Yamaha RX-V 75 Series owners thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 245Likes
post #2341 of 3216 Old 03-31-2015, 05:34 PM
m. zillch's Avatar
Quoted: 2003 Post(s)
Liked: 1285
Originally Posted by dannphou View Post
Wait, don't you only turn on Adaptive DRC at night? Or am I misunderstanding the point of adaptive DRC?
You use it whenever you wish to limit the change in volume between loud and soft passages. A typical scenario is when you don't want the loud explosions in the movie to wake your housemates, hence the generalization that you would use it typically "at night".
"Adaptive" means it not only applies a limitation to the change in dynamic range but it does it differently based on the average level you happen to select on your master volume knob.
I find it to be only mildly effective, but that's probably better than "overkill" which would make music sound like, um, modern pop music which is said to be very compressed from the get go.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #2342 of 3216 Old 03-31-2015, 08:07 PM
kriktsemaj99's Avatar
Quoted: 665 Post(s)
Liked: 383
If you want less than maximum dynamic range (which you seemed to be asking for) then Adaptive DRC will do that. I never use it, but I watch movies in a dedicated room and don't have to worry about disturbing other people.
kriktsemaj99 is offline
post #2343 of 3216 Old 03-31-2015, 09:07 PM
Bond 007's Avatar
Quoted: 2656 Post(s)
Liked: 2110
Bet those F1 cars sound mighty fine in there.
Bond 007 is online now
post #2344 of 3216 Old 04-01-2015, 05:46 AM
Quoted: 665 Post(s)
Liked: 383
^ The new cars not so much. But my cable TV provider seems to compress the dynamic range of all audio to a certain extent, which is a pity.
post #2345 of 3216 Old 04-01-2015, 07:18 AM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
I use volumes in the -40.0 dB to -50.0 dB range so adaptive drc can be overkill at times. I use such values during the day and night since my room is small and my fronts are fairly sensitive at 87 dB and YPAO sets the front left at 0.0 dB and adjusts the rest to match the front left.
I wanted only a mild drc so I could hear soft dialogue passages without deafening peaks and it seems BD movies with lossless audio tend to have way more dynamic range than regular Dolby Digital soundtracks found on other BDs, cable TV, Netflix, some games, etc.
Too much drc makes content sound unnatural/unrealistic but too much dynamic range can also be annoying. I wish there was a dynamic range setting that affected all input signals and had a ten point scale for manual adjustment.
PlasmaPZ80U is online now
post #2346 of 3216 Old 04-01-2015, 09:18 AM
m. zillch's Avatar
Liked: 1285
There's not much you can do to correct it if they broadcast it that way but many cable boxes, such as my Comcast DVR, has a DRC setting in the advanced setup menus.
post #2347 of 3216 Old 04-01-2015, 10:20 AM
Quoted: 22 Post(s)
Liked: 9
Setting up my RX-V675 tonight when I get home. I will be for a 2.1 system (for now). Will it be worth my time to run the YPAO or is that mainly for surround setups?
Bard78 is offline
post #2348 of 3216 Old 04-01-2015, 10:50 AM
Bond 007's Avatar
Liked: 2110
Yes. Run YPAO.
post #2349 of 3216 Old 04-01-2015, 11:16 AM
Quoted: 22 Post(s)
Liked: 9
Thanks. I will give it a go then.
Bard78 is offline
post #2350 of 3216 Old 04-01-2015, 06:29 PM
Liked: 716
If I want a cheap tripod with an extension bar purely for YPAO mic use, what's a good choice?
Also, I have a very, very old tripod I might be able to use if I can buy an extension bar separately.
I currently place the mic on top of a small plastic container close to ear level in the main listening position. However, I wonder if the box interferes with the mic's reading accuracy.
post #2351 of 3216 Old 04-01-2015, 06:54 PM
m. zillch's Avatar
Liked: 1285
Unless people are seriously rearranging major furniture, drapes, rugs, or changing their speakers/speaker placement, YPAO is a set and forget sort of thing. Can you perhaps borrow one? How about balancing and then duct taping a broom stick/mop/cane/crutch/hockey stick etc. to the existing tripod? Perhaps you have a musician friend with a mic stand/boom? If you are reading some thread where people are talking about how important a good tripod with boom is and how it makes a world of difference, stop reading that thread! YPAO mics are also extremely omnidirectional; although you should aim it straight up as a good practice, at ear height, I doubt even serious misaiming it by 45 degrees would have any real world consequence. [ear height is important though]
Note the "acceptance angle" spec here, meaning "it's always good":
Another trick is to attach the mic to a stick like device and lean it, from the back, on the backrest of the primary listening chair so it falls where one's ears are. [Yes, the nearby box surface is not good since it may add a refection.]
If you MUST buy then here's an option:
http://www.monoprice.com/Product?seq...15C=1699455042
if you want the YPAO mic to screw on you may need a "1/4- 20 adapter" , if it doesn't come with one, that they or other music stores sell.
post #2352 of 3216 Old 04-02-2015, 06:27 AM
ChromeJob's Avatar
Quoted: 1216 Post(s)
Liked: 641
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
Curious.... You could set the level of the mains down and then all else accordingly, since those are sensitive.
Also ... if it's just dialog you're concerned with, maybe use the dialog adjustment (level) in Options? Nothing dynamic about it, but it would boost the center (I believe that's all it does, I could be wrong) for a particular title.
(Unfortunately, it doesn't have negative values. Criterion's 5.0 mix on the IN THE MOOD FOR LOVE DVD I just started playing has the center/dialog much louder than in the 2.0 mix.)
Don't think you need an extension bar. I just did measurements in 6 or 7 positions around the room. Any old tripod will work great.
