Yamaha RX-V 75 Series owners thread - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 236Likes
Old 05-08-2014, 05:28 PM
psychobrew's Avatar
Liked: 30
Originally Posted by luza View Post
Well I tried wiring my phone to the 2 audio inputs in the back. No dice. Will try with my PS4 when I get it next week.
Sorry, I missed that. I would contact Yamaha support.
Samsung PN50C7000
Yamaha RX-V775WA
BIC Venturi DV64 Towers
BIC Venturi DV62 CLRs Center
Still building but sounds amazing so far
psychobrew is offline
Old 05-09-2014, 06:31 AM
Sacc Attack's Avatar
Quoted: 13 Post(s)
I kind of skimmed your post, but do you have other speakers (even cheapos) you can try to rule out any damage to them during transport?
Vizio m55
Yamaha v475
Pioneer Andrew Jones 5.0, BIC F12
PS4, AppleTV, DirecTV
Sacc Attack is offline
Old 05-09-2014, 08:01 AM
Benjitb's Avatar
If i were to buy a NAS (with DNLA) drive, put flac on, plug it into my router with my 475 attached via ethernet cable and a bluetooth dongle attached to the 475.
1. With the PC off can i control my library of flac in the NAS via my android smartphone through the dongle and use it as a "jukebox" to play the flac/mp3?
2. I was recommended the cheaper: http://www.amazon.co.uk/HomeSpot-NFC-enabled-Bluetooth-Receiver-System/dp/B009OBCAW2/ref=sr_1_4?ie=UTF8&qid=1399486971&sr=8-4&keywords=Bluetooth+Audio+Receiver over the yamaha's: http://www.amazon.co.uk/Yamaha-YBA-11-Bluetooth-Adaptor/dp/B00BWEUNAA/ref=sr_1_1?ie=UTF8&qid=1399487329&sr=8-1&keywords=yamaha+bluetooth.
Any other recommendations. (USA or UK shops).
3. I know this may not be the perfect forum, but i'm a novice with NAS (with DNLA) drives any good budget recommendations?
Yamaha RX V-475 - Monitor Audio Bronze BX2 L/C/R - BRFX Rears
FAT PS3
Benjitb is offline
Old 05-09-2014, 01:41 PM
tonyr1955's Avatar
I use a Western Digital NAS to store all my music files, including FLAC and it works great my RX-V475. You can also use your computer as a DLNA server, but that means it has to be on. The WD NAS box does not use much power and I always leave it on. I also use it to stream video to my Yamaha BD player.
You can completely control the RX-V475 from your Android using the Yamaha AV Controller app. It controls the receiver via your WiFi network. You can select the input to be "Server" and then choose your DLNA server and which songs or playlist you'd like to play. I've streamed 24bit/96kHZ FLAC files from the NAS to the receiver and they sounded great.
With this kind of setup, I'm not sure why you'd want Bluetooth?
Benjitb likes this.
tonyr1955 is offline
Old 05-09-2014, 02:03 PM
Benjitb's Avatar
Hi Tony, thanks. That WD is exactly the one i was looking at, but i didn't want to spend £107 on that and £48 on the Yam dongle to find out it didn't work.(you use the Yamaha one then?)
1. I don't "want bluetooth" for sending music to the AVR, but though i'd need the bluetooth dongle to control what album/songs to play from the WD NAS via the Yamaha apps interface on the ios smartphone/ or does the App you said allow for this WITHOUT the yamaha dongle?
2. Can i just confirm that with the PC off I CAN use the 475 and WD NAS to navigate/play a music library.
FAT PS3
Benjitb is offline
Old 05-09-2014, 02:27 PM
tonyr1955's Avatar
Hi, in your first post, you said "android smartphone" and in the second "ios smartphone" (aka iPhone). I can't confirm that Yamaha has an app for the iPhone that can do everything the Android one does, but I'd be surprised if they didn't. Anyway, using the Android app, I can browse my music collection on the WD NAS and select which song/album/playlist to play. The only requirement is that your phone is on the same WiFi network. No Bluetooth dongle is required!
BTW, Bluetooth is limited to 768 kbps and CD quality FLAC files are close to 1000 kbps, so you won't get full fidelity from a BT connection.
The only reason I can think of for a BT dongle would be to play a streaming service, such as Google Play Music or some other service not supported by the RX-V475. For those, I decided to use a Google Chromecast dongle that plugs into one of the HDMI ports on the 475.
Benjitb likes this.
