The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
post #4861 of 12678 Old 01-12-2014, 04:31 PM
scientifix's Avatar
Originally Posted by jdsmoothie View Post
You can press and hold either the MOVIE or MUSIC buttons to get the Multi CH Stereo mode ....
Oh wow, didn't even think of the possibility of "press and hold" - instead went through every option in the menu but couldn't find it smile.gif
scientifix is offline
post #4862 of 12678 Old 01-12-2014, 07:52 PM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Hi guys, I just got this new TV (yeah!) and it's smart and it's got ARC, so I might as well use it. I have an X4000; the HDMI link is between the ARC output on the X4000 and the ARC input on the TV, so all is good cable-wise. But ARC doesn't seem to work. I made sure HDMI control is enabled on both the X4000 and the TV (while turning off any power on / power off control settings, I'm using a Harmony remote). Yet, still no ARC.
I don't see any other setting specific to ARC on the TV or on the AVR, and the manual doesn't have much to say about ARC (other than I may have to tell the TV to output audio through ARC). I've scoured both the TV and AVR menus and don't see anything else. However I wonder how it works on the AVR side. If the AVR is turned on, it will be set on a source right? What is the source when you want to do ARC? I see there is a TV Audio button on the remote but it doesn't seem to do anything.
Anybody knows what I'm doing wrong? Thanks for any hint.
neutro is offline
post #4863 of 12678 Old 01-12-2014, 08:08 PM
jdsmoothie's Avatar
Quoted: 12136 Post(s)
Liked: 5527
On page 1 of this thread, you'll find some very helpful posts #3-6 which will assist with operation of your X4000 to include the link below on the HDMI(ARC) feature ...
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_E4
jdsmoothie is online now
post #4864 of 12678 Old 01-12-2014, 08:50 PM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Thanks a lot for pointing out that link. At first sight it doesn't help much though. For now I just found out that I had hidden the "TV Audio" source before. So now I'm showing it again and can select it (the X4000 says "TV AUDIO"), and as per the manual, since HDMI control is enabled, it should then only come from ARC. But even then... no dice, ARC doesn't seem to work. I'll try posting on my TV's official owner's thread in case there's something that can be done on that side.
neutro is offline
post #4865 of 12678 Old 01-12-2014, 09:55 PM
Durden1011's Avatar
You'll hear audio from all 5 speakers and sub ... give it a try .. you tell me. smile.gif
Just an update on getting my receiver to play AAC 5.1 when the source is coming from my TV. After some testing it turns out it was an ARC problem. Switching to optical completely solved the problem and a few others at the same time. I don't know about anyone else or if this is just a problem with Samsung smart TV's perhaps, but the ARC function seemed to be very very clumsy with my x2000. Maybe it's just that my TV isn't able to interface with the receiver easily, but I would have to change audio format from pcm/dolby/dts every single time depending on the source, where as with the optical cable the best source is automatically selected, and AAC works now as well. It's very rare that I'll ever need to send an HD audio source from my TV so the optical cable should suffice, anything more than that will most likely be coming from a blu ray.
Durden1011 is offline
post #4866 of 12678 Old 01-13-2014, 06:24 AM
Iceblade's Avatar
Hey gang,
Quick question. I've got my AVR-X4000 connected via a wired connection to an 8-port network switch which is then connected to a wired Netgear R7000 router. I'm trying to figure out which of the various connections listed within my router is which component on my network but I see that most components have either NO device name, or some incomprehensible alphanumeric set of characters that do me no good in figuring out what it is. Does anyone here know how the AVR-X4000 shows up when connected in terms of device name? Also, is there a way to change the device name on the unit itself, if I don't like what it is (or it's blank)? Thanks!
Jeff
Iceblade is offline
post #4867 of 12678 Old 01-13-2014, 06:28 AM
almgren's Avatar
MIne shows up with the mac adress as name, without any colons.
0005CD37ADCF
and the manufacturer is Denon it also says.
There is in network setup a friendly name, but so far I have not seen it used anywhere.
Iceblade likes this.
almgren is offline
post #4868 of 12678 Old 01-13-2014, 07:06 AM
Morg81's Avatar
How to prevent Zones 2/3 from powering on when not using them
For those X4000 owners using the Denon remote that are having difficulty with Zones 2 or 3 powering on, yet not currently having any Zone 2/3 speakers connected, you can program the remote to only control the Main zone as shown on p. 208 in the Owner's manual and below ...
Hi all
I currently own a X4000 and I use both video HDMi outputs:
- Main HDMi output for my projector (BenQ W1070),
- Zone 2 HDMi output for my TV (Sony KDL-46EX501).