“He couldn't sign his name any faster than he could duck.”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear. You will RTFM, even if I have to shame you into doing it.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
post #2353 of 3216 Old 04-02-2015, 06:42 AM
Liked: 716
Well, my main listening position is on a bed lying down, so I only need about 6 to 12 inches off the surface of the bed.
I'm also considering a mini tripod since it wouldn't need an extension bar/arm.
I just don't want to use the box since reflections could be hurting YPAO's accuracy. It's a small box but it's still much bigger than the mic and the height is not an exact match to ear height.
post #2354 of 3216 Old 04-02-2015, 06:57 AM
Liked: 716
Would something like this work?
http://www.bestbuy.com/site/eforcity...d=mp1307076910
ChromeJob likes this.
post #2355 of 3216 Old 04-02-2015, 07:13 AM
ChromeJob's Avatar
Liked: 641
Ah, I see...
My favorite "tabletop" tripod is the UltraPod II. REI sells them, believe they're on Amazon, too. I think Jobi also sells a short tripod along with their smartphone tripod clip attachment, lemme see if I can find that. The UltraPod II is more versatile though IMHO. Pedco sells an Ultrapod Mini that might suit your need and budget, too.
Pedco UltraPod II Lightweight Camera Tripod https://www.amazon.com/dp/B000ANCPNM..._q8uhvb0DZDZ8Q
Joby JM2-01WW GripTight Micro Stand (Black) https://www.amazon.com/dp/B009GHYM0M..._H-uhvb0RRFVXH
The tripod and the clip should separate, the clip looks the same as the one I bought separately years ago. (I use the clip with, you guessed it, the UltraPod II.)
Yes, your suggestion would also work.
post #2356 of 3216 Old 04-02-2015, 07:25 AM
Liked: 716
I'd need a maximum height of at least 8 inches as that is how high my ears are from the bed surface.
post #2357 of 3216 Old 04-02-2015, 07:27 AM
ChromeJob's Avatar
Liked: 641
I don't think you need to be that precise, I'm sure YPAO isn't sensitive to a few inches difference.
I would buy the tripod if you can use it otherwise, if only just to get the mic on the bed, maybe use a short box ... some cereal boxes .... a thick pillow or two ... or lay there and hold it?
post #2358 of 3216 Old 04-02-2015, 07:29 AM
Liked: 716
How high do the two ones you linked to go?
post #2359 of 3216 Old 04-02-2015, 07:48 AM
ChromeJob's Avatar
Liked: 641
I'm not even going to answer. 2" - 4" either way is not going to effect YPAO IMHO.
Maybe you should just get the one from BB, do your measurement, then return it to BB.
// Posted from Tapatalk 3.2.1 for iOS - later versions are pfft //
post #2360 of 3216 Old 04-02-2015, 08:08 AM
Liked: 716
I'm probably over-thinking this, but could a few inches be more significant when the bed surface is so close to ear height? Normally, it's in a chair/couch when the seat and ear height are several feet apart.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
post #2361 of 3216 Old 04-02-2015, 08:11 AM
Liked: 716
and more importantly, what does the 20 refer to in 1/4"-20 threaded socket?
EDIT: never mind 1/4 inch, 20 TPI
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #2362 of 3216 Old 04-02-2015, 08:17 AM
Bond 007's Avatar
Liked: 2110
EDIT: never mind 1/4 inch, 20 mm
TPI use Google. It's your friend.
post #2363 of 3216 Old 04-02-2015, 08:18 AM
Bond 007's Avatar
Liked: 2110
No
post #2364 of 3216 Old 04-02-2015, 08:23 AM
Bond 007's Avatar
Liked: 2110
Tape the mic to a 12" ruler and pinch it in between your laptop and smartphone on the bed.
m. zillch likes this.
post #2365 of 3216 Old 04-02-2015, 08:30 AM
ChromeJob's Avatar
Liked: 641
Originally Posted by plasmapz80u View Post
i'm probably over-thinking this, ...t.
Yes.
post #2366 of 3216 Old 04-02-2015, 08:33 AM
Liked: 716
got this for $5 after using a rewards certificate:
http://www.bestbuy.com/site/sunpak-2...at328900050013
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #2367 of 3216 Old 04-02-2015, 11:18 AM
m. zillch's Avatar
Liked: 1285
1/4 20 bolts (or screws) can be bought in long lengths at hardware stores and then taped to heavy objects or build this sort of mount maybe:
Aiming an omnidirectional mic isn't all that important, getting the right height IS important especially since, for all I know, the hi frequency absorbency of the bed surface may differ greatly based on just a short change in distance.
post #2368 of 3216 Old 04-02-2015, 11:28 AM
Liked: 716
Originally Posted by m. zillch View Post
1/4 20 bolts (or screws) can be bought in long lengths at hardware stores and the taped to heavy objects or build this sort of mount maybe (if one doesn't want to drill):
Well, I got a 7.5 mini tripod and ear height is almost exactly 7.5 (8 was just a round figure) so I should be more than fine.
m. zillch and ChromeJob like this.
post #2369 of 3216 Old 04-02-2015, 11:29 AM
Liked: 716
* inches
post #2370 of 3216 Old 04-03-2015, 11:26 AM
ChromeJob's Avatar
Liked: 641
The Pedco UltraPod II puts the tip of the YPAO mic any from 6" to 8" high,[1] no big difference from the one you bought. Should work fine. If you need more height, I'd just put book(s) underneath. Or towels. I gather we want something sort of acoustically dead.
[1] You can vary the height a bit with the pivoting head, and playing with the legs a little.
a/v receiver , component cables , hdmi , optical audio , Yamaha , Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver , Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx V775wa 7 2 Channel Network Av Receiver
