The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 220 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
post #6571 of 12678 Old 03-31-2014, 09:17 AM
jdsmoothie's Avatar
Quoted: 12106 Post(s)
Liked: 5509
As I said ... all of the mics issued from 2008 onward are interchangeable for any Denon model from 2008 thru to the current 2013 models.
jdsmoothie is offline
post #6572 of 12678 Old 03-31-2014, 09:56 AM
Plasmalvr60's Avatar
Originally Posted by jdsmoothie View Post
There is likely a setting on the TV to change the audio to "Home Theater" or "External speakers", Also, if you are using a cable/sat box connected to the TV/CBL HDMI input, you'll want to either assign the optical input to an unused source name or or you can simply connect the optical cable to the TV/CBL OPT1 input and press the INPUT button on the back of the remote and select "Digital" when you want to listen to the smart app audio and select "HDMI" when you want to listen to the cable/sat box.
jdsmoothie:
Thanks so much for your feedback!
Samsung PN64F8500 Smart TV (64" Plasma-2013); LG BD 390 Blu-ray Player; Denon AVR-1709; Nakamichi MB CD Player; Verizon FiOS Motorola 7 Series Cable Box (500GB Hard Drive).  Pioneer Elite 1120 (5th Generation Plasma- 2005); Denon AVR 2800 (2000); Oppo Blu-ray 103 w/Roku Stick; Sony Carousal CD;...
Plasmalvr60 is offline
post #6573 of 12678 Old 03-31-2014, 10:01 AM
Jiffylush's Avatar
Originally Posted by HaydenAVRX4000 View Post
Hey all
I have a Denon AVRX4000
I am looking into a Samsung 4k screen but I just learned about HDMI 2.0
Is the 2.0 only for the 3d thing?  Also could I get around the need for upgrading AVR by hooking the HDMI cord directly into the TV?  If I hooked the HDMI cord into TV how would I get audio back to AVR?
Apart from the fact that someone answered and told you the X4000 would do what you needed I thought I would answer the other part of the question. You would use HDMI from the source to the TV and then Optical back to the Receiver. The downside here is that you would lose some of the capability to use higher-resolution audio formats like Dolby TrueHD and DTS HD Master Audio.
Jiffylush is offline
post #6574 of 12678 Old 03-31-2014, 10:14 AM
McStyvie's Avatar
Liked: 78
You need a machine that can do video and audio separately out. One HDMI to the TV, one to avr. Lossless on both
Sent from my GT-I9300 using Tapatalk
McStyvie is offline
post #6575 of 12678 Old 03-31-2014, 12:33 PM
Redmist's Avatar
Quoted: 13 Post(s)
Originally Posted by al210 View Post
From What HI FI? "Sound quality
...it’s not quite authoritative enough in the lower frequencies to deliver a fully engaging performance.
Dynamically, the Denon sounds a little restricted in comparison."
I know magazines are often full of hyperbole but this perfectly sums up my thoughts on my Denon 3312 when compared to my Onkyo 808. I was hoping that the newer X4000 would be much improved but it sounds like there's still something lacking. It's not something that can be "EQ'ed" away in my experience.
Redmist is offline
post #6576 of 12678 Old 03-31-2014, 02:07 PM
tcramer's Avatar
Quoted: 274 Post(s)
Liked: 119
I have an X4000 that I'm using for the full 7.2 in the main listening area. I have a couple sets of in-ceiling speakers in separate rooms that I plan to use for my zone 2.
Is there a cheap amp that anyone has had luck with to power a 2nd zone in a similar situation? These are cheap Polk in-ceilings that have independent volume control for each pair in the other rooms, so definitely don't need an Emotiva or anything of that level. I see quite a few of cheapo 2 channel ones, but thought maybe someone has had good luck with a certain unit.
JVC DLA-RS600, 110" Stewart Cima Neve, Oppo UDP-203, TiVo Bolt, Denon X4300H
Dual Rythmik FV15HP, Energy Veritas Fronts and Surrounds, 4x RSL C34E for Atmos
tcramer is offline
post #6577 of 12678 Old 03-31-2014, 02:11 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Audiosource AMP 100.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #6578 of 12678 Old 03-31-2014, 02:11 PM
jdsmoothie's Avatar
Liked: 5509
post #6579 of 12678 Old 03-31-2014, 03:45 PM
tcramer's Avatar
Quoted: 274 Post(s)
Liked: 119
Thanks to you both. That is the one that stood out to me too.
tcramer is offline
post #6580 of 12678 Old 03-31-2014, 09:45 PM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
Do you think by having klipsch fronts and polk t15 rears with my x4000 is that degrading my overall surround sound quality? IE: how much better would a pair of klipsch bookshelfs sound for my overall aural enjoyment?
