The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 238 - AVS Forum | Home Theater Discussions And Reviews
 415Likes
post #7111 of 12870 Old 04-28-2014, 04:58 PM
jdsmoothie's Avatar
Quoted: 15037 Post(s)
Liked: 7252
Originally Posted by mnc View Post
No warranty if purchased from Amazon?
jdsmoothie is offline
post #7112 of 12870 Old 04-28-2014, 08:32 PM
AlphaPie's Avatar
Quoted: 152 Post(s)
Liked: 376
Originally Posted by jdsmoothie View Post
7.2 - Pioneer Elite SC-85 | Pioneer Elite BDP 120 | Polk Audio RTi12/CSi3/RT25i | DIY Dual 12" subs/Behringer Inuke3000
Monster Power 2500 | Sharp Aquos 60" | Xbox One | Sony BRP | Plex Server | Custom TV Stand w/ Middle Atlantic Racks
2 CH - Realistic STA-2100D | Realistic 31-2009 Stereo EQ | Marantz AT 6 | Sony CDP-CE375
AlphaPie is online now
post #7113 of 12870 Old 04-28-2014, 09:07 PM - Thread Starter
batpig's Avatar
Quoted: 3705 Post(s)
Liked: 3572
Originally Posted by dpjb View Post
Quick question. When I set up my new AVRX4000, it said my sub was too loud and had me adjust the control on the subwoofer until it read 75dB on the screen. But when Audessey was finished running, it set the sub level to -6.5. If 75dB is reference level and the mic read 75dB when I stopped adjusting the sub, why the big cut? All the speakers are set to small and the cutoff is 80hz.
The initial sub level check screen uses a different, cruder method for checking sub SPL. The actual Audyssey pings are more precise and also factor in any EQ adjustments required. That initial screen is just there to get you in the ballpark.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #7114 of 12870 Old 04-28-2014, 09:42 PM
dpjb's Avatar
So do you recommend sticking with the Audyessy settings or boosting them as someone else suggested? It doesn't sound bad, but seems to have a little less bass than the avr791 I replaced with the 4000. The 791 was at the settings it's version of Audysessy came up with.
dpjb is offline
post #7115 of 12870 Old 04-29-2014, 12:55 AM
McStyvie's Avatar
Liked: 78
It is really just a matter of personal preference whether you boost it or not. It will not affect the filters at all (if you only change the level in the AVR and don't touch the gain on the sub).
I run mine 3 db hotter than what Audyssey put them at. Some run them 6db hot, some 12...
McStyvie is offline
post #7116 of 12870 Old 04-29-2014, 05:10 AM
chi_guy50's Avatar
Quoted: 1596 Post(s)
Liked: 1340
As JD has explained in his exhaustive early post in this thread, Amazon is an authorized reseller but "Amazon Warehouse Deals" is NOT; therefore D&M will not honor the product warranty if purchased from the latter (or from any other unauthorized third-party e-tailer selling on Amazon's website).
However, if you are still tempted to purchase an Amazon Warehouse Deals (AWD) listing, know that Amazon has an internal policy to provide coverage for any product you purchase from them (including AWD) for which the manufacturer refuses warranty coverage due to the source of purchase.  Obviously YMMV and you will have to jump through some wickets first, but this means that Amazon will generally reimburse you the purchase price if the product turns out to be defective within Denon's stated warranty period and you are denied coverage by D&M.  As JD has frequently pointed out, you also have the option of purchasing a third-party warranty and/or obtaining warranty service from your credit card issuer in some cases.
Living Room: Sony XBR-65Z9D UHD LCD TV w/FALD; Oppo UDP-203; Sony BDP-S5200 (multi-region); Denon AVR-X5200W (Video: Dolby Atmos/DSU 7.1.4; Music: DTS Neo:X 11.1); Dayton Audio MA1260 12-Channel Amplifier (60wpc); Polk Audio RTiA7 (F/LR), CSiA6 (C), RTiA5 (FW), OWM5 (Sr, SB), 80F/X-RT (FH, TR); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929 LCD HDTV w/FALD, DarbeeVision DVP 5000S, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #7117 of 12870 Old 04-29-2014, 07:14 AM
tl187's Avatar
My X3000 shuts down intermittently and blinks red when connected to my Samsung UN55F6400 TV's ARC HDMI port.
I have had my X3000 for about a month with no issues.  As soon as I introduced the TV I began having shutdown issues with my receiver.  It seems the problem occurs only (or mostly) when the HDMI cable is connected from the AVR's ARC/Monitor port to the TV's HDMI2 (ARC) port.  In this configuration, the shut downs happen quite often and regularly.  When I unplug it from the TV and reset it, it seems to work without issue.
