Yamaha RX-V 75 Series owners thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 245Likes
post #1561 of 3216 Old 08-22-2014, 03:44 PM
acousticdelight's Avatar
Hi all, I have a Yamaha rx-v675 receiver and i have my chromecast powered by the front usb port in the receiver. The problem with this set up is that the chromecast is powered even when the receiver is in standby mode. Is there a way I can shut down the chromecast power from the usb port when I turn my receiver off and put it to standby mode?
acousticdelight is offline
post #1562 of 3216 Old 08-22-2014, 06:12 PM
kriktsemaj99's Avatar
Quoted: 659 Post(s)
Liked: 382
Probably not for the front USB port, but you can for the rear one (the one labelled DC OUT). Look in the Setup Menu for DC OUT.
kriktsemaj99 is offline
post #1563 of 3216 Old 08-23-2014, 09:18 AM
Birddoggin's Avatar
Quoted: 53 Post(s)
Originally Posted by johnnymacIII View Post
If you haven't already packed up the 475, did you try switching around the HDMI cables to rule out a bad cable? Did you try switching the inputs around to see if it was a bad input? If you switch everything around and Dish is still the only dropout issue, your problem may reside in your Dish receiver. I would try all that before I would get another avr only to find out it was your Dish receiver.
Well I got the dropouts to go away. I had to use a digital optical cable for the sound on Dish. For some reason, the audio didn't work right using HDMI between Dish and the 475. It's funny because HDMI audio is fine with the blu-ray player and Roku.
Well, kinda fine with the Roku. No dropouts, but I get PCM only instead of DD+. Gonna do some research on that soon.
Bottom line is that I may end up keeping the 475 after all, so thanks for the tip!
Birddoggin is offline
post #1564 of 3216 Old 08-23-2014, 09:29 AM
Birddoggin's Avatar
Quoted: 53 Post(s)
Originally Posted by m. zillch View Post
The good thing about glitches in DVR playback is you can hit rewind and replay the troubled section over again. If it repeats itself exactly in the same spot then you know the devices downstream probably aren't at fault and there's most likely a problem with that specific recorded TV show in that particular spot.
If you re-record another airing of the same TV show episode, a repeat broadcast, and the glitch is still there at the same spot, that tells you it is on the broadcaster's end and there's nothing you can do at all.
I rewound many times after the glitches, and the dropouts were never there the next time. Anyway, using a digital optical cable instead of HDMI for audio took care of it.
post #1565 of 3216 Old 08-24-2014, 08:56 AM
ChromeJob's Avatar
Quoted: 1190 Post(s)
Liked: 621
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
The rear port on my 775 only puts out 0.5A, which is sufficient for the Yamaha Bluetooth Adapter, but NOT for a Chromecast (requires about 1.0A - 1.5A IIRC). If the amp had switched power on the back like my 663, it could be powered that way with the Chromecast's AC adapter.
FWIW I moved my Chromecast from the TV (where it was powered by the TV, when it was on) to the RX-V775 because I noticed that the Chromecast identified itself as an HDMI-CEC device. Sure enough, when an app connects to the Chromecast e.g. Photos or screen-casting (Beta) on Android, Google Play Music or Netflix or HBO Go on Android & iOS, the input switched. Now plugged into HDMI2 of my 775, the Chromecast will switch the Standby Through input to HDMI2, and turn the TV on. So it makes sense to leave the Chromecast on. I think the device can handle it. And for only $35, if it burns out in a year or two, just get another, newer version of the Chromecast.
(Since I have Network Standby set to ON so that I can switch the amp on from the Android/iOS remote app, the amp is in standby mode anyway with or without Standby Through.)
I have the reverse issue. With optical audio out from my TV, Netflix (and I presume Amazon Prime) are submitting DD+ 5.1, but the amp just identifies it as Dolby Digital, with intermittent dropouts (no more than a second, but sometimes several occurrences per minute). With Netflix running on a Chromecast in HDMI2, the amp identifies the decoder as Dolby Digital+. I'm beginning to wonder if this is the problem. I'd be interested in others' observations after toggling the INFO button while seeing audio dropout problems. Toggle INFO until you see the Decoder display. I seem to have no issues when PCM is displayed.
