Yamaha RX-V 75 Series owners thread - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #1321 of 3203 Old 06-16-2014, 03:06 PM
fredxr2d2's Avatar
Quoted: 198 Post(s)
Liked: 110
Originally Posted by am_dew View Post
Originally Posted by kriktsemaj99 View Post
Originally Posted by johnnymacIII View Post
Hi everyone. I was reading Nyall Mellor's blogs over at Acoustic Frontiers and he stated, "Note that the low frequency effects signal is nearly always internally set to be to be 10dB louder than that for the speakers so that the end user's life is simplified and the subwoofer is calibrated to 75dB rather than the 85dB one might expect." Is this true for the rx-v375 or do I need to calibrate it to 85db using the internal pink noise. Thanks for your time. Here is a link to the page. http://www.acousticfrontiers.com/hom...eference-level
With Yamaha receivers the internal test tones for all channels (sub included) should be calibrated to 75dB with master volume at 0.
Can anyone recommend a good guide to manually calibrating a 5.1 system with a SPL meter?
Haven't used it yet, but found this one:
http://forum.blu-ray.com/showthread.php?t=38765
Best of luck!
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 106" 0.8 Gain Screen, Darbee, PS4, w/ Marantz SR6011, NAD C370 (for Front L/R), Outlaw Model 5000, SVS PB-2000, SVS PC-2000, a Def Tech CS-8080HD, 2 SM65 for L/R, 2 SM55 for sides, 2 PM1000 for rears, and 4 AW5500 for Atmos.
fredxr2d2 is offline
post #1322 of 3203 Old 06-16-2014, 06:35 PM
johnnymacIII's Avatar
Quoted: 163 Post(s)
Liked: 51
Best of luck!
+1 This is the one I used.
johnnymacIII is online now
post #1323 of 3203 Old 06-17-2014, 05:59 AM
Sacc Attack's Avatar
Quoted: 13 Post(s)
Liked: 29
Originally Posted by Sea3 View Post
I see there is a firmware update.
Firmware Update Version 1.51
1. Improves stability of AirPlay playback
2. Includes other functional improvement
Any idea what the "other functional improvement" might be?
this must be the network receivers only because I still see 1.21 for the 475
http://download.yamaha.com/search/pr...uct_id=1752277
Vizio m55
Yamaha v475
Pioneer Andrew Jones 5.0, BIC F12
PS4, AppleTV, DirecTV
Sacc Attack is offline
post #1324 of 3203 Old 06-17-2014, 06:19 PM
am_dew's Avatar
Quoted: 27 Post(s)
Best of luck!
Thanks! In reading this guide, it says to play the test tones and then adjust the master volume so that the SPL meter reads 75 dB. I'm just curious how loud this will be and if anyone has a V 375, what was your master volume setting when the test tone was 75 dB? I know speakers vary in efficiency but it will at least give me an idea what to expect. I don't have an SPL meter yet but I turned on the test tones and started adjusting the master volume on my 375 upwards and it started getting pretty loud at -10 dB or so. I think I've read that 75 dB should be with the master volume at 0. I don't want to bother my downstairs neighbors so I'm wondering how critical the 75 dB is when just trying to adjust each speaker so they are all relatively the same volume?
am_dew is offline
post #1325 of 3203 Old 06-17-2014, 06:55 PM
Quoted: 163 Post(s)
Liked: 51
I have the 375. The test tones at 75 db are pretty loud. If you have neighbors downstairs I would do it when they aren't home or let them know what you are doing and tell them it will only be a few minutes. Right now I have relatively inefficient satellite speakers (remnants of an old sony HTIB from 2003) so your results may be different, but I set the 375 at 0 db and had to add 6 - 8 db per speaker to get to 75 db. When calibrating, it's loud enough to where you definitely want to get it over with, but not painful or anything.
I believe it is important to calibrate the speakers to 75 db, because that is the db that the pink noise was recorded at.
I would definitely calibrate it to 75 db. After running YPAO and setting the correct speaker levels, you will definitely have a much more enveloping sound. For me, YPAO set my sub and surrounds a bit too low. For you, maybe it set yours perfect, but it would be good to check just to make sure you are getting everything you can from your system.
Have a good one, man.
post #1326 of 3203 Old 06-18-2014, 05:57 AM
kriktsemaj99's Avatar
Quoted: 648 Post(s)
Liked: 367
... I don't have an SPL meter yet but I turned on the test tones and started adjusting the master volume on my 375 upwards and it started getting pretty loud at -10 dB or so. I think I've read that 75 dB should be with the master volume at 0. I don't want to bother my downstairs neighbors so I'm wondering how critical the 75 dB is when just trying to adjust each speaker so they are all relatively the same volume?
