - although I don't really post I have learned a lot from this thread!
NateDM is offline
post #995 of 3188 Old 04-16-2014, 02:30 PM
Bond 007's Avatar
Liked: 1910
Yes. Handshake issue. Probably ARC related.
Licence to Kill
Bond 007 is offline
post #996 of 3188 Old 04-16-2014, 02:54 PM
NateDM's Avatar
I will disable ARC and see.  Any other ideas on what to try?
NateDM is offline
post #997 of 3188 Old 04-16-2014, 03:26 PM
Quoted: 13 Post(s)
there were a bunch of settings on my tv, not just receiver i had to mess with to get the audio to work how i wanted it. dl your tv manual and see.
Vizio m55
Yamaha v475
post #998 of 3188 Old 04-17-2014, 04:55 PM
vatakle's Avatar
Originally Posted by vatakle View Post
Hello Everyone,
 i couldn't hear any sound from subwoofer.
Please advise. Thanks
Just a quick update. I set the front speakers to large, crossover to 160 hz and everything is working fine. Once i will have the complete 5.1 i would be able to hopefully change it to small, 80hz and hopefully it works.
Thanks everybody for your replies. Appreciate it.
vatakle is offline
post #999 of 3188 Old 04-18-2014, 08:46 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
I listen to DD or DTS in the STRAIGHT when the source if from DISH (DD) or a DVD or CD (DTS)
When I listed to a non HD station on DISH or anything in PCM I listen in the 7 CH STEREO mode
When I listen in the 7 CH STEREO mode I often would like to boost the db of the rear speakers. Is there a setting on the AVR in which a preset can be made for the db levels for individual DSP modes?
CaptMike is offline
post #1000 of 3188 Old 04-18-2014, 09:07 AM
Bond 007's Avatar
Liked: 1910
All DSP modes are customizable. You cant change the db levels but in 7 ch stereo you can change the front/rear bias. Essentially changing the db levels of the speakers in pairs.
Licence to Kill
Bond 007 is offline
post #1001 of 3188 Old 04-18-2014, 10:33 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Ok thanks, and in "customizable" if the db levels cannot be changed, in what other ways is it customizable then?
CaptMike is offline
post #1002 of 3188 Old 04-18-2014, 12:21 PM
Bond 007's Avatar
Liked: 1910
Look for "Configuring Sound Programs" in your Owners manual. It is well explained there.
Licence to Kill
Bond 007 is offline
post #1003 of 3188 Old 04-18-2014, 03:15 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Ok...got the 7 ch Stereo customized but I guess the STRAIGHT mode is not a DSP mode as it cannot be customized as the other modes can.
CaptMike is offline
post #1004 of 3188 Old 04-18-2014, 04:57 PM
Bond 007's Avatar
Liked: 1910
Correct.
Licence to Kill
Bond 007 is offline
post #1005 of 3188 Old 04-18-2014, 05:05 PM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Correct.
Yeah, you kind of threw me when you said "all dsp modes are customizable" which was the reply to my question of STRAIGHT and 7 CH Stereo.
But I got that one figured out now.
Thank you
CaptMike is offline
post #1006 of 3188 Old 04-18-2014, 06:11 PM
Bond 007's Avatar
Liked: 1910
Thank you
yw Straight by definition bypasses the Digital Signal Processor and is therefore not a DSP mode. It only passes the existing signal "straight" through.
Licence to Kill
Bond 007 is offline
post #1007 of 3188 Old 04-19-2014, 03:44 PM
Quoted: 13 Post(s)
I'm wondering if I got a bad receiver. My lipsync issues isn't consistent and occasionally i'll be watching something (tv shows) even movies and the codec will switch between dolby digital and pro logic. every 5 seconds or so. Once the picture just turned off on me. Is this a directv thing or the receiver? I can't imagine a movie on hbo would switch between 5.1 and stereo like that.
Vizio m55
Yamaha v475
post #1008 of 3188 Old 04-19-2014, 04:53 PM
Bond 007's Avatar
Liked: 1910
Normal.
Lipsync will vary by source.
Its switching between displaying DD and PL because the movie is 2.0. Its not really switching codecs.
Licence to Kill
Bond 007 is offline
post #1009 of 3188 Old 04-20-2014, 08:23 AM
Rob MacKenna's Avatar
Hi folks.  About to pull the trigger on a V675 but I have a setup question that I'm hoping someone can give me some insight on.  I am envisioning setting up a 7.1 setup in my main room with front presence speakers in addition to center and left/right speakers in front and back left/right back surround speakers.  I also have a Zone2 that I would like to send music out to my patio area.  It would be nice but not crucial to send a different signal out there than in the main room (not a deal breaker by any stretch).  Looking at the speaker connections in the back, it appears that the receiver wants to connect Zone2 and Front Presence speakers to the same terminal.  Meanwhile the connectors for the "surround back/bi-amp" are not connected to anything.  Is it possible to reassign Zone2 or the Presence speakers to the unused terminal?  Or am I stuck using a speaker selector or a second amp connected to the "Zone2 out" RCA port?
Thanks for any help!
Rob MacKenna is offline
post #1010 of 3188 Old 04-20-2014, 12:54 PM
NateDM's Avatar
I wanted to follow-up and ask for some more advice.  I have disabled ARC and manually turned HDMI control off then back on for each input with no change.  I continue to get video but no audio through my AVR when any device turns on the AVR via HDMI control.  After manually turning the receiver off and back on the input works again.  This happens with both our PS4 and Chromecast.  Anything else to try?
nicolm likes this.