Others online complain about the Samsung TVs, or the Netflix App, but since people in this thread are seeing the issue with multiple devices, I think the x75 amps have an issue.
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
post #1566 of 3216 Old 08-24-2014, 09:28 PM
johnnymacIII's Avatar
Quoted: 163 Post(s)
Liked: 51
No problem. I remember having the same problem with Directv. It was my sat receiver. I would call Dish and see if they can replace your reciever for you for free.
Try setting your Roku to bitstream if it has that setting. It also may be transcoding the audio so you may want to play with those settings as well.
johnnymacIII is offline
post #1567 of 3216 Old 08-26-2014, 12:47 AM
Cyborg_Optoma's Avatar
Quoted: 109 Post(s)
Originally Posted by jnick1 View Post
Another question; how do I go about figuring out the crossover frequency? Does Yamaha have anything in their RCS that will help or do I go based on my speakers white papers?
Originally Posted by Bond 007 View Post
See the answer that I provided for your identical question in the Rhythmik thread.
Got it. Thanks! I actually already have the receiver, it's just not hooked up yet. I'll look at the manual today.
I'm just curious, why does it matter that you run YPAO then manually configure it rather than just configure and blanace with an SPL? Can you not use EQ settings if you do it manually?
Thanks again!
can you guys provide the url.. of the post which you are talking about..related to checking crossover for the entire system
i have a yamaha rx-v575.. and all I see in the configuration is.. it just says crossover at one place..it means that the value it shows there after YPAO setup is set to all the speakers in the system ? how can I check the individual crossover frequencies... I am not sue how useful the feature test tone is ... again from menu option... as the sound from each speaker is like for 2-3 seconds only and that too the sound is just like when you don't have any transmission and the that sound seems useless to catch the frequency of the speaker using a spl meter... or I am I wrong ?
if someone knows how to determine or set individual crossover frequencies for rx-v575... please let me know.... I am guessing it is not possible...
also after ypao .. what other values in the system is recommended to be bumped ? trim or tone volumes....or sound levels from the main menu..
appreciate your response..
PS: I am trying to calibrate PSA sub woofer .. all these days.. almost 8-9 months since I had this receiver... I have set the values on different menus and sub menus is just by my hearing levels and how I felt good about the sound....and never liked the ypao setup... but recebtly I changed home.. and right now using ypao setup.. and it seems ok... but I just want to get more bass.. please let me know your recommendations.. I can provide details about the room or other speakers in my setup.. Thanks
Cyborg_Optoma is offline
post #1568 of 3216 Old 08-26-2014, 06:52 AM
Quoted: 163 Post(s)
Liked: 51
The 575 does not allow you to set the individual crossover for each speaker. It only allows for an entire setup crossover. You will have to cater to your weakest link in the chain.
To use the test tone feature to set your spl, you need to turn on test tones and then go into the menu option where you would check your speaker levels. Now you can hear pink noise for each individual speaker for as long as you need to.
After I run YPAO; I change all my speakers to small, bump the crossover frequency for all speakers up to 80hz, and check the spl of all speakers(including the subwoofer) to make sure that the spl is balanced across all speakers. That is all I do.
post #1569 of 3216 Old 08-26-2014, 02:29 PM
Quoted: 109 Post(s)
can you please explain to me what you mean by this...
enable the test tone feature ?
test tone is already there in menu...setup>speaker configuration>test tone is right under the equalizer.. when I just get into the Test Tone menu item.. it just has on and off toggle.. on plays the noise from the speakers.. and off means.. I can get out of the test tone menu.... how do we increase the delay in the noise to play for say as long as we want from each speaker... appreciate your help and input.
post #1570 of 3216 Old 08-26-2014, 05:08 PM
Quoted: 163 Post(s)
Liked: 51
Press setup on remote. Inside the speaker setup menu click on Test Tone. Turn Test Tone on. Exit Test Tone. Click on Level. Pink noise will now be played to each individual speaker that you highlight.
post #1571 of 3216 Old 08-27-2014, 12:20 AM
Quoted: 109 Post(s)
wow you are awesome.. Thanks for the information...
one more thing.. is this pink noise enough for the spl meter to get the crossover frequency that a particular speaker is letting out.. I believe it is.. I just have to increase the volume say at -40 db or -30 db so the spl meter can get a value.. and do the same thing for all speakers.. that is set volume at -40 db or -30 db..
post #1572 of 3216 Old 08-27-2014, 01:03 AM
Quoted: 163 Post(s)
Liked: 51
No problem.
