The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 269 - AVS Forum | Home Theater Discussions And Reviews
 400Likes
post #8041 of 12725 Old 06-28-2014, 07:11 PM
yohan1969's Avatar
Originally Posted by jdsmoothie
What source are you trying to pass to Zone 2? Try swapping the speakers, if neither works in the SBR speaker posts, then try doing a microprocessor reset at least 4-5 times in a row. If still no joy, and you are within the return period of the unit, exchange it, otherwise check Denon's website to see if there is a repair facility in your local area.
Thanks JD, I've tried multiple sources and swapped speakers as well. I will try multiple resets and cross my fingers. I'm pretty sure it will have to be exchanged/repaired.
yohan1969 is offline
post #8042 of 12725 Old 06-29-2014, 04:18 AM
Liked: 0
perplexing situation !!!
Hi
This is my first post and I would like to thank all you for all the advice I have been reading till now
I recently purchased a Denon x2000 avr and hooked it up with a sony 670 TV and TataSky HD DTH Box and xbox 360.
Initially I setup as it should be ie all HDMI connections i.e output to TH ARC HDMI and all inputs into properly marked HDMI inputs.
However I had so called 'earthing' problems ie I switch on/off some light in the room and I will hear it from the amp + the tatasky box was outputting video OK but sound used to come randomly - apparently some specific power on sequence worked ...but changing channels /sources - sound goes.
read lot of posts and suggestions.
tried various things like changing hdmi ports etc - no use.
got house wiring checked as well. and all devices nowdays come with 2 pin jacks and I dont have polarized plugs.
got tatasky technician to visit also and he says as long its working directly with TV its ok.
Then I connected the tatasky box to TV and optical out to the AVR thus isolating all electrical connections between the tatasky box and the avr and 'earthing' issues go away.
the setup works fine .... till you change channels on the tatasky box - again sound goes. if you switch the avr on/off it comes back !! so everytime I change channels , I need to switch the avr on/off
have disabled all HDMI settings like bravia sync (ie ARC) in TV, HDMI controls in AVR.
AVR works fine with xbox, HDMI connection.
tatasky box works fine with the TV - HDMI connection.
AVR and tatasky hs box done work fine with each other !
So the question is whether the problem is in the tatasky HD box or the avr ?
will appreciate and any other advice/suggestions to solve this vexing issue ...and optimizing my setup.
Thx
_________________________________________________
Sony 670 HD TV, XBOX 360, Denon AVR 2000, B&W MT 50
tag1017 is offline
post #8043 of 12725 Old 06-29-2014, 04:26 AM
jdsmoothie's Avatar
Quoted: 13303 Post(s)
Liked: 6164
Connect the cable box --> HDMI ---> TV and cable box ---> optical ---> AVR. Use either an optical switch to increase the number of optical inputs to the AVR or use an optical --> coax digital converter.
tag1017 likes this.
jdsmoothie is offline
post #8044 of 12725 Old 06-29-2014, 06:36 AM
Liked: 0
Thx.
I have already connected satellite Box to AVR via optical.
however when I change channels on satellite box, sound goes. I need to switch avr on/off to get sound for the 'new' channel
tag1017 is offline
post #8045 of 12725 Old 06-29-2014, 07:09 AM
JChin's Avatar
Quoted: 350 Post(s)
Liked: 204
Originally Posted by tag1017
Thx.
Hi tag1017, as a test use the Xbox 360 (excluding Xbox 360e model) optical port to see if you get the same result like tatasky HD.
JChin is offline
post #8046 of 12725 Old 06-29-2014, 07:19 AM
jdsmoothie's Avatar
Liked: 6164
Thx.
There should be no issue with this configuration, rather seems to be an issue with the cable box. You may want to try connecting analog RCA cables (red/white) from the cable box instead, although doing so you would not be able to pass DD 5.1 from the HD channels.
post #8047 of 12725 Old 06-29-2014, 11:13 PM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
Hey JD, quick question for ya
Can zone 3 pass audio to wireless headphones via its rca outs w amp set as 5.1/zone3 or 5.1/mono zone2&3?
Reason I ask is ive been trying to get audio from zone 3 to my wireless headphones and i couldnt get any audio
I tried several soft resets and did a microproc reset 4-5 times and it still didnt work.
Also I went thru the material on page 1 and went thru the user manual there isnt any mention of not being able to use zone 3 for wireless headphones....