NateDM is offline
post #1011 of 3188 Old 04-20-2014, 01:59 PM
Bond 007's Avatar
Liked: 1910
You have some sort of a handshake issue. Turn HDMI Control off in all devices and buy a universal remote.
Licence to Kill
Bond 007 is offline
post #1012 of 3188 Old 04-20-2014, 06:31 PM
Quoted: 13 Post(s)
I read the manual and I dont think it's possible. But my nintendo wii is the only device I have that uses component cables. I was hoping the component in would still transmit video to my tv via my hdmi out. Guess not? anyone know if there's some trick?
Vizio m55
Yamaha v475
post #1013 of 3188 Old 04-20-2014, 07:07 PM
Bond 007's Avatar
Liked: 1910
Set the Wii to output 480i.
Licence to Kill
Bond 007 is offline
post #1014 of 3188 Old 04-20-2014, 08:22 PM
NateDM's Avatar
Frustrating that there is no fixing this - thanks for the feedback.
NateDM is offline
post #1015 of 3188 Old 04-21-2014, 08:14 AM
Benjitb's Avatar
(Posted in the MA thread as well - but its the Yamaha settings i'm asking about really)
Hello everyone, I have just completed my 5.0 setup.
For those on mobiles i have: Yamaha RX V-475, Monitor Audio Bronze BX2 Speakers, Monitor Audio Bronze BX Centre & Monitor Audio Bronze BRFX Rears.
I got the BRFX rears used for £80, they are Bipole/Dipole (previous model to the matching BXFX rears.)
I have a couple of Q's
1. The Nominal Impedance is 6 on my BRFX http://www.monitoraudio.co.uk/support/past-products/bronze-br/brfx/#/specification but 8 on the matching BXFX's http://www.monitoraudio.co.uk/products/bronze-bx/bxfx/#/specification. I don't understand the Nominal Impedance differerence.
2. Drive Unit Complement (again, no idea) is different.
3. Is there anything i need to do/adjust on my AVR before using them because of this.
When i've got them on the walls i'll get some positioning help too.
Yamaha RX V-475 - Monitor Audio Bronze BX2 L/C/R - BRFX Rears
FAT PS3
Benjitb is offline
post #1016 of 3188 Old 04-21-2014, 08:30 AM
Quoted: 13 Post(s)
I'm pretty sure it's set to do that automatically? Anyhow I can't change the settings until I can see the options menu on the tv anyhow. And the manual doesn't mention anything about composite in, hdmi out. I suppose I can just hook it into the tv and use ARC... just wanted to keep my system simple.
Vizio m55
Yamaha v475
post #1017 of 3188 Old 04-21-2014, 08:41 AM
Bond 007's Avatar
Liked: 1910
http://en.m.wikipedia.org/wiki/Nominal_impedance
The Yamaha is set to 8 Ohm by default. That will work fine so you dont have to make any changes.
I have no idea what Drive Unit Complement is. Sounds like a marketing buzzword from Monitor Audio. Might want to ask them.
Benjitb likes this.
Licence to Kill
Bond 007 is offline
post #1018 of 3188 Old 04-21-2014, 08:45 AM
Bond 007's Avatar
Liked: 1910
You may be right. I dont have a Wii. But Ive heard people say that the Yamaha will only upconvert the video if its 480i or 480p. I cant remember which. The upconversion chart is in the Owners manual.
Seems like others have mentioned a composite to HDMI convertor as well. Might want to look into that.
Licence to Kill
Bond 007 is offline
post #1019 of 3188 Old 04-21-2014, 08:56 AM
Quoted: 13 Post(s)
for the 2 times a year that i fire up the wii, it's not worth a hole lot of effort smile.gif
when i look at the specs, it appears the 475 doesn't offer upconversion so it must not do passthrough either.
http://www.crutchfield.com/p_022RXV475/Yamaha-RX-V475.html?tp=179
thanks for the help
Vizio m55
Yamaha v475
post #1020 of 3188 Old 04-21-2014, 11:56 AM
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
I just picked up a rx-v475 refurbed for 200 bucks. I am using this reciever in kind of an odd location. This is going to power my 5.1 (or soon to be 5.1) setup in my bar area that I am building in my basement. the shape of the room is first of all odd. It's an L shaped basement and the bar will be in the back corner of the L. So the speaker locations are not what you would see typically in a square room so using the automatated setup thing isn't best for setup in my situation. For the main use of this reciever I have it hooked up to an old dell inspirion all in one touch screen PC that is mounted on the wall and is acting as a JukeBox running a software called album player. I have it connected using a simple 3.5mm to rca cable as this pc is limited in any other type of output. I think it sounds pretty good but I'd like to tweak the speaker setup and EQ. Does anyone have any reccomendations on settings or EQ settings? Iv'e gone through the menues and it's a bit confusing. I turned up the levels on all my speakers to almost full as before it seemed that I had to really crank the volume to get the sound to close to "loud". I'm guessing there are some way's to really tweak the eq to help with this as well but it's pretty obscure to me as a newbie when it comes to recievers. any advice would be appreciated.
gec5741 is online now
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
