The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 2677Likes
post #5941 of 12891 Old 03-03-2014, 06:28 AM
neutro's Avatar
Quoted: 209 Post(s)
Liked: 586
Originally Posted by William K View Post
It sounds like it might be a lot easier than continuously adding albums to WMP. There is no loss in sound quality right? I usually play FLAC files.
Not sure if you got a reply on this already, but... No, using UPnP/DLNA streaming doesn't induce any sound quality loss as the original file is sent to the media renderer (in our case -- the AVR itself). So when you're selecting a FLAC file, the FLAC file is sent to the AVR. Some DLNA media servers can also do on-the-fly transcoding but this is not required not the norm.
As for using BubbleUPnP -- it can't be a WMP replacement as it only runs on Android. If you want to try other DLNA servers or control points on Windows, there are many good choices. But I like Serviio and foobar2000 myself.
neutro is offline
post #5942 of 12891 Old 03-03-2014, 06:47 AM - Thread Starter
batpig's Avatar
Quoted: 3726 Post(s)
Liked: 3603
Originally Posted by seggers View Post
I must be being extra thick this morning as both of those replies were as clear as mud....
The Denon is currently on about 50. So where do I set it to 0?
Seggers
Sorry, reference is 0 on the relative scale and 80 on the absolute scale.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5943 of 12891 Old 03-03-2014, 12:02 PM
sat4all's Avatar
Hi guys,
Well, i'm plaining to get one of the 4k sets line up. Will my x2000 do 4k 60hz passthrough?
sat4all is offline
post #5944 of 12891 Old 03-03-2014, 12:33 PM
Selden Ball's Avatar
Quoted: 3498 Post(s)
Liked: 1766
Originally Posted by sat4all View Post
Hi guys,
No.
It will do 4k @30Hz, though.
4k@60Hz requires HDMI v2.0, which requires new HDMI chips.
sat4all likes this.
Selden
Selden Ball is offline
post #5945 of 12891 Old 03-03-2014, 03:04 PM
William K's Avatar
There is a BubbleUpnp download that I installed on my Windows 7laptop and uses "Linn Kinsky" software as an interface. I may be getting a little off topic in this forum but here is the link, look under Download and installation wink.gif
http://www.bubblesoftapps.com/bubbleupnpserver/
I'm going to have a look at Foobar2000 it may be simpler for me, I'll see
William K is offline
post #5946 of 12891 Old 03-03-2014, 05:11 PM
jnnt29's Avatar
Quoted: 120 Post(s)
Liked: 133
I was able to do the firmware update today by running a 50 foot Cat5 wire from my FIOS router directly to my X4000, prior to that my unit would get caught in loop and never update. I have a new issue / question. I have Windows 8.1 and do not see the save / load buttons and I am not able to save the profile. Does anyone have a solution to this? I was unable to find an answer to this in the thread. Thanks JT
My set up
Marantz SR-7008, Emotiva XPA-3
Sony UBP-X800 Ultra 4K Blu Ray Player, Harmony Ultimate Remote
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is online now
post #5947 of 12891 Old 03-03-2014, 05:16 PM
jdsmoothie's Avatar
Quoted: 15356 Post(s)
Liked: 7508
Posts #3-#6 on page 1 of this thread provide some very helpful setup and troubleshooting tips, including post #4 which directly answers your question.
jdsmoothie is offline
post #5948 of 12891 Old 03-03-2014, 05:32 PM
jnnt29's Avatar
Quoted: 120 Post(s)
Liked: 133
Thank you very much jdsmoothie I am now able to see the Save-Load buttons on the web app. Now to do the save around the families viewing schedule. Thanks again. JT
My set up
post #5949 of 12891 Old 03-03-2014, 05:43 PM
jdsmoothie's Avatar
Liked: 7508
post #5950 of 12891 Old 03-03-2014, 05:50 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Mine's connected through two wired switched before it gets to the FIOS Actiontec router. One switch is in the cabinet with it, the other one's back at the wiring panel and then it connects to the switch. But no powerline or wireless bridging in-between. It updated just fine.
wkearney99 is offline
post #5951 of 12891 Old 03-03-2014, 06:04 PM
jnnt29's Avatar
Quoted: 120 Post(s)
Liked: 133
That's exactly how mine is setup as well, but it would never update. I'm glad that the direct connection worked and the unit was finally updated. Thanks for the responce
My set up
post #5952 of 12891 Old 03-03-2014, 06:27 PM
gnphiker's Avatar
Got my X2000 in today and mostly setup. Sound Quality is noticeably improved over my Sony STR DN1000. I'm hearing much better low level sounds and vastly improved Bass management. Never could get the Sony to sound quite right to my liking.
Outta curiosity what volume level do y'all listen to an action filled DB at? Seems 75 ~ 80 is a good spot. Oddly with my Sony it couldn't go past 45 it seemed.
gnphiker is offline
post #5953 of 12891 Old 03-03-2014, 07:16 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
2. SAVE/LOAD procedure - Due to the use of browsers other than Internet Explorer for the SAVE/LOAD feature possibly being unstable, Denon removed their use in the Denon "X" series models; however, if you prefer to give them a try, forum member enricoclaudio reported that you can use either Firefox or Safari by entering the following URL into either browser window....http://192.168.X.X/SETUP/OTHERS/f_others.asp replacing the "X's" in the IP address with your own AVR's IP address.
Anyone actually tried saving from an E300? I just did, using Chromium, and the resulting config.dat file is 336k of nothing but zero hex characters!