First, it's only really important to have all speakers balanced relative to each other. Having master volume 0db be reference level (75dB with the test tones) is not essential.
Second, you can calibrate to 65dB with the master volume at -10 (and so on), then you'll end up with the same result as 75dB at volume 0. The only drawback here is that background noise in the room can interfere more, so just try to do it when everything is as quiet as possible.
kriktsemaj99 is offline
post #1327 of 3203 Old 06-18-2014, 06:34 AM
am_dew's Avatar
Quoted: 27 Post(s)
The reason I asked, besides not wanting to bother my neighbors, was that the YPAO test tones don't seem nearly as loud as the manual test tones with the master volume turned up higher than around -20. The relative low levels of the YPAO tones surprised me when I ran it for the first time. My girlfreind has an Onkyo AVR which uses Audyssey and those tones are much louder than the YPAO tones.
am_dew is offline
post #1328 of 3203 Old 06-18-2014, 11:20 AM
jnick1's Avatar
Quoted: 56 Post(s)
Finally pulled the trigger on my sub, the LV12R!
With that said, it's been a WHILE since I setup a sub/HT system. I have a Yamaha 675, infinity speakers and now the LV12R. How do I go about calibrating the sub? I was reading that I need to play with the Sub Gain to get YPAO to get the sub the closest to 0dB? Then tweak the levels inside the receiver?
I do have an SPL meter and typically, I tone out all the speakers to read 80dB on the SPL, with the center running a little hot, around 82-83 for better dialogue and the sub running at 84-85 for more bass. Is this still the way to do it? However, please note that I NEVER used room calibration software. I always just used the SPL meter.
Thanks and I can't wait for it to get here so I can get started!
jnick1 is offline
post #1329 of 3203 Old 06-18-2014, 11:52 AM
Quoted: 648 Post(s)
Liked: 367
^ You can still set the levels manually, but it's worth running the YPAO auto-setup first then you can hear what it does for EQ. You might find you like YPAO Flat or Natural vs no EQ, and you can always disable the EQ if you don't want it. Make any manual level changes afterwards, and it doesn't affect the YPAO EQ results.
post #1330 of 3203 Old 06-18-2014, 12:06 PM
jnick1's Avatar
Quoted: 56 Post(s)
Awesome, glad I asked as, again, I never used any room calibration software. So to confirm, run Yamaha's YPAO, pick an EQ setting, then confirm dB ranges using the SPL? Should I find discrepancies, I can then +/1 dB per channel to even it out on the SPL?
What is the process for the sub? I was reading about getting it to where YPAO sets the sub as close to 0dB? If it's too far off, to then play with the gain and re-run YPAO?
Thank you!
jnick1 is offline
post #1331 of 3203 Old 06-18-2014, 04:11 PM
Quoted: 648 Post(s)
Liked: 367
Correct. And you have 0.5dB steps for level changes if you really need that precision.
post #1332 of 3203 Old 06-18-2014, 04:25 PM
Bond 007's Avatar
Quoted: 2518 Post(s)
Liked: 1993
Thank you!
Correct.
Bond 007 is offline
post #1333 of 3203 Old 06-19-2014, 06:24 AM
jnick1's Avatar
Quoted: 56 Post(s)
Another question; how do I go about figuring out the crossover frequency? Does Yamaha have anything in their RCS that will help or do I go based on my speakers white papers?
jnick1 is offline
post #1334 of 3203 Old 06-19-2014, 08:23 AM
Bond 007's Avatar
Liked: 1993
See the answer that I provided for your identical question in the Rhythmik thread.
Bond 007 is offline
post #1335 of 3203 Old 06-19-2014, 09:52 AM
jnick1's Avatar
Quoted: 56 Post(s)
Got it. Thanks! I actually already have the receiver, it's just not hooked up yet. I'll look at the manual today.
I'm just curious, why does it matter that you run YPAO then manually configure it rather than just configure and blanace with an SPL? Can you not use EQ settings if you do it manually?
Thanks again!
jnick1 is offline
post #1336 of 3203 Old 06-19-2014, 10:13 AM
am_dew's Avatar
Quoted: 27 Post(s)
Thanks again!
I could be wrong but YPAO will also set the proper delays based upon their distance.
am_dew is offline
post #1337 of 3203 Old 06-19-2014, 11:04 AM
Bond 007's Avatar
Liked: 1993
Correct.
Bond 007 is offline
post #1338 of 3203 Old 06-19-2014, 11:06 AM
Bond 007's Avatar
Liked: 1993
Thanks again!
Reread post 1330 above.
