The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 2677Likes
post #5671 of 12887 Old 02-18-2014, 10:09 AM
tedpolzin's Avatar
Ok I think I know the answer to this so I am sorry if its been answered 1000x times.
Can I have two different sources for HDMI going to zone 1 and zone 2? I assume to have 5.1 out of zone 2 I would need another receiver to process it but can I use this for a 6 in and 2 out video matrix?
Also I wouldnt use the amps for the primary zone 1. Can I use them for anything else?
Ted
tedpolzin is offline
post #5672 of 12887 Old 02-18-2014, 10:15 AM - Thread Starter
batpig's Avatar
Quoted: 3720 Post(s)
Liked: 3592
Yes, assuming you are talking about the X3000/X4000 which have Zone 2 HDMI. It is a 6 in / 2 out matrix for the 6 rear HDMI inputs, with the main zone also having audio/video processing (the 2nd zone is just passthrough). This is noted in the very first post of the thread.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5673 of 12887 Old 02-18-2014, 10:29 AM
tedpolzin's Avatar
Thought so but last time I purchased a unit a few years back this was far off. Just wanted to make sure my understanding of this was correct before I went and purchased one. I really only have need for two output zones so this goes a long way to making video distribution to those zones cheap.
Ted
post #5674 of 12887 Old 02-18-2014, 01:37 PM
jdsmoothie's Avatar
Quoted: 15322 Post(s)
Liked: 7475
Ted
Referring to the X4000 with main zone pre-outs that you would be using, the unused Surr Back speaker posts could be used for a Zone 3.
jdsmoothie is offline
post #5675 of 12887 Old 02-18-2014, 02:57 PM
pbarach's Avatar
Quoted: 370 Post(s)
Liked: 221
Originally Posted by seggers View Post
One more dumb question, when you run the unit for a number of hours, does it get hot to the touch, along the top, and if so where? The reason I ask is that the X4000 won't be in a rack and I'd like to get a decent fan and place it correctly.
It turns out my 805's fan came from that lot too. I'll be sending that off though as I hope a newer one is quieter.
Seggers
My X4000 is sitting on top of an open set of component shelves, and it operates way cooler than my 4310 did in the same spot. It has never gotten hot to the touch. It did have an odd "electronics" smell for a couple of days when I first unpacked it, but that disappeared and hasn't returned.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #5676 of 12887 Old 02-18-2014, 06:31 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Given these units are now programmable via Ethernet, is there a program that can download the current configuration of one for backup and possible reloading later?
I'm likewise curious about the possibility of using that to effect ways to handle loading specific configurations. Instead of taking the old route of playing the setting commands one at a time, just loading a config 'in bulk'.
Possible?
wkearney99 is offline
post #5677 of 12887 Old 02-18-2014, 07:16 PM
royalkilla408's Avatar
Anyone downloading the firmware for X4000? Mine is updating right now. Can someone please post the what the update contains? Thanks!
royalkilla408 is offline
post #5678 of 12887 Old 02-18-2014, 07:35 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4042
I imagine jd smoothie with have the ins on the update.
gadgtfreek is offline
post #5679 of 12887 Old 02-18-2014, 08:14 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
iirc jd had updated on page one its to remedy Netflix Dolby Digital+ playback. I don't see anything there now.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
post #5680 of 12887 Old 02-18-2014, 08:15 PM
SeattleAl's Avatar
Mine updated successfully, New version is 5530-9656-1603.
The volume control works much better.
The update says it improves stability. We'll see.
SeattleAl is offline
post #5681 of 12887 Old 02-18-2014, 08:26 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4042
I'll let you lab rats play with it for a week or two LOL
Keenan likes this.
post #5682 of 12887 Old 02-18-2014, 08:37 PM
tvuong's Avatar
Quoted: 1790 Post(s)
Liked: 1086
What do you mean by the volume control works much better? Can you elaborate?
tvuong is offline
post #5683 of 12887 Old 02-18-2014, 09:29 PM
SeattleAl's Avatar
The volume control was too fast before, so you had to tap the volume control or you would zip way past your desired setting.
Now, it changes a bit slower, so you can hold down the volume control and nail your desired setting a lot easier.
post #5684 of 12887 Old 02-18-2014, 10:34 PM
tvuong's Avatar
Liked: 1086
^^ thanks. Any other improvement?
tvuong is offline
post #5685 of 12887 Old 02-18-2014, 11:19 PM
pasisti's Avatar
I just moved and I've then had a problem with my X1000 receiver. The DynEQ and DynVol settings reset to "On (0db)" and "Medium" when the receiver has been powered off for a while. I keep them both "off" otherwise. Nothing else happens, so all the other settings remain untouched. If I just switch the power off and on again, I can't reproduce the problem, but after every night or after coming back home I need to adjust the settings. When I moved, I didn't change any settings besides running audyssey. No one else could've messed with the settings, either. Any ideas or suggestions?
pasisti is offline
post #5686 of 12887 Old 02-19-2014, 04:00 AM
jdsmoothie's Avatar
Liked: 7475
Possible?
Yes. You can use the Web Control feature to SAVE and the LOAD the configuration. Refer to the posts below for more info ....
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_E9
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134212
post #5687 of 12887 Old 02-19-2014, 04:01 AM
jdsmoothie's Avatar
Liked: 7475
Are you using a Quick Select perhaps to power on the AVR. If yes, you'll want to rememorize the Quick Select with thes settings set to OFF.
post #5688 of 12887 Old 02-19-2014, 04:31 AM
carminepesce's Avatar
Quoted: 49 Post(s)
Liked: 44
Hoping they update firmware to correct this on X1000 as well....Volume control is def way too fast....