So I tried from my X3000, this time using IE, and got the same result. The file is nothing but zero hex characters inside. No apparent data!
post #5954 of 12891 Old 03-03-2014, 08:03 PM
D Bone's Avatar
Quoted: 297 Post(s)
Liked: 377
Most of us use the relative THX volume (0db is reference level, and anything lower than reference shows as a negative number like -27db for example) I listen to -12db to -15db for blu-rays, and DirecTV is all over the place from -8db to -25db. You can change the setting by going to Settings > Audio > Volume.
gnphiker likes this.
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT Flat / DEQ OFF~ Power Sound Audio XV15
D Bone is offline
post #5955 of 12891 Old 03-03-2014, 08:51 PM
gnphiker's Avatar
Thanks, I'll give that a geaux tomorrow!
D Bone likes this.
gnphiker is offline
post #5956 of 12891 Old 03-03-2014, 10:12 PM
jwells222's Avatar
I have an X4000 receiver, which has Record Out functionality using "Media Player" for composite video/audio out. Is there anyway to directly or indirectly gain Record Out functionality for component video/audio out?
jwells222 is offline
post #5957 of 12891 Old 03-04-2014, 12:02 AM
McStyvie's Avatar
Liked: 78
Am really hankering for an x4000 but the CFO has told me I need to wait at least a month.
So, may just be worth waiting for the next models. How does Denon go about pricing the successors? Will it be roughly the same price?
Besides Hdmi 2.0 (which I don't need yet, but who knows in five years maybe?), what else is to be added? Any ideas?
McStyvie
McStyvie is offline
post #5958 of 12891 Old 03-04-2014, 07:03 AM
pieandchips's Avatar
Liked: 175
Originally Posted by McStyvie View Post
...CFO...
pieandchips is offline
post #5959 of 12891 Old 03-04-2014, 08:03 AM - Thread Starter
batpig's Avatar
Liked: 3603
McStyvie
Generally yes pricing is relatively stable at the same model tier year to year.
We will know more in a few weeks when Denon announces the new lineup.
McStyvie likes this.
Setup Guide and FAQ
batpig is offline
post #5960 of 12891 Old 03-04-2014, 08:04 AM - Thread Starter
batpig's Avatar
Liked: 3603
The X4000 has component video output but note that there is no cross conversion of other formats to analog output. So it would have to be component in to get component out.
Setup Guide and FAQ
batpig is offline
post #5961 of 12891 Old 03-04-2014, 09:37 AM
jwells222's Avatar
Is the same true for Rec Out function using Media Player composite output....that the source has to be composite?
Or is the limitation you describe above just for component video out?
post #5962 of 12891 Old 03-04-2014, 11:23 AM
philz662's Avatar
Anyone having E400 Dolby Digital sound drops running with Directv HR24 DVR ?
Display : Panasonic 60ST60
Blu-Ray : Sony BDP S5100
HD-DVR : Directv HR24/100
AVR : Pioneer VSX-1020-K 7.1
Speakers : Polk RM6750 5.1
Center Speaker : Polk TL2
philz662 is offline
post #5963 of 12891 Old 03-04-2014, 04:02 PM
jdsmoothie's Avatar
Liked: 7508
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq#user_E9
post #5964 of 12891 Old 03-04-2014, 04:10 PM
jdsmoothie's Avatar
Liked: 7508
Both .....
post #5965 of 12891 Old 03-04-2014, 07:01 PM
jwells222's Avatar
Both .....
So, I cannot record onto my VHS player any signals that are coming into the X4000 other than those coming in from a composite source? Is this true of most AV receivers? What about Aventage?
post #5966 of 12891 Old 03-05-2014, 05:13 AM
gnphiker's Avatar
I like this much better. The Blu-ray's passing DTS HD Master around -15db sound great. Again I'm very impressed with the sound quality. Watched the new A&E show Those Who Kill, DD 5.1 via Comcast and never before have I heard the low level detail that I was getting out of the Sony STR-DN1000.
D Bone likes this.
gnphiker is offline
post #5967 of 12891 Old 03-05-2014, 05:35 AM
tezster's Avatar
Quoted: 517 Post(s)
Liked: 401
Anyone know if there's a new firmware coming for the X2000? I'm hoping it'll fix my issue with low volume via Network sources without having to send the unit off for repair.
tezster is online now
post #5968 of 12891 Old 03-05-2014, 05:53 AM
jdsmoothie's Avatar
Liked: 7508
Yup. Either today or tomorrow. Per post #4 in this thread it will include the fix for the issue with the Netflix DD+ center channel audio issue as well as additional fixes to be posted in post #6 of this thread.
tezster likes this.
post #5969 of 12891 Old 03-05-2014, 08:00 AM
Teremei's Avatar
Quoted: 540 Post(s)
Liked: 231
is it just the x4000 or is anything with that much wattage just gonna run pretty hot? Compared to my 1712 it runs quite a bit hotter, and gets hotter quicker.
Aside from cost, lol. That's about the only thing I can complain about on the x4000. It runs hot and really should have a fan built in. Any hope the next model with xt32 might be built a bit better?
Upstairs Living Room - LG 65EG9600: Klipsch R-20B Soundbar
Basement - Sony 75x940d: Klipsch Reference series II speakers, 2 subwoofers, Denon x4000
Teremei is offline
post #5970 of 12891 Old 03-05-2014, 08:45 AM - Thread Starter
batpig's Avatar
Liked: 3603
It's actually probably the additional processing chips. IIRC the X4000 has an additional DSP chip for audio processing and it also has a lot of video processing (conversion and scaling chips) that the 1712 lacks.
That said I don't think my X4000 runs significantly hotter than any other units I've had in the same spot.
Setup Guide and FAQ
batpig is offline
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
