Yamaha RX-V 75 Series owners thread - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 236Likes
post #1201 of 3191 Old 05-13-2014, 10:42 AM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
Originally Posted by Sacc Attack View Post
is it reactive? meaning it will update as the quality of the stream changes?
Yes I believe so. Try it.
Licence to Kill
Bond 007 is online now
post #1202 of 3191 Old 05-15-2014, 07:12 AM
mygirlzdad's Avatar
Hello,
just received my new 675 yesterday; it will replace my old Yammy Rx-V1400.
Haven't unboxed it yet, will set it up this weekend. Just wondering how to connect my cable box from Brighthouse Networks, a Samsung HD DVR SMT-H3272. This unit provides our primary TV viewing signal. It has both HDMI and optical out connections. The 675 manual really doesn't address cable box connections. I'm inclined to just connect it to one of the HDMI inputs on the 675.
Thoughts....
My 5.1 set-up is using the following speakers:
Fronts: Axiom M60ti Towers
Surround: Axiom QS-8
Center: Yamaha NS-C310 (not overly impressed with this speaker. However, may be due to the age of the 1400)
Subwoofer: HSU VTF-2
Is anyone out there using, or has used, similar speakers?
I've read this entire thread and it's been so helpful.
Pete
mygirlzdad is offline
post #1203 of 3191 Old 05-15-2014, 07:29 AM
Bond 007's Avatar
Liked: 1911
Your inclination is correct. HDMI Out from cable box to HDMI In on 675. HDMI Out on 675 to TV.
Licence to Kill
post #1204 of 3191 Old 05-15-2014, 08:38 AM
mygirlzdad's Avatar
Thank you Mr. Bond.
I may have a few additional questions once I get into the set up.
Reading the manual and this thread has given me a good foundation for setting up my system. However, I may have questions about my sub connection. The back of the sub has a multitude of settings I'm really not familiar with, such as
Base Extension switch
Phase switch
Crossover switch
Variable Crossover Control
Dual Voltage Switch - this one I know about! :-)
Thanks again for your quick reply.
post #1205 of 3191 Old 05-15-2014, 10:48 AM
Bond 007's Avatar
Liked: 1911
The best place to ask about your sub is probably the owners thread for whatever kind of sub you have.
Licence to Kill
post #1206 of 3191 Old 05-18-2014, 03:29 AM
John-p's Avatar
Originally Posted by Bond 007 View Post
Might be because Spotify isnt really completely internal to the receiver like Pandora and Rhapsody. It only gives you the capability to stream Spotify from an external device. What model do you have?
I found a solution!!
If you go along to input> spotify or airplay you can press up and change the video out to HDMIxx
Works great! Thanks for all the help. I have an RXV675 FYI
John-p is offline
post #1207 of 3191 Old 05-18-2014, 06:22 AM
Bond 007's Avatar
Liked: 1911
Originally Posted by John-p View Post
Hello again. Loving my rxv675 after having it a couple of months now.
My question is I listen to spotify connect a LOT. How can I watch set top box through HDMI while still listening to spotify or airplay?
Every time I switch the HDMI I lose music then can't change the audio out to spotify. The only way around I can see is go back to RCA wired spotify through say audio1 then change the HDMI audio to Audio1.
Anyone got any tips ??
TIA
Originally Posted by kriktsemaj99 View Post
Look under Video Out in the Input Menu (page 83 of the manual). You specify which HDMI input is to be used for video while playing a particular audio source (such as a network source). Then when you select the audio source the video will play from the HDMI input you specified.
This is what krik posted for you 2 weeks ago. And then you said you couldnt select Spotify as an Audio input. Thats what threw everyone off.
Licence to Kill
post #1208 of 3191 Old 05-21-2014, 04:44 AM
John-p's Avatar
Okay, let me clarify that then. I thought he told me to go to the HDMI input in my case HDMI5 and change the audio output to spotify which you cannot do as spotify is not shown as an audio output.
BUT you can go to spotify as a video output and change the video to HDMI5 whilst still having the spotify audio. maybe some skim reading from me, I did go to page 83 but didnt see the correct instructions.
Still very thankful it works 😊 Thanks Kriktsemaj99
John-p is offline
post #1209 of 3191 Old 05-21-2014, 07:08 AM
Bond 007's Avatar
Liked: 1911
Spotify is an Audio input. You changed the Video out for that Audio input to HDMI5. Kriks post was correct and all you needed to fix your problem.
Glad you got it working.
Licence to Kill
post #1210 of 3191 Old 05-21-2014, 01:52 PM
tomreidy's Avatar
after searching I cannot find the answer to my question so I was hoping someone could help here. I would like to connect An equalizer/spectrum analyzer to my receiver. I don't see any preamp options other than subwoofer which is already connected. How could I make this work?many thanks in advance… Tom
tomreidy is offline
post #1211 of 3191 Old 05-21-2014, 02:36 PM
asarose247's Avatar
Quoted: 699 Post(s)
Liked: 456
Been a while since I thought of that but maybe this will give some direction
this sounds like a very old question from the strictly analog days.
where it was advised to use the tape inputs/outputs for putting an equalizer into the loop.