YPAO is generally good at setting SPL with the exception of the subwoofer (at least with my experience). I generally set my SPL to 75 db across the board and make a note at what DB my relative volume is set to. That way I can know how far below reference volume I am playing. To do this you might turn the volume up on your receiver to read 0db and then turn up or down the level for each individual speaker to get a 75 db SPL reading on the meter. That way when you are playing a movie at -20db you will know you are playing 20db below reference volume.
You run YPAO to automatically set your crossover and you make adjustments as you see fit (80hz to 120hz is generally the number to aim for). If you are unhappy with what YPAO is doing, I would look into getting Room EQ Wizard with a UMIK-1 so you can accurately set your crossover and SPLs. You will be able to see quite a bit from there. Better yet, get a miniDSP nanoAVR 8x8 and bypass the Yamaha speaker management system altogether. Before you give up on YPAO; make sure that you are putting the YPAO mic level (preferably on a tripod), at ear height, your speakers are setup at the recommended positions, and there is no noise in the room (I even leave the room).
Good luck.
post #1573 of 3216 Old 08-27-2014, 09:54 AM
m. zillch's Avatar
Quoted: 1974 Post(s)
Liked: 1263
In dozens of Yamaha manuals the test tone noise is referred to as "like pink noise", key word: like. This may be because it is, for instance, bandwidth limited pink noise, or perhaps spectrally skewed for what works best for setting volume levels by ear. [The human ear is much more sensitive to volume changes around 3.5 kHz than it is elsewhere, so they theoretically may boost that region, for example].
https://www.google.com/search?q=yama...-US:IE-Address
If it were truly just pink noise then why do they throw the word "like" in front of it?
It's probably quite suitable for setting levels, but there are test discs and downloadable files of true pink noise and I would feel safer using those for any full range EQ purposes. Just sayin'.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #1574 of 3216 Old 08-27-2014, 01:35 PM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I just hooked up my Rx v775. My center speaker is set on the lower shelf pointed slightly up, however, because the projector screen is 106", I am not getting the voices to center (they still seem to come from below the screen). I thought there was a way to center the sound of the center channel but I can't find it. Does anyone know how to do this? Oops - sorry, I have the 777 receiver.
shortspark
milacqua is offline
post #1575 of 3216 Old 08-27-2014, 02:00 PM
m. zillch's Avatar
Liked: 1263
There's only one sure fire way to make the center of the soundstage coincident with the center image and that's to use the exact same technique used in professional movie theaters [which is after all what our home theaters are attempting to mimic but at a smaller scale]: place all three speakers in a straight line behind the center of the acoustically "transparent" screen:
post #1576 of 3216 Old 08-27-2014, 02:06 PM
m. zillch's Avatar
Liked: 1263
What's that? Don't own an acoustically transparent screen or for that matter even a projector? Then you will have to compromise in some way and how you do that will be up to you.
Keep in mind millions if not billions were successfully entertained by a medium called stereo, still in wide distribution to this day, and although there is almost always a center image in nearly all a stereo songs, often the vocals for example, very few people actually have a dedicated speaker in the center to reproduce that part. They use what is sometimes called a "phantom center" which means the imaging of their front two speakers will hopefully create the illusion of a center image. Your electronics allow for this mode as well.
Just because everyone you know says you have to have a center, doesn't mean it's true. They often create more problems than they solve, and their "necessity" is questionable if your theater layout is primarily for entertaining an audience of only one or two viewers wide.