Main room (3D blu ray, PS4) - LG 65EG9600: Denon x4000, Klipsch RC-62II, RF-62II x2, RS-41II x2, SVS PC-12NSD + Klipsch RW12d
Couple small LCDs - PS2, PS1, Dreamcast, N64, 3DO, Saturn and other various retro game collections MINT COMPLETE games
Teremei is offline
post #6581 of 12678 Old 03-31-2014, 09:50 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 896
Unless you like to listen to a lot of sacd or other 5.1 music formats, I wouldn't worry about it. It'll be fine for movies, etc.
ambesolman is offline
post #6582 of 12678 Old 04-01-2014, 04:13 AM
jdsmoothie's Avatar
Liked: 5509
Nope. Having unmatched surrounds is far less important than having unmatched front speakers.
post #6583 of 12678 Old 04-01-2014, 06:51 AM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
Thanks both of you. Looks like I can save a few hundred for now. I might want to buy a pair of 51s in the future if only to open up the the rears a bit. Because it's about twice the size and weight of the ones I have now.
Teremei is offline
post #6584 of 12678 Old 04-01-2014, 10:01 AM
ryangs's Avatar
Wow, this thread is a great reference. Way to go, batpig and jdsmoothie.
I'm looking at refurbished on Accessories4Less, and I don't think I can say no to the E400 at only $269. That's practically a Craigslist price, but I'm sure to get the remote and setup mic, plus a one year warranty. The X2000 is $399, and for that big a price difference, I don't think I can justify the X2000. I don't think banana plugs and slightly better Audessey EQ are worth a 50% price increase.
If I were to spend more, I'd be inclined to jump up to a Marantz from AC4L. It looks like the xxx7 Marantz series corresponds to the 2012 xx13 Denon models, and the xxx8 are the same platform as the 2013 (X or E) Denons. Is that correct? Do the Marantz models receive firmware updates with the same frequency or timeliness of the Denons? Are there any (proven) internal differences between the Denon line and the Marantz line, or are you just paying for the brand and the sexy front panel?
ryangs is offline
post #6585 of 12678 Old 04-01-2014, 11:22 AM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
The E300 is available for $160 less than the X1000. Say I am not interested in multi zone function, is the X1000 worth the price premium for an extra 5 watts/channel and the MultEQ XT?
Is the sound processing better on the X series?
Opinions...?
wattheF is offline
post #6586 of 12678 Old 04-01-2014, 12:05 PM - Thread Starter
batpig's Avatar
Liked: 3415
The differences between the models are discussed in post #2 of this thread. The X1000 write-up includes an explicit list of upgrades over the E300.
There is no difference in "sound processing" besides the superior XT calibration.
Setup Guide and FAQ
batpig is offline
post #6587 of 12678 Old 04-01-2014, 12:47 PM
Signal to Noise's Avatar
Quoted: 13 Post(s)
I finally got around to setting up my X4000 this past week. It replaces a still capable AVR-2310ci. Comparatively the X4000 was a breeze to set up and the audio once calibrated is fantastic.
The only thing I miss on the X4000 is that telling blue DTS HD Master audio indicator light. frown.gif Oh well.
Overall a very solid receiver so far.
Audio + Video = Bliss
Ears: Denon | Cambridge Audio | Polk | Totem | Martin Logan | Mission | KEF
Eyes: Panasonic plasma | Samsung lcd
Signal to Noise is offline
post #6588 of 12678 Old 04-01-2014, 12:49 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2983
At least it says still says it on the display. The Marantz porthole sucks IMO
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #6589 of 12678 Old 04-01-2014, 01:24 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Opinions...?
wattheF is offline
post #6590 of 12678 Old 04-01-2014, 01:28 PM - Thread Starter
batpig's Avatar
Liked: 3415
Did you REALLY just bump your own post after a mere 2 hours, even though I already answered the original post over an hour ago?!??
Farley1 likes this.
Setup Guide and FAQ
batpig is offline
post #6591 of 12678 Old 04-01-2014, 01:42 PM
jpsooner's Avatar
I tried to read through all these pages, and did searches in this thread but couldn't find much that answers this question:
Owners of the E300 or E400, do you enjoy your receiver?
Thinking of pulling the trigger on the E400 because it's only $279 (refurb) but wanted to know if people who owned this receiver were completely happy with it. This thread seems to have more about the X series than E series.
jpsooner is offline
post #6592 of 12678 Old 04-01-2014, 01:55 PM
Dig and Spike's Avatar
Dig and Spike is offline
post #6593 of 12678 Old 04-01-2014, 01:57 PM
Yes, extremely happy. With the E400. The only issue I have is that it seems to run on the warm side, so make sure you have adequate ventilation and/or space.
post #6594 of 12678 Old 04-01-2014, 02:01 PM - Thread Starter
batpig's Avatar
Liked: 3415
I helped a friend set up his system with a refurb E300 from A4less and he is very happy with it. No issues at all and it looked brand new.