HIH
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #1212 of 3191 Old 05-21-2014, 03:24 PM
tomreidy's Avatar
Agreed, and based on the hard-to-find manual for the circa 80s device in question, which of the following on the back panel receiver "out cluster" would one most likely connect into said device?:
1) AV out
2) audio out (even though it doesn't specify "out" but it's within the same cluster)
3) monitor out
4) sub woofer pre-out (already used)
tomreidy is offline
post #1213 of 3191 Old 05-21-2014, 06:25 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
I just realized the 75 series took away the ability to stream airplay to zone 2 while still using hdmi 5.1 in the main zone. They now require airplay in both zones. The 3030 and 777 are the same way. The 775 does allow more audio inputs to have a video background available like John-p just started using. On the 777 all analog, network and usb inputs will allow background video. Arrow up baby. No more piano wallpaper! 2014 only.
kikkenit2 is offline
post #1214 of 3191 Old 05-22-2014, 11:36 AM
brilong's Avatar
I just replaced my RX-V630 (2002) with a RX-V775 and I'm concerned with the volume.  On my previous receiver with optical input from the PS3, I would set the volume to -45dB or -40dB max and it would sound great (and loud).  On the RX-V775 with HDMI from the PS3 (not optical), before and after I ran YPAO, I have to set volume to -20dB to experience decent levels of audio.  This is with the speakers mentioned in my signature below.  YPAO was not very loud even though the documentation recommends not running it at night due to the fact it can disturb.  I've only followed the quick start guide and I'll dig into the user manual later today, but is there anything specific I should look for or are the volume knob "dB" levels not comparable between Yamaha receivers?  Am I just looking for a problem where one doesn't exist?  Thanks.
Definitive Technology ProMonitor 80 x 4, ProCenter 100, ProSub 80
BenQ W1070 Projector
Yamaha RX-V775WA
Ultimate Home Theater Fusion Escape seating
Buttkicker Advance
brilong is offline
post #1215 of 3191 Old 05-22-2014, 11:44 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
This question comes up all the time. You can't compare the volume number with old models. It's normal that you'll be using -20 or more.
brilong likes this.
kriktsemaj99 is online now
post #1216 of 3191 Old 05-22-2014, 12:37 PM
gymnos's Avatar
Hi, I always set the volume between -30dB and -25dB, I have never reached -20dB thinking about the neighbours.
Regards.
gymnos is offline
post #1217 of 3191 Old 05-22-2014, 04:16 PM
Benjitb's Avatar
Hi Brilong, I would say a problem does exist. I connect my PS3 via HDMI to a 475 in the same series and if i set the volume to -20bD it would rock the walls of the House, let alone the room. I generally use the same levels you previously did (-40,-45) for Blu-ray TV shows, (Game of Thrones) and its just right.
This question does seem to sometimes come up but if none of the noises on the YPAO were loud then thats another indicator, i wouldn't run it with the cat in the room.
You had an AVR before so i'm assuming you haven't got it on a strange mode or accidently adjusted the trim? What did the YPAO set the levels of the speakers?
Try reseting to defaults if it persists.
Yamaha RX V-475 - Monitor Audio Bronze BX2 L/C/R - BRFX Rears
FAT PS3
Benjitb is offline
post #1218 of 3191 Old 05-22-2014, 07:32 PM
Quoted: 636 Post(s)
Liked: 357
He does not have a problem. TV and video games are not mastered to any standards so you can't say much about what's normal volume. But DVD and Blu-ray discs are pretty consistent and you need to watch at -10 to -20 to get anything like a real movie experience. There's a trend these days to master them louder than they should be, so I play some recent discs at -20, but never lower than that.
-40dB for a Blu-ray is not going to sound very loud at all unless you have incredibly efficient speakers and sit close to them.
post #1219 of 3191 Old 05-23-2014, 06:45 AM
brilong's Avatar
Interesting back and forth about the volume issue.  I watched The Avengers Blu-ray last night with the PS3.  At times the dialog was too quiet with -20 to -18, so I pumped it up to -16.  With -16 the sound effects were a little too much, so I definitely have some tweaking to do.  I've not yet played with the multi-point YPAO nor have I tried boosting just the center channel a little to help with dialog.
Yamaha RX-V775WA
Buttkicker Advance
brilong is offline
post #1220 of 3191 Old 05-23-2014, 07:28 AM
Bond 007's Avatar
Liked: 1911
What size is the room? How far do you sit from the speakers? What volume did YPAO set your speakers at? Can you provide a picture of your system?