Panasonic 50" ST50 Plasma
Outlaw Model 5000 Amp
Yamaha CX-A 5000 Pre/Pro
Oppo BDP-103D Bluray player
SVS PB-1000 Sub w/DSpeaker Anti-Mode 8033s ii
SVS Prime System
carminepesce is offline
post #5689 of 12887 Old 02-19-2014, 06:37 AM
alspoll's Avatar
All,
Sorry if this has been asked before, but I have a quick question regarding HDMI output for Zone 2 on the X4000.
I know for zone 1, the receiver does not need to be on to pass through the hdmi signal. Is this the same for zone 2 or does the receiver need to be on to pass the HDMI signal out?
TIA,
AL
alspoll is offline
post #5690 of 12887 Old 02-19-2014, 06:56 AM
Happy Tom's Avatar
What Happened to Denon Radio/V-Tuner?
I did a firmware upgrade to receiver last night, now all of these presets are gone.  I can not even get to V-tuner in the internet
Happy Tom is offline
post #5691 of 12887 Old 02-19-2014, 07:00 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 585
No idea... Well thanks for the warning... I'll postpone the firmware update on my end rolleyes.gif
RayWK likes this.
neutro is offline
post #5692 of 12887 Old 02-19-2014, 07:17 AM
Happy Tom's Avatar
Sorry, this is related to a X-4000. Thanks
post #5693 of 12887 Old 02-19-2014, 07:29 AM
SeattleAl's Avatar
It's working on mine.
I had to use Google Chrome to use the vTuner website because it is having a problem with cookies in IE.
post #5694 of 12887 Old 02-19-2014, 07:55 AM
Happy Tom's Avatar
"GUI upgrade" was on the display during the last half of the update.  The icons contained in the setup menu are much larger.
post #5695 of 12887 Old 02-19-2014, 08:44 AM
mpotter's Avatar
I just looked at the firmware section on page 1. The most recent firmware listed for the X4000 is dated 7/18/2013. I know a firmware was just released which has not been listed yet, but is this correct? Am I looking in the right place? I know some new firmwares have come out since July!
Also, a few pages back, someone said that jd posted on page 1 that a new firmware was expected for the X4000 on Feb. 20th. Again, I'm not seeing this on my end.
Sorry if this is a dumb question.
mpotter is offline
post #5696 of 12887 Old 02-19-2014, 09:24 AM - Thread Starter
batpig's Avatar
Liked: 3592
Originally Posted by alspoll View Post
All,
TIA,
AL
Zone 2 needs to be powered on, the Zone 2 output is a powered matrix that allows source switching, unlike the passive standby passthrough you get in main zone which is just a simple repeater and doesn't allow source switching.
Setup Guide and FAQ
batpig is offline
post #5697 of 12887 Old 02-19-2014, 10:15 AM
alspoll's Avatar
Thank you for confirming.
alspoll is offline
post #5698 of 12887 Old 02-19-2014, 11:11 AM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Originally Posted by starbark View Post
I have a question on multiroom and Airplay I'm hoping to get some help with. I tried searching but I was not able to find an answer.
I have an AVR-X4000 which has its zone 2 pre-outs connected to a second receiver that powers speakers in other rooms. The problem I have is when using the AVR-X4000 in network play mode. The volume control in the Apple Remote app (or any other iTunes remote app) only affects the main volume, not the volume that is sent to the pre-outs for zone 2. This is not the case if I use an XBMC player as the Airplay source (the volume control on the app also affect pre-outs.) Is there a way to change this behavior for network?
I looked through the receiver settings but couldn't see an obvious one. Seems like a weird limitation since the AVR-X4000 can change the pre-out output volume. Any comments greatly appreciated!
I use the DeRemote app (iOS). Does pretty much all I want it to, even control the zone volumes independently 😉
tboe77 likes this.
ambesolman is online now
post #5699 of 12887 Old 02-19-2014, 03:58 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Any comments on the IR sensitivity of the X3000? I'm finding mine has a very narrow angle in which it'll detect IR signals. Is this a known design issue? Or am I dealing with the possibility the IR LED inside the front isn't well aligned?
Likewise, what about the E300? I haven't tried that one yet but I'm debating how to install the gear above a TV. I've a thread for that here:
http://www.avsforum.com/t/1518645/shelving-for-gear-with-tv-up-in-corner
If I point the face of the E300 toward the most-used position it'll leave the side and back cabling visible from the entry door. If I turn the gear to hide the wires then I'm concerned the IR won't work effectively.
Short of going to universal remotes and IR emitters (a step I do not want to take at this time) is there a reasonably simple way to improve the IR detection field angle?
post #5700 of 12887 Old 02-19-2014, 04:05 PM
HTScotty's Avatar
As much as I hate to say it, I think it's a design flaw. I had the x3000 briefly before trading it back to the vendor for the x4000. (I wanted XT32, and I'm SO glad I went with it) The 4000 does not exhibit any of the "narrow angle" IR issues that I encountered with the x3000. I had to almost point my Harmony directly at it for it to work sometimes. The 4000 doesn't do that at all and works as well as my avr-888 did. I considered emitters as well, but because of the proximity of the remote to the avr itself, I didn't want false signals or even double signals to get to the x3000.
HTScotty is offline
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