From your manual:
"If the function "4. CENTER SPEAKER" in the SET MENU
mode is set in the "PHNTM (phantom)" position, in step
10, the sound output level of the center speaker cannot be
adjusted. This is because in this mode, the center sound
is automatically output from the left and right main
speakers."
post #1577 of 3216 Old 08-27-2014, 09:52 PM
Quoted: 109 Post(s)
No problem.
Good luck.
Thanks again.. appreciate your input .. will try out your suggestions.
post #1578 of 3216 Old 08-28-2014, 09:31 PM
ChromeJob's Avatar
Liked: 621
I believe the manual details how you can set "center height" using front presence speakers. Is that an option?
In my 775 manual, it's referred to as "dialogue lift" or "height balance" (7ch Stereo).
You could also ... perhaps ... send the Center pre-out audio to the TV separately. Not sure if this would be satisfactory. Several years ago, I had Bose 201 Series II speakers next to the TV as dual center channel speakers, but also had the TV playing center channel quietly (using a pre-out), which helped center the, um, center channel content. You couldn't hear it until I muted the TV, and the absence was noticeable.
Yet another option: use Dolby PLIIx Music mode, and set center width from default 3, to 2. What this does: send center channel content to left, center and right, creating a wider "phantom" center channel using the side speakers. I use the Music mode for films a lot as it makes the Center channel sound more like a full theater setup. Reducing the width from 3 to 2 narrows the default Music phantom Center to more in the center without being quite a narrow and localized as a dedicated center speaker.
post #1579 of 3216 Old 08-28-2014, 09:38 PM
ChromeJob's Avatar
Liked: 621
Network lost infrequently, requiring disconnection or turning off network standby
It's continued to happen: Pandora has suddenly said "not connected." Cycling power on the amp does nothing -- I have Network Standby enabled. The amp Info - Network display indicates DHCP has been lost and the amp has the usual 169.x.x.x address. Tonight I remedied this by unplugging the CAT5 Ethernet from the router (acting as a wireless bridge, or repeater) momentarily. On reconnecting the amp immediately started streaming Pandora.
Anyone else noticed this with their x75 network connection?
post #1580 of 3216 Old 08-29-2014, 04:36 AM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
Thanks for that ChromeJob, I will try your suggestion later today. Yesterday I found the center "height" adjustment and it works with some settings but not others (mine is a 5-1 set up). It helps somewhat but my real problem is the lip-synch. I can't seem to get it right. There is a "delay" enable/disable setting that I'm not sure what it means but I'll look it up. Anyway, I have tried "delay" both ways, auto/manual and making adjustments and it still seems a bit off.
I do notice that voices that should be centered (such as a reporter's news broadcast on ABC) does not seem to come from the center, but, as you suggested, from the two front speakers. This seems to throw the speaker's voice off, hence, it adds to the lip-synch issue. I will play with the settings a bit more and try the different modes. I have just installed the 777 after coming from an older RX series receiver that was fried in a lighting strike. The older receiver did not have this problem but I'm sure it is correctable with the proper settings. Another thing is that when the source is ProLogic, Master Audio, etc., for example, my old receiver showed that but this new one does not so I never know what mode I'm in. I am too far away from the receiver to see how many speakers are actually playing but I assume the receiver is picking up and playing whatever source material is being sent to it.
shortspark
milacqua is offline
post #1581 of 3216 Old 08-30-2014, 03:02 PM
ChromeJob's Avatar
Liked: 621
I've noticed that my RX-V663 would display a speaker arrangement to indicate the channels it was receiving; this RX-V775 shows what speakers are playing. Not sure I like that. I believe toggling the "INFO" display to DECODER will indicate what format the input source is. Let me confirm that by putting a 96/24 DVD and an equivalent Blu-Ray.... Yep, it shows DTS 96/24 for Peter Gabriel's PLAY and Ron Fricke's CHRONOS DVD. Seems you have to put the amp into STRAIGHT to see the input channels
If you only have 5.1 speakers, and no front presence speakers, I don't think the "height" adjustments will do anything. I only suggest putting DD and other 5.1/6.1 audio sources through PLII Music as the introduction of center channel content to the side speakers will reinforce a higher sensation (particularly if your side speakers are at ear height, and roughly the TV screen's height). Leaving it at the default width, 3, will be more reinforcement than setting to 2 (which effectively reduces the amount of center channel content from the sides). Play with it with different sources and content. There's no right answer here, just what you and your ears prefer.
post #1582 of 3216 Old 08-30-2014, 07:29 PM
m. zillch's Avatar
Liked: 1263
Personally I would avoid using any form of electrical height elevation, even if it initially seems effective for a given scene, due to the deleterious effects on lateral panning on the center sound image. It's sort of a parlor trick or a gimmick and would likely be terrible if there's music playing through the center channel.
