The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
Old 02-11-2014, 07:35 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Originally Posted by krips View Post
To get the Dolby and DTS Neo for the DVD you are playing, you don't need to set PS3 to PCM, rather set it to Bitstream. Now when you play a DVD or any other source that doesn't have multi-channel audio, if you hold 'Movie' 'Music' or 'Game' for few seconds you'll see the other options like DTS Neo, Dolby PL II etc.
Just a caveat though. If the PS3 is one of the older, "fat" versions, the HDMI board cannot bitstream DTS Master Audio nor Dolby TrueHD. So if you want to get DTS-MA or TrueHD sound, you actually *have* to set the fat PS3 to PCM, as it is able to decode the formats and send the decoded stream as PCM on the HDMI link. The AVR then displays MULTI CH IN.
neutro is offline
Old 02-11-2014, 07:44 AM
retro124's Avatar
Quoted: 1078 Post(s)
Liked: 782
Originally Posted by jdsmoothie View Post
Correct. The X4000 can power up to 7CH and if you add an external 2CH amp you can connect up to 9 speakers in the main zone. As noted in the image below, you have the option of powering 1 of 4 different sets of speakers.
If powering the Front (FL/FR) speakers you'll likely want a 200W+ amp, while if powering any of the remaining sets of speakers a 50W amp like the one below should be plenty. Connect the amp to the speaker pre-outs for the set you select and run Audyssey again to EQ the new speakers.
http://www.amazon.com/AudioSource-AMP-100-Stereo-Power-Amplifier/dp/B00026BQJ6
Thanks, so do you think Emotiva xpa-3 will be ok for my front RF-82II and RC-62II because they are 150W and Emotiva is 3x200W. Do I need to be worry about demage speakers?
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is online now
Old 02-11-2014, 09:15 AM
tpyke's Avatar
Hi. I have a slight problem with my X3000's setup....
I have a 5.1 setup for zone 1 and an amp hooked up to the zone 2 RCA outputs. I have a TV and a PS3 hooked up with HDMI. I can get the PS3's sound to come out of Zone1 and 2, but the TV only comes out of Zone 1. The sound from the TV is brought to the X3000 through the HDMI ARC.
Is there a setting I need to change to get the TV's sound to the Zone 2 speakers?
tpyke is offline
Old 02-11-2014, 09:37 AM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
It doesn't work like that. You are unlikely to ever use anything close to 200 watts. Not with super efficient Klipsch speakers.
The speaker rating is just a recommended maximum continuous power that it can handle before you risk damage. A 200w amp doesn't out out 200w at all times, you draw what you need which in most cases is 10 watts or less.
It's like the speed rating on a tire -- if you put a tire rated to 130mph on a Porsche that can go 170mph, the tire isn't going to blow up when you are cruising at 65mph. In the real world you aren't likely to ever test the theoretical limits.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 02-11-2014, 10:07 AM
Randy Ta's Avatar
I have the older "FAT" PS3 so that is why I have it set to PCM.
Randy Ta is offline
Old 02-11-2014, 10:21 AM
retro124's Avatar
Liked: 782
OH ok thanks for explaining so what to use for front speakers and center to run them the best they can do and be able use receiver for rest to end up having 9.2 set up?
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 10:38 AM - Thread Starter
batpig's Avatar
Liked: 3415
The Emo would work great, it's a very popular option. I wasn't trying to tell you not to get it, just that if you do get it you don't have to worry about damaging anything.
Setup Guide and FAQ
batpig is offline
Old 02-11-2014, 11:00 AM
Happy Tom's Avatar
Purchased and set up new X-4000 a few days ago and have figured most of it out, but have a question about how to playback FLAC 24/96 files over the network.
By way of background, it is hooked up to a LAN with a PC that has both iTunes with latest updates and Windows Media Player vers.11.0.5721.5280. I also have Apple TV. My music library is rather large with approx 60,000 songs, most are MP3 and AAC format.  I have started collecting some High Res FLAC just to get my feet wet with the new format and test for improvement in SQ.
There is no problem accessing MP3 and AAC files with airplay or Apple TV.  (in fact, Apple TV UI is fastest and most flexible to access music files, best UI of all current options)  I have also been able to access most files through network, seems like it is using Widows Media Player to access files on PC.  This methods seems much slower and difficult to use compared to Apple TV.
What I have not been able to do so far is find and play my FLAC files using the Media Server function found on the Network input of the X-4000.  I have the library of both players (WMP and iTunes) pointed to the folder that contains these files.  Is this because neither player supports the FLAC format?  Is there another player that could be downloaded to my PC that would play FLAC files on my computer and pass them through the LAN to the X-4000?