Licence to Kill
post #1221 of 3191 Old 05-23-2014, 07:41 AM
brilong's Avatar
Hi Bond,
My speakers are listed in my signature.  DefTech ProMonitor 80's, ProCenter 100, ProSub 80.  Pictures of my room before I moved furniture in are available here (in the BenQ W1070 thread).  The room is 14' wide and about 30' long.  I'm sitting about 11' from the wall where the image is projected (no screen yet).  Because of the light switch, my projected image is about 95" diagonal.
When I looked briefly at the YPAO settings, it had the sub at -6dB and most of the other speakers at 0dB, -1dB and +1dB (left?).  I have yet to finish putting the left speaker on a stand in front of the closet door; right now it's sitting on that knee wall.  This weekend I plan to fix it so the left and right channels will be equidistant from the screen.  I'll upload new pictures when I'm done adding the wall plates for the banana plugs.
Yamaha RX-V775WA
Buttkicker Advance
brilong is offline
post #1222 of 3191 Old 05-23-2014, 07:49 AM
Bond 007's Avatar
Liked: 1911
Hi Bond,
Thanks. I use the mobile version most of the time and signatures dont show on it. Nice speakers.
I clicked on that link and it said something like "unusable lightbox data".
Sounds like everything is pretty normal as far as your settings. Multipoint may help a little. Sometimes center channel placement can make the center not sound as good. Thats why I asked for a picture.
Licence to Kill
post #1223 of 3191 Old 05-23-2014, 07:58 AM
brilong's Avatar
Bond,
Here's a link to the actual post where I included the photos.  I've not used the AVS mobile version so I didn't realize signatures were not shown.
Yamaha RX-V775WA
Buttkicker Advance
brilong is offline
post #1224 of 3191 Old 05-23-2014, 08:16 AM
Bond 007's Avatar
Liked: 1911
Bond,
A sealed room, thats a good thing. You may want to consider carpet since its your HT room. It will cut down on reflections and sound much better.
You using the deftech 80 system or 800 bookshelf speakers? Either way thats a pretty good size room and youre asking a lot of those speakers. Its no wonder you have to turn it that loud.
Licence to Kill
post #1225 of 3191 Old 05-25-2014, 01:54 PM
asarose247's Avatar
Quoted: 699 Post(s)
Liked: 456
"Agreed, and based on the hard-to-find manual for the circa 80s device in question, which of the following on the back panel receiver "out cluster" would one most likely connect into said device?:
1) AV out
2) audio out (even though it doesn't specify "out" but it's within the same cluster)"
a picture could help
post #1226 of 3191 Old 05-26-2014, 08:45 AM
mygirlzdad's Avatar
Have a noob question: Just hooked my 675 and did the YPAO setup. All devices, Blu-Ray, Roku, Sammy set top box, and Sammy LED, are connected with HDMI. Running 5.1 but noticed that the sub isn't putting out any sound.
Went into set up and found that YPAO set my speakers to Large. Went into manual setup and changed them to small, saved it and then did a test tone. My sub is set to Use, and shows as being part of the system. However, when using the test tone all speakers produce a sound but the sub doesn't.
Don't know what's goin on. Can anyone help with this?
post #1227 of 3191 Old 05-26-2014, 09:17 AM
Bond 007's Avatar
Liked: 1911
Lets start with the obvious.
Is it turned on?
Are you sure the sub works?
Have you tried a different cable?
Did it produce sound when you ran YPAO? If so what level did the 675 set the sub at?
Are you sure its making no sound? Its a low frequency and you have to turn it up pretty loud to hear it.
Did you go LFE Out on the 675 to LFE In on the sub?
Licence to Kill
post #1228 of 3191 Old 05-26-2014, 10:42 AM
mygirlzdad's Avatar
Thanks for the quick response Bond.
Well, I got it working.
Short answer is there are two cable inputs on the back of the sub labeled L and R and under the R Mono! When I reconnected to the input labeled Mono, it worked.
Re-ran the YPAO setup and it configured the sub to -10.db.
Not sure why the YPAO set the Fronts to Large, but I went into manual setup and changed them to Small.
post #1229 of 3191 Old 05-26-2014, 11:41 AM
Bond 007's Avatar
Liked: 1911
Glad you got it working. Its normal for YPAO to set the fronts as large. Most people change them to small.
You should keep playing with the sub volume at the sub and rerunning YPAO until you get the sub volume in the area of -3/+3 in the 675. -10 is the limit. You may be at -16 for all you know.
Licence to Kill
post #1230 of 3191 Old 05-26-2014, 11:43 AM
clipper57's Avatar
Quoted: 21 Post(s)
recently purchased the yamaha 575 reciever and noticed when playing blurays and using standard dsp mode the osd reads dts but if i go to straight mode it shows dts master.is this normal ? would like to use the dsp modes and get hi-def audio.thanks for any help i can get.
clipper57 is offline
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