I found a third party source to back my contention:
Technical Editor Hugh Robjohns replies: Conventional stereo and surround systems have no intrinsic ability to convey height information. They are designed to produce only a horizontal soundfield. However, there are various 'tricks' that can create the impression of height. The most effective is to use complex and specific comb filtering to recreate the kind of natural comb filtering produced in the listener's ears when sounds are coming from above. Several pseudo-surround systems claim to be able to do this — Roland's RSS and Q Sound Labs' Q Sound are two. This type of 3D-from-stereo system has been discussed before in the Q&A pages, in July 2003 (www.soundonsound.com/sos/jul03/articles/qa0703.asp) and, more recently, in July 2004 (www.soundonsound.com/sos/jul04/articles/qa0704-5.htm).
To recap briefly here, the problem is that the results are not all that reliable or consistent, as these systems are heavily dependent on both the nature and quality of the listening system and environment, and the perceptions of the listeners themselves! Fortunately, in your situation you are working with pictures, and since eyesight is a far more dominant sense in most people than hearing, if the audience can see a helicopter 'above' them, they will automatically associate the corresponding sound with a similar height. All you have to do is ensure that the perspective and relative panning movement of the sound in the horizontal soundfield doesn't break that illusion. "
http://www.soundonsound.com/sos/Oct0...s/qa1004-9.htm
Of course it can't hurt to try, but if you notice it sometimes seems odd...
ChromeJob likes this.
post #1583 of 3216 Old 08-31-2014, 04:10 PM
ChromeJob's Avatar
Liked: 621
I concur. I tried Neo:6 Music a few years ago (which probably means I'm due to try again, as I'm in a new room, different distances), and it just didn't sound right.
That's the bottom line ... how does it sound, not just with a test 30-second scene from a movie (as I was doing last night with center ch config LARGE (full sound to channel) vs SMALL (diverts bass frequencies < [crossover setting] to scenes from BARAKA), but after a few hours of listening to different content. At a certain point, your ears will tell you.
post #1584 of 3216 Old 08-31-2014, 05:06 PM
Liked: 1
where do i set my receiver to let it know there is no sub in my config? (5.0, yamaha rx-v775)
Thnx!
Xavit is offline
post #1585 of 3216 Old 08-31-2014, 05:16 PM
Bond 007's Avatar
Quoted: 2622 Post(s)
Liked: 2083
Thnx!
Setup > Manual Setup > Configuration > Subwoofer > None
Bond 007 is offline
post #1586 of 3216 Old 09-01-2014, 06:56 AM
Liked: 0
Airplay with video?
I have a yamaha 575 and am trying to figure out if I can listen to music via airplay or spotify and watch an hdmi source at the time. I can change the audio out to av1 and av2 but airplay/spotify/pandora is not an option. Anyone have any ideas?
Stlfreak is offline
post #1587 of 3216 Old 09-01-2014, 07:28 AM
Bond 007's Avatar
Liked: 2083
Change the VIDEO OUT of the music source.
Bond 007 is offline
post #1588 of 3216 Old 09-01-2014, 07:38 AM
Liked: 0
Where do I change that??
Stlfreak is offline
post #1589 of 3216 Old 09-01-2014, 08:21 AM
Liked: 0
Not seeing anything that allows me to change the video out. From what I've researched, this is capable on the 675, but I haven't seen where someone has accomplished this with the 575. I hope I'm wrong though.
Stlfreak is offline
post #1590 of 3216 Old 09-01-2014, 09:30 AM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi Stlfreak, on the remote press the OPTION button and scroll down to Video Out.
JChin is offline
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