Has anyone experienced this?
Things I've already tried that did not work:
  I tried doing a soft reset.
  I tried plugging the AVR into a different power outlet.
  Firmware on both the AVR and TV are the latest.
tl187 is offline
post #7118 of 12870 Old 04-29-2014, 08:10 AM
Vecuronium's Avatar
I've got the same exact TV and an X2000 with no issues. There is a setting in the Denon to turn off HDMI control or something. I turned it off and have had no problems.
Vecuronium is offline
post #7119 of 12870 Old 04-29-2014, 08:42 AM
tl187's Avatar
Why did you have to turn HDMI control off?
tl187 is offline
post #7120 of 12870 Old 04-29-2014, 09:29 AM
jdsmoothie's Avatar
Liked: 7252
If you have the HDMI(ARC) featured enabled on both the TV (Anynet+) and AVR (HDMI Control), there appears to be some voltage issue with your TV that is causing the AVR to shut down. You can disengage Anynet+ or HDMI Control and instead use an optical cable from the TV to the AVR to pass the TV smart app audio back to the AVR.
post #7121 of 12870 Old 04-29-2014, 09:35 AM
tl187's Avatar
Could this be due to a defect on the TV that is causing this voltage issue?  Wondering if I should return the TV.  I will try the optical cable once I acquire the cable.
tl187 is offline
post #7122 of 12870 Old 04-29-2014, 01:28 PM
jdsmoothie's Avatar
Liked: 7252
Can't say for sure, but most likely as it shouldn't be an issue otherwise, not to mention this issue has rarely been brought up.
post #7123 of 12870 Old 04-29-2014, 03:26 PM
AlphaPie's Avatar
Quoted: 152 Post(s)
Liked: 376
Been getting a busy signal on the phone all day from yall, whats the deal? Must be making tons of people happy with great prices biggrin.gif
post #7124 of 12870 Old 04-29-2014, 04:11 PM
jdsmoothie's Avatar
Liked: 7252
Back on line again now but phone service went out for a few hours and now intermittent disconnects due to thunderstorm in area knocking out power smile.gif
post #7125 of 12870 Old 04-29-2014, 05:00 PM
canbonbon's Avatar
Torn between Denon X2000 and Yamaha RX-V775WA. My Pioneer 1021K just died. So in market for another. This time trying to go for a more reliable product. Denon offers 3 yr warranty so that is good. My primary use would be to watch Hi Def Movies. Has anyone done any comparisons of these series? I tried to search through the thread but could not find anything. Any suggestions beyond the obvious 2 HDMI Out, etc. would be appreciated especially in sound quality, reliability, etc.
canbonbon is offline
post #7126 of 12870 Old 04-29-2014, 06:46 PM
IvanVest's Avatar
Just purchased a Denon AVR X4000i
I have a vintage Bang & Olufsen half tack open reel tape recorder with three 5-pin DIN jacks (stereo in/out - tape monitor & stereo microphone). All now adapted to RCA plugs.
Also an older <>1994 model Denon DRS-840 cassette player with the normal stereo RCA tape in/out jacks. How to best hook up these two to the X4000?
Ivan
IvanVest is offline
post #7127 of 12870 Old 04-29-2014, 06:52 PM
DNZone's Avatar
Quoted: 176 Post(s)
Liked: 55
You have to be careful with power specs, you can't just look at the listed wattage number but also the rest of the spec (impedance and distortion and bandwidth). The 120w number is probably a 6 ohm rating whereas the 80w is an 8 ohm rating so you are comparing apples to oranges.
So when the denon site says its 135w per channel, what does that actually mean? 8ohm performance?
DNZone is offline
post #7128 of 12870 Old 04-29-2014, 07:16 PM
carlbarry's Avatar
Quoted: 22 Post(s)
Ivan
I have a Sony reel to reel and 2 Harman Kardon cassette decks. Formerly hooked up to my Carver Receiver. I was pretty shocked when I realized that receivers now have no tape inputs or tape monitoring abilities. When I called Denon I was told to use the analog "media" outputs.
carlbarry is offline
post #7129 of 12870 Old 04-29-2014, 07:40 PM
Jfedorczyk's Avatar
Not sure if this is the right place to ask this or not, but here goes.
I made the jump to dual subwoofers (two jbl 8400p) hooked into a denon x4000.
When I run the audyssey calibration it asks me to level match each sub to 75db. Once calibration is complete, the trim levels are coming back at -10 and -9.5 for the subs which seems too far negative to me. Both subs are on the front wall 1/3 of the way in.
The bass is present, and clean sounding, sound stage is centered with the bass, but I guess I was expecting more "punch"
Is this just my ears needing to get used to proper reference bass levels or is there something I should be doing differently? I don't have an SPL so gain matching isn't going to happen.