I have played FLAC 24/96 files on X-4000 using a thumb drive connected to the USB port, they sounded great.  As collection grows, this will not be the most practical method and would like to use the LAN if possible.
Also, I wanted to thank the regular contributors to this forum for ongoing great advise and comments.  Your input helped me decide to purchase this unit and provided great insight that has helped with set up, use and enjoyment of this product.
Happy Tom is offline
Old 02-11-2014, 11:01 AM
retro124's Avatar
Liked: 782
Oh ok so do you think is better to get Emotiva 5x200W or 3x200W will be good? And maybe dumb question how to connect emotiva to Denon receiver?
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 11:45 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
Go to blue jeans cable and get some LC-1 analog cables made to your required lengths to go from the preout rca connections on the denon to the rca connections on the amp. Then go to radio shack and get a male to male mono cable for the 12v trigger.
http://www.radioshack.com/product/index.jsp?productId=2102950
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
Old 02-11-2014, 12:01 PM - Thread Starter
batpig's Avatar
Liked: 3415
Since you like the ATV interface (as you should) why not convert FLAC to ALAC and then just use iTunes for everything? Makes it simpler, all your music is in one place, and you get the everything works closed ecosystem of Apple / Airplay
ambesolman likes this.
Setup Guide and FAQ
batpig is offline
Old 02-11-2014, 12:10 PM
maynerd's Avatar
Do you care more about features or sound quality? The X1000 has MultEQ XT vs. the rudimentary 2EQ in the Onkyo, which doesn't even EQ the sub. If you just want more features, go with the Onk. If you want superior sound quality and don't need to go beyond 5 channels, then get the X1000.
Thanks for the info.
So...anyone wanna buy an Onkyo? LOL
maynerd is offline
Old 02-11-2014, 12:26 PM
retro124's Avatar
Liked: 782
ok so I will need for Emotiva 3x200W 3 LC-1 wires and go from denon precut L/R front and center and then go on Emotiva to unbalanced inputs correct? Sorry i have no experience with it. :)  and 12V trigger is for turn on emotiva with receiver right?
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 12:36 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
Yepp.
Old 02-11-2014, 01:05 PM
retro124's Avatar
Liked: 782
Yepp.
Thanks for help man. I'm thinking to get first generation of Emotiva xpa-3 from used market will see how much they are or maybe new one second generation from Emotiva web. Just need to find out what is different between them.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 01:33 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
The XPA-3 is what I use with my X4000 with no issues.
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
Old 02-11-2014, 02:40 PM
Randy Ta's Avatar
I changed my PS3 back to bitstream but on a standard DVD that is Dolby, I still only get stereo. Holding movie on the remote gives me options to play stereo thru all speakers but not Dolby. I have played a DVD that is DTS and that shows up and seems to work fine. Dolby used to work fine on my 3808.
Thanks for your help.
Randy Ta is offline
Old 02-11-2014, 02:43 PM
Happy Tom's Avatar
There is a blinding flash of the obvious.  Can you recommend a program to do so?
Old 02-11-2014, 02:51 PM - Thread Starter
batpig's Avatar
Liked: 3415
The receiver can't control the source. If it's getting a stereo input, that's what it's getting. Holding down the MOVIE button can change modes to matrix stereo to 5.1 (using Pro Logic or the like) but it won't change the INPUT SIGNAL itself. That can only be controlled by the source device itself -- so in other words, look upstread at the PS3 settings.
Setup Guide and FAQ
batpig is offline
Old 02-11-2014, 02:54 PM - Thread Starter
batpig's Avatar
Liked: 3415
I've never done it personally, but this link will be both snarky and helpful: http://lmgtfy.com/?q=convert+flac+to+apple+lossless
D Bone and ambesolman like this.
Setup Guide and FAQ
batpig is offline
Old 02-11-2014, 03:00 PM
retro124's Avatar
Liked: 782
I was just worry about damage speakers but looks like it will be just fine, thanks for your answer. Can you listen different when you have your HT with and without Emotiva?
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 03:04 PM
Selden Ball's Avatar
Quoted: 3055 Post(s)
Liked: 1494
Don't forget, though, that the amps in your new receiver will work fine, too. External amps are only needed when the amps in the receiver are inadequate. This is more often the case for inefficient speakers, not for Klipsch speakers. But an external amp will work fine, too.
Whenever you change your room/speaker/amp configuration, you need to run Audyssey again. After you've run the calibration for the new configuration, the same volume control settings will produce the same sound levels as you heard before at your primary listening position, which is the first microphone position.