" -- 3rd zone is stereo audio only (either with external amp or internal amp assignment)
d. Wireless Headphones: One advantage of having a model with Zone 2 pre-outs (ie. “CI” or "X" model), is that you can connect a set of analog wireless headphones (eg. Sennheiser) and listen to music elsewhere in the house while someone is watching a movie or playing a game in the main zone (noting the Zone 2 limitations listed above). "
So either Zone 3 can only pass audio with an external amp/receiver or my receiver is busted and ill need to RMA it via Denon
music_to_my_ear is offline
post #8048 of 12725 Old 06-29-2014, 11:16 PM
Quoted: 185 Post(s)
Liked: 90
ps: I just want to add doing a proc reset has fixed the zone 2 to wireless headphones issues i was having earlier last week. So I just want to thank you for that!
post #8049 of 12725 Old 06-30-2014, 03:13 AM
jdsmoothie's Avatar
Liked: 6164
Although Zone 3 cannot pass HDMI audio (like Zone 2) it should be able to pass PCM 2.0 optical/digital coax/analog.
post #8050 of 12725 Old 06-30-2014, 08:35 AM
lemonslush's Avatar
Quoted: 826 Post(s)
Liked: 403
With the new x4100 coming out soon, do you think the x4000 will go down in price?
lemonslush is offline
post #8051 of 12725 Old 06-30-2014, 09:00 AM
jdsmoothie's Avatar
Liked: 6164
Depends on whether there is any excess inventory although pricing of new X4100W is going up $100 when it is released in Sep so not likely to be much.
post #8052 of 12725 Old 06-30-2014, 10:52 AM
alfbinet's Avatar
New AVR-X1000 & iPod Problems
Here is the equipment causing me problems:
NEW Denon AVR-X1000
Apple iPod Nano - 5th Generation
After initial set up I experienced problems with the Front USB port. I had connected my 5th Gen iPod Nano and set it up. I chose the "On Screen Option" to play the device. I selected iPod/USB as the function. Then AVR shows options of Artists, Songs, etc. I choose Random, select song, "Enter". Screen pops with "Now Playing". About a minute later album art, song title, band, and album name appear. Options on screen are: Pause, Previous, Option, Back, and Next. There is a minute and second indicator, and a percent indicator. Both always displays 00.00 and 0%. There is a "spinning wheel" that is constantly going around and around on the right side of the display. All this with NO AUDIO.
I slept on this problem and did a full microprocessor reset this morning. Same result. Do I have a poor USB input? I have checked the manual and my 5th Generation iPod Nano (with a drawing) shown as being supported. I LOVE this receiver but is it time to ship it back for a replacement or refund?
Jim Kilbane
Chad Billheimer rocks as a ISF Calibrator for Ohio.
Roller Coaster season is upon us. Proud member of American Coaster Enthusiasts (ACE) Woodies Rule!
alfbinet is offline
post #8053 of 12725 Old 06-30-2014, 11:34 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
NEW Denon AVR-X1000
Jim Kilbane
I have a similar problem with an older ipod classic, except in my case, if I choose the on-screen option everything works fine, but if I choose the option that lets me select music directly on the ipod, no sound. I had the problem with an X1000, which I ended up returning, and I have the identical problem with my current X2000. So I've reconciled myself to have to use analog-in to get ipod content to the X2000.
Separately, I've noticed that with solo piano tracks, Airplay introduces a non-trivial crackling noise into the soundtrack. There are tons of reports of this on the interwebs, going back many years, it seems to be a software quirk that Apple has never managed to fix. Odd.
niccolo is offline
post #8054 of 12725 Old 06-30-2014, 07:19 PM
alfbinet's Avatar
Niccolo,
I figured it out! The AVR-X1000 is fine; it was the iPod. I have had my iPod over 4 years. I got the bright idea to try and find the manual for it - 5th generation or not. I found it and downloaded to my laptop. It was suggested in the manual to reset the iPod (I didn't know you could). I followed the instructions, plugged it into the front USB and sound! Still have problems with cover art. It has stayed on Gerry Rafferty's City to City cover art for about 5 different songs.