Old 05-09-2014, 03:49 PM
Benjitb's Avatar
Hi Tony, well done for spotting that, i was distracted and put the wrong op (android/apple). I do have an android, i installed all the apps a while ago, but have been too busy getting my speakers all set up  (buying and installing, tv/speaker stands/cables!) that I decided to leave something to savour at the end. The Networking.
That is great news that i don't require the Dongle for what i want to do, thanks for that, you've saved me some cash, I was told previously i needed it to use the phone to conrol the NAS.
Thanks for wrapping that up. I'll invest in the NAS soon. Yet ANOTHER £100+. When will this endevour end!
EDIT: I've read some revies that the WD NAS can be laggy when streaming HD movies, how have you found it?
greenhavenn likes this.
FAT PS3
Benjitb is offline
Old 05-09-2014, 04:29 PM
tonyr1955's Avatar
Ben,
I have never had any trouble streaming HD MKVs, even ones ripped from BluRay. This particular WD NAS has a gigabit Ethernet connection and I can easily transfer files at 240Mbps between my computer and the NAS drive. HD Video needs at least 20Mbps. My guess is that the people running into problems are trying to run the stream over an older WiFi connection running at 54Mbps. There's not much room for any sort of interference or competing traffic in that case. My network uses a wired connection (at 100Mbps) to the BluRay player.
Benjitb likes this.
Old 05-09-2014, 04:57 PM
Benjitb's Avatar
Ben,
I think you're right. I'd be using wired connections so that should be just fine.
Thanks for your help, have a great weekend.
EDIT: Curious, what speakers are you running with your 475 Tony?
FAT PS3
Benjitb is offline
Old 05-10-2014, 07:35 AM
Mgparnott's Avatar
Hi there,
I have a Rx v375, got it for Christmas. In January it had a repeated 'check sp wires' error messages. I checked all the speaker wires and after having completely unwired and rewired it, it worked well until last week.
I tried to connect a video camera via the component video connection, that didn't work so I gave up, but ever since I've been having the same check sp wires message when the volume goes slightly loud.
Initially I thought I'd loosened a connection when I pulled it out to connect the video camera, but I have just unplugged ALL cables from the back and when I run the test sound, the amp still cuts out with the same 'check sp wires' error message, but there are no wires connected!!!
This suggests to me that the problem is with the amp, not my speakers or cable, but any thoughts or experience would be most welcome.
Mike
Mgparnott is offline
Old 05-10-2014, 08:18 AM
Benjitb's Avatar
Originally Posted by Mgparnott View Post
Hi there,
Mike
Hi Mike, i think the "error" is a speaker wire error, caused by a short or perceived short.
You say: "the amp still cuts out with the same 'check sp wires' error message, but there are no wires connected!!!"
Sounds like you can have ruled out any error on your part, the problem is the AVR and you should contact Yamaha/ the shop for a replacement.
Alternatively i would say: Are you using banana plugs or not? Check again that no loose strands are "straying" to other connections on all speakers/connections. Do this one at a time then turn the system on and off trying to fing the wire(s) causing the problem. If you have any wires in walls/along walls double check them. If thats all correct and the problem persists, rule out the speakers as a source of error by hooking up some others to the AVR.
But you seem to have done that, and it worked for a week. You didn't say you'd found the source of the problem a week ago so the same wire(s) may have coincidently come loose.
Good luck
FAT PS3
Benjitb is offline
Old 05-10-2014, 02:39 PM
Mgparnott's Avatar
Thanks for that. Yes it still happens even when no speakers connected. Going to contact Yamaha!
Old 05-10-2014, 06:25 PM
psychobrew's Avatar
Liked: 30
So far I am really loving the RX-V775WA except for one issue. I keep getting an access error message when listening to Pandora. It works fine for a couple of hours, but then it quits. Yamaha supports thinks it might be the wireless adapter but I am not so sure since I can listen to Net Radio with no problem when this happens (though occasionally my phone is not able to find the receiver through the Yamaha app unless I manually enter the IP address). To fix this, I have to disable network standby (or whatever the network feature is that allows you to turn the receiver on through your phone), turn off the receiver, then turn it back on. If network standby is enabled, I have to turn the receiver off, unplug the wireless bridge for 30 seconds, plug it back in, then turn the receiver back on.
When I had it running over a wire, I did not notice this issue but I will be trying it again.
I am guessing the issue is a mixture of my FIOS wireless router and the Pandora implementation in the receiver, but I don't know what settings I need to adjust to improve performance.