Selden
Selden Ball is offline
Old 02-11-2014, 03:06 PM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 580
Indeed -- I suspect you should browse the audio parameters on the PS3 and set it to deal with all multichannel formats. I don't remember the details but it looks like your PS3 currently only outputs stereo. You can easily check what the AVR receives with the info button on the remote.
neutro is offline
Old 02-11-2014, 03:12 PM
retro124's Avatar
Liked: 782
Ok, reason why i want that is I'm thinking to do 9.2 set up so I need extra amps for some speakers I just don't know if do front 3 and buy ore expensive amps or do just surrounds and buy cheaper one.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
Old 02-11-2014, 04:54 PM
Randy Ta's Avatar
Thanks for all your help guys. Problem solved and not equipment. The two Standard DVD's that I was using to test with listed audio options as Dolby or Surround 5.1. I thought that the first one listed was always the default and produced the best audio so I have been trying to get it to produce 5.1 Dolby Surround. I just tried the Surround 5.1 option and Dolby shows up in the AVR window. Not what I was expecting but it works and produces Dolby 5.1 Surround audio. At least now I have a better understanding how things work. and maybe not as sure of what I used to do.
Thanks again for your help.
Randy
Randy Ta is offline
Old 02-11-2014, 04:55 PM
krips's Avatar
Quoted: 140 Post(s)
Liked: 107
Install the open codecs from http://xiph.org/dshow/
I too was having the same issue. I could play FLAC from my Nexus 5 using Bubblesoft UnPN, but won't from WMP. Finally did a search and found the solution. Also, for more detailed instructions and other functionality read the instructions from this website: http://www.codeemporium.com/2009/11/26/convincing-flac-files-to-play-in-windows-media-player-12/
Sony XBR55HX929 / LG OLED55C6P
Denon x4000 / PS3 Slim / BDP-S6200 / OPPO UDP-203
Roku 3 / WD TV Live /Chromecast / Fire TV stick
Speakers - DT PM1000 / PC2000 / Sony HTNT5
Sub - Power Sound Audio S1500
krips is offline
Old 02-11-2014, 05:06 PM
Liked: 1494
My personal recommendation is to just get the amps needed for the surround channels. While additional amps for the fronts probably won't hurt, they won't produce any better sound. I write "probably" because some models of Emotive amps have very high gain. When those amps are used with highly efficient Klipsch speakers, people have found that the total gain is more than Audyssey can cope with. When that happens, attenuators have to be inserted between the AVR and the amps to bring the signal down to a level that can be calibrated.
Selden
Old 02-11-2014, 05:41 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2980
I've found the SQ from my outlaw amp with my speakers sound great, especially when I have it cranked, but Outlaw is a tad bit pricier than emotiva. I did read about the gain thing.
Old 02-11-2014, 06:18 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
I purchased the amp when I had my 4310 and it is for future expansion of my system. I will not say it sounds better or worse with the amp, but I do like it.
My set up
jnnt29 is offline
Old 02-11-2014, 06:51 PM
BombaytheGreat's Avatar
E300 - Troubleshooting help needed
Owner of an open box E300.  I can't say that it was not powered on, but I am pretty certain that the remote, mic, antennas, and manual were not opened.
What I am trying to accomplish:  Run my tv audio to the E300.  The TV is a LG 42LA6200 receiving a broadcast signal (via rabbit ears antenna).
Connection:  HDMI (arc) from the TV to HDMI (arc) on the E300.  No other connections.
Issue:  Unable to receive TV audio thru the E300.
Before I go into settings, I will mention a few things that I have tried and then see if anyone has a "simple" answer.  If not, I can walk thru settings.
Since I was unable to receive audio from the TV, I decided to do a few things:
- walked thru the setup settings to see if the E300 would auto-correct or configure for me.  Ran Audyssey and heard tones thru the speakers, etc.
- Hooked up FM antenna to E300 and tuned to a channel to ensure I could get sound thru the speakers. I could.
- connected my BD player to the E300 BD HDMI input and then HDMI (arc) Out to TV HDMI (arc).  I was able to get video on TV and audio thru the E300.  I did this primarily to ensure that the HDMI cable I was using (for the first time) was good.  The hdmi cable does not appear to be the issue.
With that said, does anyone have any simple fixes to try or do I need to go into settings detail?
Also, is an optical audio cable (toslink) required, or do I understand correctly that HDMI (via the arc input/output) should provide both video and audio (with need for the toslink)?
Eager for your help
Rob
retro124 likes this.
BombaytheGreat is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