I also have two inputs:
- HDMI BD for a bluray player (Sony S4100)
- HDMI CLB/SAT for a TV box connected to Internet
In this setup the TV and the Projector are both located in the same room and are never used at the same time, therefore I do not need the "zone management" > when I use the remote I would like the X4000 to consider that changes are to be applyed for both Main and Zone 2 (source modification, volume etc.). Is is possible?
I already selected the "dual HDMi out" setting, but I still need, depending on the HDMi output in use, to select the "main" or "zone 2" button before doing anything with the remote.
Any idea?
Morg81 is offline
post #4869 of 12678 Old 01-13-2014, 07:10 AM
jdsmoothie's Avatar
Liked: 5527
Originally Posted by Iceblade View Post
Hey gang,
Jeff
The name should appear as "Denon AVR-X4000". As noted on p. 189 in your Owner's manual, this name can be changed.
post #4870 of 12678 Old 01-13-2014, 07:14 AM
jdsmoothie's Avatar
Liked: 5527
Originally Posted by Morg81 View Post
Hi all
Any idea?
Sure. Rather than using the Zone 2 HDMI output, you should be using the Monitor 2 HDMI output. smile.gif
post #4871 of 12678 Old 01-13-2014, 07:21 AM
Morg81's Avatar
Morg81 is offline
post #4872 of 12678 Old 01-13-2014, 08:10 AM
newfmp3's Avatar
Quoted: 273 Post(s)
Liked: 252
New owner here. Having issue with 720p content from SatTv, PC, xbox etc. Basically it's not scaling properly and the image is too big and going beyond the edges of the screen. 1080i is fine, 1080p is fine. Only way I can the image to fit properly is to turn the Denon's ip scaler on.
Any suggestions? besides running everything at 1080i
newfmp3 is offline
post #4873 of 12678 Old 01-13-2014, 09:12 AM
jdsmoothie's Avatar
Liked: 5527
You may want to check for an HDMI overscan setting on your TV as well.
post #4874 of 12678 Old 01-13-2014, 10:03 AM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
How much is getting cut off? Most 1080p displays will allow no overscan on 1080 input signals but will automatically engage 2-3% overscan on lower resolution inputs.
If letting the receiver scale to 1080p works then just do that.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4875 of 12678 Old 01-13-2014, 10:05 AM
Iceblade's Avatar
0005CD37ADCF
almgren,
EXACTLY! I figured that crazy HEX number was it, which in no way, shape or form matches what the user's manual says it should show up as. That's what was throwing me. Does this actually show up like it is supposed to for others?
Jeff
Iceblade is offline
post #4876 of 12678 Old 01-13-2014, 10:06 AM
Iceblade's Avatar
JD,
Please see my response above, as it matches almgren's experience, as well. Any ideas?
Jeff
Iceblade is offline
post #4877 of 12678 Old 01-13-2014, 10:11 AM
almgren's Avatar
JD,
Jeff
Actually I see it now. If you open Explorer in Windows and go to Network, there it shows up with friendly name. double click om it and your browser will go to the right IP adress.
almgren is offline
post #4878 of 12678 Old 01-13-2014, 10:18 AM
Iceblade's Avatar
Almgren,
I'm trying to do it from within the confines of the "attached devices" view of the Netgear router configuration. What Windows thinks isn't really important to me, as I'm trying to figure out what each item is that is currently connected via wired/wireless to my router. Thanks for the details on where you actually see this name, though. At least I now know that the HEX digits thing is the AVR, now.
Jeff
PS - Not sure which version of which version of Windows you are using, but that looks nothing like what I see in WinXP SP3.
Iceblade is offline
post #4879 of 12678 Old 01-13-2014, 03:32 PM
Emetw's Avatar
Liked: 37
Try turning the AVR off and unplug it for 10 minutes.
Will do, thanks!
Anthem MRX-500 - Vincent SAV-P200 - RAW Acoustics Lambda Plus arrays, Apex C II center - HT4 tower surrounds - CSS WR.30 sides - Rythmik FV15HP - Vizio XVT553SV - Xbox One - Xbox 360 - WD Live TV - QNAP TS212 NAS w/WD Red drives - APC H15BLK
Emetw is offline
post #4880 of 12678 Old 01-13-2014, 09:49 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 898
Almgren,
Jeff
Just turn them off one at a time, you'll figure it out.