Any thoughts would be welcome.
Samsung PN50C7000
Yamaha RX-V775WA
Old 05-10-2014, 09:47 PM
John-p's Avatar
Originally Posted by kriktsemaj99 View Post
Look under Video Out in the Input Menu (page 83 of the manual). You specify which HDMI input is to be used for video while playing a particular audio source (such as a network source). Then when you select the audio source the video will play from the HDMI input you specified.
I have tried that but you cannot select spotify connect as an audio output. Still stuck sadly :-(
John-p is offline
Old 05-11-2014, 04:46 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
Might be because Spotify isnt really completely internal to the receiver like Pandora and Rhapsody. It only gives you the capability to stream Spotify from an external device. What model do you have?
Licence to Kill
Bond 007 is online now
Old 05-11-2014, 08:31 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
When they added Spotify support in the firmware update they didn't add any more choices for Video Out. Maybe setting Video Out for AirPlay also works for Spotify (just guessing), otherwise I would ask Yamaha about it (maybe it's something they could add).
The easiest place to try all these things is the web setup interface (ipaddress/Setup/). Under System / Input_Output / Assign / Video_Out, try setting a video output for all the listed audio sources just in case one of them also works for Spotify.
kriktsemaj99 is offline
Old 05-11-2014, 10:02 AM
Benjitb's Avatar
I turned the equalizer off. Then ran YPAO  and it has set the [Equalizer->PEQ] automatically. Any idea why?
Rears are dipole (out of phase).
FAT PS3
Benjitb is offline
Old 05-11-2014, 10:05 AM
Bond 007's Avatar
Liked: 1911
Normal. Part of the reason to run YPAO is the eq the speakers. Just turn it Off again.
Licence to Kill
Old 05-11-2014, 07:41 PM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
Is this thread also good for rx-v377 owners?
MilkManX is offline
Old 05-12-2014, 02:15 AM
Bond 007's Avatar
Liked: 1911
http://www.avsforum.com/t/1531370/yamaha-rx-v-77-series-owners-thread
Licence to Kill
Old 05-12-2014, 10:06 AM
DiNZi's Avatar
I'm getting a RX-V675, how does the Spotify work on it? After connecting Ethernet, do I just go to say the Spotify app on the remote and login and play whatever songs I want?
DiNZi is offline
Old 05-12-2014, 10:17 AM
Bond 007's Avatar
Liked: 1911
No. You have to have a paid subscription. Then you can only stream to the 675 with an external device (pc, tablet, etc.).
Licence to Kill
Old 05-12-2014, 06:15 PM
asarose247's Avatar
Quoted: 699 Post(s)
Liked: 456
Question about Yamaha AV Controller App. It's downloaded to my S5 and my galaxy pad but if "stuck" in DEMO mode!
How have folks "enabled" it? so it works?
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
Old 05-12-2014, 06:30 PM
psychobrew's Avatar
Liked: 30
Your receiver must be connected to the network, either by wireless or hard wire. If that's done, then check network Standby and make sure it's on (otherwise you must turn on the receiver manually). If you are still unable to connect, you can clear the app cache on your phone or try restarting it or just enter the IP address manually.
Samsung PN50C7000
Yamaha RX-V775WA
Old 05-12-2014, 07:39 PM
asarose247's Avatar
Quoted: 699 Post(s)
Liked: 456
thanks for a swift reply, let you know how that works.
I do have a wireless connection for the avr.;
Old 05-13-2014, 02:20 AM
DiNZi's Avatar
Ok, I've got Spotify on my iPhone 5S and HTC One (M7), should that work pretty straightforward?
DiNZi is offline
Old 05-13-2014, 05:06 AM
Bond 007's Avatar
Liked: 1911
Yes
Licence to Kill
Old 05-13-2014, 10:00 AM
Quoted: 13 Post(s)
is there a display setting similar to that which displays which audio codec is being used that allows you to see what resolution video is passing through? I'm messing around with some netflix streaming and i'm curious about what resolution i'm getting sometimes.
Vizio m55
Yamaha v475
Old 05-13-2014, 10:22 AM
Bond 007's Avatar
Liked: 1911
Menu > Information > Video Signal
Most devices also have an Info button you can press when watching Netflix that will tell you also.
Licence to Kill
Old 05-13-2014, 10:38 AM
Quoted: 13 Post(s)
is it reactive? meaning it will update as the quality of the stream changes?
Vizio m55
Yamaha v475
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