Bond 007 is offline
post #1339 of 3203 Old 06-19-2014, 03:36 PM
scooby609's Avatar
Hey all
Just picked up the RX-V375 from Amazon, about to set it up but I can't seem to find where I can find firmware updates for my new receiver all I can find are user manual downloads... Can anyone point me in the right direction please?
scooby609 is offline
post #1340 of 3203 Old 06-19-2014, 03:46 PM
am_dew's Avatar
Quoted: 27 Post(s)
Originally Posted by scooby609 View Post
Hey all
I also have the 375 and had the same question when I got it and I found out that there are no firmware updates for this model.
scooby609 likes this.
am_dew is offline
post #1341 of 3203 Old 06-19-2014, 03:56 PM
scooby609's Avatar
OK thanks! guess I can stop looking around now & start hooking my new baby up!
post #1342 of 3203 Old 06-19-2014, 04:00 PM
am_dew's Avatar
Quoted: 27 Post(s)
Have fun! I got mine 2-3 months ago and I am still tweaking it, but that's just me....it's a real nice AVR for the price.
am_dew is offline
post #1343 of 3203 Old 06-19-2014, 05:49 PM
jnick1's Avatar
Quoted: 56 Post(s)
I did re-read it, however, it doesn't really explain why. kriktsemaj99 explained that YPAO auto sets everything and the EQ. My question was, if I don't use YPAO and configure it manually, can I still manually set the EQ? Or is the EQ limited strictly to YPAO configuration.
jnick1 is offline
post #1344 of 3203 Old 06-19-2014, 06:39 PM
Quoted: 648 Post(s)
Liked: 367
On the 675 and higher, you have full manual control over the parametric EQ (same control that YPAO has). On the lower models if you don't want the YPAO EQ you only get a manual graphic equalizer (not parametric, so the width and centre frequency of each filter is fixed).
post #1345 of 3203 Old 06-19-2014, 07:38 PM
Bond 007's Avatar
Liked: 1993
Page 93 in the Owners manual.
Most of the stuff you are asking is explained in the manual and is pretty intuitive when you start setting it up. You should read the manual and try setting up your system and if you have any trouble then ask questions. You dont have to wait until you get the sub to set up your other speakers. It will be good practice.
Bond 007 is offline
post #1346 of 3203 Old 06-20-2014, 06:48 AM
jnick1's Avatar
Quoted: 56 Post(s)
You got me there. I have not read the manual yet :/. I will be doing so over the weekend, however, so thank you for your patience!
Unfortunately, I'm still awaiting the cabling for the system, which should be here at the beginning of next week otherwise I promise you, those speakers would have been up and running! I can only withstand listening to the "razer thin" speakers on my Vizio so much!
Thank you for your help.
jnick1 is offline
post #1347 of 3203 Old 06-20-2014, 06:49 AM
jnick1's Avatar
Quoted: 56 Post(s)
Thank you! Either way, I'm going to run YPAO. I was just curious as to if the EQ functionality was there, should I want to do a full manual setup at some point. I'm still new to all of this, so thank you for your help!
jnick1 is offline
post #1348 of 3203 Old 06-20-2014, 12:48 PM
brilong's Avatar
Hey all
When I first turned on my RX-V775 while it was plugged into my home network, it automatically connected to Yamaha's servers and popped up an onscreen dialog asking if I wanted to perform a firmware upgrade. It appears the RX-V375 does not have a Network port, so I'm not sure about firmware upgrades.
Definitive Technology ProMonitor 80 x 4, ProCenter 100, ProSub 80
BenQ W1070 Projector
Yamaha RX-V775WA
Ultimate Home Theater Fusion Escape seating
Buttkicker Advance
brilong is offline
post #1349 of 3203 Old 06-21-2014, 05:54 AM
anjenaire's Avatar
RX-V675 Showing DVI instead of HDMI on Display
I recently replaced a V467 with a V675. An issue I am having is that on standby through, no audio is coming from the TV speakers (as it did with the V467). Same HDMI cord, same TV different result. In check through the various options, I noticed the display is being shown as DVI:
Not sure why this is and how I can change this. This is most likely the reason why I have no audio since the receiver perceives a video signal only even though it is connected with an HDMI cable into an HDMI port on the television. Scratching my head. #@$%^& HDCP!
anjenaire
"Conservation, it's worth the energy"
anjenaire is offline
post #1350 of 3203 Old 06-21-2014, 06:51 AM
Quoted: 648 Post(s)
Liked: 367
^ You could try going into the Advanced Setup Menu and setting Monitor Check to SKIP. Might not work but it's worth a shot (page 106 of the 675 manual). Remember to turn it off and on again after changing the setting.
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