ambesolman is online now
post #4881 of 12678 Old 01-14-2014, 03:26 AM
almgren's Avatar
Almgren,
But as I wrote,m you will get the IP adress that way, and then you can check that in your router. WHat I would do is then to assign a static IP to the Denon so you always have the same, that way any bookmarks will work for you from any device
almgren is offline
post #4882 of 12678 Old 01-14-2014, 07:19 AM
JoeBloggz's Avatar
Prospective Denon buyer here. I'm looking at the X2000 vs 2312CI. They are pretty much the same price on accessoriesforless(refurbs). Never bought a refurbed avr before. With regard to refurbished, is the main difference 1yr vs 3year warranty? Any other specifics I should be wary of when buying refurbished. I'm setting up a 3.1 system with a polk sub and bookshelves to be named later(looking at CA S30's, Wharfedale 10.1, etc) I know the X2000 is the newer model and I don't need the extra subwoofer out on the 2312. Do they both do a good job of video upscaling? How about sound?
Pioneer Pro111FD viewed from 7'------>Picture mode, ISF Day(calibrated by umr)
Sony PS4
JoeBloggz is offline
post #4883 of 12678 Old 01-14-2014, 07:50 AM
Iceblade's Avatar
Almgren,
I'm on WinXP SP3. I don't see anything like what that screenshot shows. Is there something akin to that for my OS or is that a Win7/Win8 thing?
Jeff
Iceblade is offline
post #4884 of 12678 Old 01-14-2014, 08:00 AM
almgren's Avatar
Almgren,
Jeff
Hm, I think yu coudl explore the network in XP to. You should get something. Or hook up your TV, go into SETUP and NETWORK and selct INFO, there is the IP adress
almgren is offline
post #4885 of 12678 Old 01-14-2014, 08:54 AM
Iceblade's Avatar
Sure, I can go in and check it out in the AVR. I just wanted to make sure:
1.) I wasn't missing something obvious in terms of the way that connected devices show up in my router/Windows
2.) I didn't do something wrong during setup that was causing the lack of device names.
For reference, the My Network Places in WinXP merely is listing my shared folders and mapped network drives... no actual devices. Also, the Network Connections only shows things like LAN Connection and 1394 connection, etc...
Anyway, thanks for trying.
Jeff
Iceblade is offline
post #4886 of 12678 Old 01-14-2014, 10:51 AM - Thread Starter
batpig's Avatar
Liked: 3420
FYI for all -- just noticed that Sound & Vision / HT Mag posted an E400 review, very favorable: http://www.soundandvision.com/content/denon-avr-e400-av-receiver
As is typical with recent models with the AD video chip with 4k scaling, video performance was excellent.
Setup Guide and FAQ
batpig is offline
post #4887 of 12678 Old 01-14-2014, 11:03 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
The video processor in my X2000 is better in ever way when compared to my Sony S5100 BD player, or my Samsung 60" UN60D6420 display. I let it do all of the processing with noticeable results on real world content, not just test patterns.
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is offline
post #4888 of 12678 Old 01-14-2014, 12:21 PM
emattias's Avatar
Quoted: 16 Post(s)
I have a couple of questions about the Denon receivers:
  1. Does it appear as an airplay destination when it is in standby mode? Or can it be configured to do so?
  2. If yes on previous question: Can I start “air playing” to it when in standby and it will automatically wake up and switch to airplay source, without me having to do it manually?
  3. Can you make it autostart and switch source when receiving signal from another source, like digital/optical in or HDMI?
  4. Can you show video from 1 HDMI port and at the same time play audio from airplay?
  5. Can you show video from 1 HDMI port and play audio from another HDMI port or an audio only port (digital in for example)?
  6. Can you turn it on from standby in the app?
If you know the answer to any of these questions I'd be very grateful for an answer! Thanks!
emattias is offline
post #4889 of 12678 Old 01-14-2014, 01:28 PM - Thread Starter
batpig's Avatar
Liked: 3420
1. Yes, there is an IP Control in standby setting
2. Yes
3. No, unless the HDMI CEC in the source device does it for you
4. Yes, any audio only source can be mixed with any HDMI video source
5. No, you can't mix two HDMI sources
6. Yes, if IP Control is set to on on standby then the app or browser can see it even when powered off
emattias likes this.
Setup Guide and FAQ
batpig is offline
post #4890 of 12678 Old 01-14-2014, 02:31 PM
jdsmoothie's Avatar
Liked: 5527
Review post #2 in each of the Denon 2012 and 2013 Owner's threads or just go to Denon's website to review the features of each model. Both use the same version of Audyssey MultEQ XT. Whether the AVR does a good job of upscaling depends on how good of a job the source or TV does as to whether you bypass the video processing in the AVR or not.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