Setup Guide and FAQ
batpig is offline
post #6595 of 12678 Old 04-01-2014, 02:04 PM
Look on Amazon; new E400 for $349.00. Best Buy will price match. 2 yr warrantee for new compared to only 1 yr warrantee for refurb.
post #6596 of 12678 Old 04-01-2014, 02:53 PM
AnttiV's Avatar
Hi! My eyes are starting to bleed from reading this thread (and multiple different threads over this and other forums), but I just can't seem to find an answer to my question. I made a separate thread for this question, but on second thought I should've probably posted it here. So I'll just copy the question here:
I'm looking for a new AV Receiver and my current search has pointed me to Denon AVR-X2000 (The other serious contender right now being Yamaha RX-V775). However, I seem to be in a sort-of unique position, that I need BOTH optical in AND HDMI in for audio (obviously not at the same time) with just one (HDMI) video signal.
I've read through the Denon manual, but I'm unable to find specifics of how the receiver works concerning this need.
Okay, so the manual says I can assign inputs pretty much however I choose, yes? BUT, can I choose one HDMI input for multiple inputs? Say I have two settings, named "Games" and "Movies". Can I do this:
Movies: HDMI-1 Video + HDMI-1 Audio
Games; HDMI-1 Video + Optical Audio
And just change between them via the quick select buttons?
AND/OR, can I do this:
Just one setting. Let's say named "Computer".
I connect both HDMI and Optical connections. Then in the Audio Type (or whatever that was called) menu I select "Auto" (it allows "Digital", and "HDMI" also).
Can the receiver then play sounds from BOTH optical audio AND HDMI audio, depending on what the source sends?
In all cases the output will be HDMI for video and audio via speakers. HDMI and optical audio will NOT output at the same time, as far as I know.
Why I need this? - read on if you want the full explanation.
I'm connecting my computer to the receiver (and possible few other sources, but that shouldn't matter). My Music/Movie sounds will be output through the HDMI (via nVidia GTX680) in 2.0 - 7.1, depending on source. The sound will be unaltered by the computer (as much as possible.) I will also connect my X-Fi Titanium soundcard via optical to the receiver and all my game audio will be output via that (processed by the soundcard/software as much as needed, encoded in DDL5.1 or DTS5.1). This way I will get to enjoy both "pure" movie soundtracks and processed game audio. In the latter case, it would be ideal if the receiver could upmix that 5.1 to 7.1, though that's not a deal breaker.
AnttiV is offline
post #6597 of 12678 Old 04-01-2014, 03:16 PM - Thread Starter
batpig's Avatar
Liked: 3415
You cannot create two "logical" inputs with a single physical input. So for example you can't map a single HDMI connection to two different "names".
You CAN however assign both optical and HDMI to the same input, and then toggle the "Input Mode" setting from "Auto" to "Digital" when you want to force audio from the optical input and override the HDMI audio. Unfortunately the "Auto" setting won't work to automatically toggle because the receiver will still sense the HDMI connection and assume there's audio coming down the pipe as well.
I'm still not clear however why you can't just output the video game audio via the HDMI connection as well.
AnttiV likes this.
Setup Guide and FAQ
batpig is offline
post #6598 of 12678 Old 04-01-2014, 03:34 PM
ben805's Avatar
Looking into the X4000, is it a good match for EMP speakers and do you foresee any issue with it driving 6ohm? Have ordered the EMP tower, center, and surround few days ago, was going to get the Yamaha 3030 but the YPAO is inferior to Audyssey MultEQ XT32 and it's $500 more expensive.
ben805 is offline
post #6599 of 12678 Old 04-01-2014, 03:35 PM
AnttiV's Avatar
Ah, darn. I was hoping (judging by the image in the manual) that I could map a physical input multiple times. Ohwell. How "hard" it is to toggle the input mode every time? Does it need multiple key presses?
I can't output the video game audio via the HDMI, because the sound card cannot "redirect" the processed audio internally to the video card. And I can't use the video card (or, more specifically I *CAN* but I don't *want* to), because then I'd lose all OpenAL/EAX/CMSS-3D/whathaveyou effects that I like in games. It would be ideal to be able to redirect the processed sound card audio via the video card to the HDMI, but that is just not possible. (I'd need a device that can "inject" optical DDL audio signal into a HDMI connection, and I'm willing to bet that these either A) do not exist, or B) cost more than an arm and a leg.)
If the Auto-setting can't work automatically between "Digital" and "HDMI", what does it DO there then? :) I mean, what is the possible scenario where the "Auto" setting would be useful, if that really can't automatically toggle between HDMI and Digital.
I'm really, REALLY tempted to just get the Denon and hope it would work like I want to, but...
Oh, at times like this I hate living here. It's nigh impossible to get a demo of any kind when buying audio equipment (just big-name stores, no specialized audio sellers around) and really, literally, impossible to get a demo of Denons because nobody's selling those locally. ("funny" fact: the stores here that have demo units of AV receivers do NOT hook them up to TVs, so you don't get to see the GUI *ever* before you purchase the items. Yeah, I know.)
AnttiV is offline
post #6600 of 12678 Old 04-01-2014, 03:48 PM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
x4000 drives my Klipsch and EMP are in the same range. I don't think you need much more than x4000 unless you are going ultra high end.
Teremei is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