Am I focusing too much on the negative trim setting result? I was under the impression that I should be aiming for +/- 3 for the trim, but I won't be able to get that if I follow the 75db level match because it is going to tell me to turn up the subs. The odd thing is that when I had only the one sub it would calibrate itself to -3.5.
Is there anything "wrong" with having the trim that low? I know I can tweak it to my liking but I don't want to go too far outside of the calibration settings and throw off the rest of the setup.
Jfedorczyk is offline
post #7130 of 12870 Old 04-29-2014, 07:42 PM - Thread Starter
batpig's Avatar
Liked: 3572
Literally the exact same question was discussed less than 24 hrs ago. See quote and read above for more.
The only thing "wrong" with an extremely negative trim setting is if the voltage is too low to trigger the auto on circuit consistently. If you want it brassier just raise it to taste.
Setup Guide and FAQ
batpig is offline
post #7131 of 12870 Old 04-30-2014, 04:42 AM
Jfedorczyk's Avatar
Doh.. I can't read! Thanks batpig.
post #7132 of 12870 Old 04-30-2014, 07:01 AM
tl187's Avatar
I tightened all my speaker connections and made sure there were no loose strands (none that I could see).  Then I hooked up the optical audio cable and turned off the ARC/CEC/HDMI Control.  No shut downs.  I then re-enabled ARC/CEC/HDMI and again, no shut downs all night.
Not sure what fixed it but it seems OK now.  I have a few weeks to return the TV so I will wait and see if the issue comes back.
tl187 is offline
post #7133 of 12870 Old 04-30-2014, 07:19 AM
dgeorge4's Avatar
hi, i own an AVR-X1000 and the quality in network mode in order to stream flickr photos is only at 576i instead of 1080i which my tv supports....is any setting that i can't find or the netword mode of the amp supports up to 576i?
dgeorge4 is offline
post #7134 of 12870 Old 04-30-2014, 08:46 AM
baltik's Avatar
Quoted: 12 Post(s)
Can I play music to x2000 via airplay without turning on the receiver or selecting an input? Just want to know if this can truly be a handsfree experience
baltik is offline
post #7135 of 12870 Old 04-30-2014, 10:00 AM
jdsmoothie's Avatar
Liked: 7252
The AVR can be in Standby and set to ON using an Airplay device (eg. iPhone, iPad), however, if you plan on using the AVR's speakers, the AVR must be ON.
post #7136 of 12870 Old 04-30-2014, 10:10 AM - Thread Starter
batpig's Avatar
Liked: 3572
RayWK likes this.
Setup Guide and FAQ
batpig is offline
post #7137 of 12870 Old 04-30-2014, 10:25 AM
jdsmoothie's Avatar
Liked: 7252
AFAIK, no as there is no video chip installed in the X1000, whereas on models with a video chip, (eg. E400, X2000, X3000, X4000) the video could be upscaled to the TV's resolution.
post #7138 of 12870 Old 04-30-2014, 10:30 AM
jdsmoothie's Avatar
Liked: 7252
Adding the second sub is generally going to increase the overall sub level by +6db which must then be countered in the AVR. As batpig notes, simply bump the subwoofer level for each sub 3-5db (or whatever is required to suit your preference). Keep in mind this is your system .. if you want more bass ... then so be it ..........BOOM ... BOOM ... BOOM. smile.gif
post #7139 of 12870 Old 04-30-2014, 10:38 AM
BLeClair12's Avatar
Quoted: 344 Post(s)
Liked: 206
Received my X2000 from World Wide Stereo/Amazon yesterday. Very excited, but I won't have a chance to use it right off. Got to start grabbing speakers (I'm chipping away at everything over the course of a few months or so.) Going to be a huge upgrade over the HTiB I'm currently using.
Just was wondering - do you guys recommend Squaretrade warranties on these things? I know the X series carries a 3 year warranty, but that I'd be responsible for any shipping charges to Denon, whereas that's all free with Squaretrade. I can get a 3 year plan for around ~$32 or so right now, but wanted to get some solid advice before pulling the trigger.
BLeClair12 is online now
post #7140 of 12870 Old 04-30-2014, 11:22 AM
ComponentActual's Avatar
Quoted: 29 Post(s)
I am thinking of purchasing the AVR-X2000 receiver and the Spotify streaming directly from the receiver is a big draw for me. My girlfriend has airplay and use that for her music, and I have android and mainly listen to Spotify. I have been trying to browse the thread for info on the Spotify app, and what I am seeing is kind of discouraging. How is the spotify app on the receiver and how is control from an android phone? Thanks
ComponentActual is offline
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