Jim
alfbinet is offline
post #8055 of 12725 Old 07-01-2014, 01:49 AM
Liked: 0
Hi
I already have the cable box connected to TV via HDMI ...so it works fine without the avr. I use AVR for HD channels ....but then switching /channel surfing is becoming a pain as audio goes away.
the way i understand it is that the AVR and sat box are 'electrically' isolated ....only connection is via optical ...and the avr is not able to 'respond' to a change in channel ....so could the problem be with the avr since audio comes when its switched on/off or is it with the cable box that its not able to send the 'change in channel' audio correctly ... this is confusing
second ..am planning to buy a basic blue ray player , since I want the avr to do everything, with the player only reading the disc. such players (eg sony bdp s1100) typically have an HDMI and a coax out. can this problem persist with the BD player as well ?
thx
tag1017 is offline
post #8056 of 12725 Old 07-01-2014, 02:43 AM
jdsmoothie's Avatar
Liked: 6164
There shouldn't be any problem with just the optical connected to the AVR. Try resetting or replacing the cable box.
post #8057 of 12725 Old 07-01-2014, 01:11 PM
Quoted: 156 Post(s)
Liked: 39
I Just got a klipsch SW 450 and it has speaker inputs , now i read that the RCA LFE only works on 5.1 and if i wanted to use the Sub in music i would have to use the Speaker setup.
Now i have the Denon x4000 does that sub has the capabilities to do that?
2pacalypsenow is offline
post #8058 of 12725 Old 07-01-2014, 01:16 PM
jdsmoothie's Avatar
Liked: 6164
Just connect the sub pre-out on the X4000 to the LFE input on the sub and run Audyssey. Reset any speakers set to LARGE as SMALL/80Hz which will ensure the low bass from music gets sent to the sub.
post #8059 of 12725 Old 07-01-2014, 01:22 PM
Quoted: 156 Post(s)
Liked: 39
So just keep it on the LFE rca and run audyssey? Ok thank you
Also i have my front speakers Bi amped is there a way i can have 7.1 and still use bi amp?
post #8060 of 12725 Old 07-01-2014, 01:40 PM - Thread Starter
batpig's Avatar
Quoted: 3654 Post(s)
Liked: 3493
The receiver has 7 amps built in. So if you bi-amp, you are using 4 for two channels.... 7 minus 4 is 3 left over for center and surrounds. So, no, you can't bi-amp and ALSO do 7.1.
Not a big deal though, since bi-amping with the receiver is basically pointless.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #8061 of 12725 Old 07-01-2014, 01:45 PM
Quoted: 156 Post(s)
Liked: 39
O i thought bi amping was a benefit?
post #8062 of 12725 Old 07-01-2014, 06:52 PM
globalgreg's Avatar
Liked: 29
Just did a firmware update on my X4000...where can I find a firmware change log?
globalgreg is offline
post #8063 of 12725 Old 07-01-2014, 07:42 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Niccolo,
Jim
Glad to hear that worked for you! Sadly it doesn't seem to make any difference with my similar issue.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #8064 of 12725 Old 07-01-2014, 11:11 PM
Liked: 0
Thx.
will try resetting everything !
as for replacing cable box ...lemme see what the dth company says ...
tag1017 is offline
post #8065 of 12725 Old 07-02-2014, 03:08 AM
jdsmoothie's Avatar
Liked: 6164
Firmware change log information is listed in post #6 of this thread.
post #8066 of 12725 Old 07-02-2014, 03:10 AM
jdsmoothie's Avatar
Liked: 6164
Not when simply using the setting on the AVR no as there is only one power supply so no more additional power and the same signal is simply passed to each set of speaker posts. You would be better served removing it and connecting the extra set of speakers if you want to go to 7.1.
post #8067 of 12725 Old 07-02-2014, 07:07 AM
Neverlies's Avatar
Yesterday my new X4000 (about a month or so old) succumbed to the sudden power down w/fast red flashing light. Two soft re-sets didn't fix the problem, and I just did a microprocessor reset and am running Audyssey as we speak.
This issue started yesterday after having a bad storm roll through that did cause a momentary power flicker, however the unit is run through a Belkin PF60 and nothing was on - this was the middle of the night.
If the microprocessor reset doesn't fix it, I'll contact JD (who I bought the unit from) for further guidance/direction. Here's hoping............
"The price of apathy towards public affairs is to be ruled by evil men."
Neverlies is offline
post #8068 of 12725 Old 07-02-2014, 07:30 AM
globalgreg's Avatar
Liked: 29
Thanks....missed that. The update I did last night was from February? Didn't realize it was that old.
post #8069 of 12725 Old 07-02-2014, 07:37 AM
jdsmoothie's Avatar
Liked: 6164
Apparently so.
post #8070 of 12725 Old 07-02-2014, 08:09 AM
jdsmoothie's Avatar
Liked: 6164
Visually check all speaker wire connections to ensure there is no loose speaker wire touching another post, otherwise, if still no joy, call me and we'll do an RMA and exchange it for you.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
