The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 395Likes
Old 07-13-2014, 01:23 PM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
Nope. There should be no change to the stereo 2.0 being sent to the FL/FR speakers.
jdsmoothie is online now
Old 07-13-2014, 01:38 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Originally Posted by sdsalsero View Post
When I listen to a stereo TV show and select DD PLIIx the audio seems to get split into the front-center and the L/R rears? I don't hear anything from the L/R fronts. Is there some setting I'm missing?
If you're in PLIIx movie mode any audio sent to both left and right will be rerouted (anchored) to the center channel. Music mode is different, try it.
Sometimes I'll listen to 2 channel streaming music sources with DTS NeoX Music. It doesn't touch the left and right channels but it does add a bit of center and surround
Tom Grooms is offline
Old 07-13-2014, 02:10 PM
sdsalsero's Avatar
Quoted: 18 Post(s)
Thanks but I am specifically referring to TV shows where you would want the dialogue in the center channel and the 'side effects' in the front L/R. So music- game- and pure- modes don't apply.
My experience is that all the non-dialogue audio goes to the rear L/R. I actually thought (think?) it was a bug which would eventually be fixed in a firmware update, but it never was.
sdsalsero is offline
Old 07-13-2014, 02:35 PM
Dan in St. Louis's Avatar
Quoted: 128 Post(s)
Liked: 39
My experience with my X4000 is that the split is very program-dependent. Even on a single telecaster, like HBO, there is significant difference between programs. One particular commercial run often on CNN seems to be ALL rear channel!
I'm afraid there is no universal solution.
---- Dan in Saint Louis
Dan in St. Louis is offline
Old 07-13-2014, 02:56 PM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
Well, since I had some unforeseen expenses come up recently. I had to adjust my budget for a new AVR. I wanted one of the new 2014 models that had bluetooth. Now I'm thinking, I haven't had it before, so I can deal with it, or I can get something like an x2000 and maybe add the bluetooth adapter, if I really want it.
Do these adapters need an external power source? I don't want any more little boxes with more little power bricks.
I really wanted 7 HDMI inputs, not including the front. I don't want a cable connected to the front.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
Old 07-13-2014, 03:36 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Does this happen with all programming or just certain programs? This kind of steering could occur with a mono signal, since any "in phase" content in the L/R channels will collapse to the center. The steering looks for differences in the channels to maintain the stereo effect but if there are no differences (mono) it will push it all to the center.
I'm inclined to believe it's not a bug but the way that content is coming in. Try something else, like the stereo track on a good DVD or blu ray.
batpig is online now
Old 07-13-2014, 06:26 PM
sdsalsero's Avatar
Quoted: 18 Post(s)
Thank you for the confirmation. My primary source here is Netflix though I also experience it with my kids DVDs
Old 07-13-2014, 07:00 PM
Quoted: 128 Post(s)
Liked: 39
SD, it annoyed one of the clients in our remote control iPad app business so much that I had to add Center Channel Volume commands for him<G>.
Old 07-14-2014, 07:46 AM - Thread Starter
batpig's Avatar
Liked: 3415
Kids DVDs are often recorded in mono with fits my theory. You might want to try PLII music mode instead of cinema, which spreads the center image across the speakers instead of trying to focus it in the center.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
Old 07-14-2014, 12:57 PM
sofakng's Avatar
Quoted: 30 Post(s)
Does anybody know the correct Audyssey microphone positions for a loveseat? I have two "theater chairs" side-by-side which basically forms a loveseat with an armrest in the middle.
How does this chart look?
The black rectangles are the armrests and the white boxes are the two seats. The arrows point towards the front of the room.
sofakng is offline
Old 07-14-2014, 01:00 PM
jdsmoothie's Avatar
Liked: 5502
If you are the primary listener, better to focus just on your one seat (ie. slide 1 to either 2 or 3 depending on which seat is yours. Either way 1- 6 look good and then 7 would go 1/2 diagonal distance from 1 to 4 and 8 would go 1/2 diagonal distance from 1 to 6.
Old 07-14-2014, 01:13 PM
Keith Mickunas's Avatar
Quoted: 103 Post(s)
Liked: 81
You do it by listening position. You want number 1 to be your primary position, followed up by the second seat. You can do the additional areas around it as you've suggested, but I think you'd be better off starting with an actual listening position, not something between them.
Keith Mickunas is offline
Old 07-14-2014, 01:29 PM
sofakng's Avatar
Quoted: 30 Post(s)
OK - Thanks!
I could've sworn I read on the Audyssey blog that if you only have a loveseat to measure the first position in the middle so it properly sets distance, etc. It also said that if you measure the PLP (primary listening position?) off-center that everything will then be measured off-center and cause other problems...
sofakng is offline
Old 07-14-2014, 01:36 PM
Quoted: 103 Post(s)
Liked: 81
OK - Thanks!
Well you might not want to take my word for it then. Have you checked the Audyssey thread? It's quite long, but perhaps searching for love seat or loveseat will help.
Old 07-14-2014, 02:23 PM
jdsmoothie's Avatar
Liked: 5502
OK - Thanks!
You set the mic ##1 position where you want the best audio. If you want that to be your armrest, then that is your choice.
Old 07-14-2014, 03:24 PM
Quoted: 128 Post(s)
Liked: 39
I'm curious about the technology inside my X4000. Are the power amps historical Class AB bipolar transistors, FETs in an analog configuration, or some mode of switching amp?
Has Denon released any papers about their design?
Thank you!
Old 07-14-2014, 04:51 PM
jdsmoothie's Avatar
Liked: 5502
Speaking of the Denon X2000 on clearance, we've only got 2 left with no more stock available, so call now if this model meets your requirements.
Old 07-15-2014, 12:48 AM
Quoted: 147 Post(s)
Liked: 38
So it looks like the x4000 will only upscale analog through the front inputs :-/
2pacalypsenow is offline
Old 07-15-2014, 01:24 AM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
I have 2 denon mics in the same drawer. Can someone check their denon x4000 mic and tell me what the number printed on it is?
Main room (3D blu ray, PS4) - LG 65EG9600: Denon x4000, Klipsch RC-62II, RF-62II x2, RS-41II x2, SVS PC-12NSD + Klipsch RW12d
Couple small LCDs - PS2, PS1, Dreamcast, N64, 3DO, Saturn and other various retro game collections MINT COMPLETE games
Teremei is offline
Old 07-15-2014, 05:22 AM
jdsmoothie's Avatar
Liked: 5502
Any Audyssey mic released from 2008 onward will work with the X4000 which is shipped with the ACM1HB mic.
Old 07-15-2014, 05:23 AM
jdsmoothie's Avatar
Liked: 5502
Any analog input can be converted/upscaled.
Old 07-15-2014, 07:20 AM
Quoted: 128 Post(s)
Liked: 39
I'm not sure what you mean -- are you saying that the information on p229 of the Owners manual is not correct?
Old 07-15-2014, 08:32 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
We must be looking at different manuals. What I see is a diagram showing that ANY component or composite video signal gets converted. That's not literally front inputs. It represents all analog video inputs. In any case, I have lots of analog inputs and they all get converted, front and back.
mdavej is online now
Old 07-15-2014, 10:00 AM
Quoted: 128 Post(s)
Liked: 39
Exactly. 2pacalypsenow said "the x4000 will only upscale analog through the front inputs :-/" so I asked him if I understood him correctly since the manual does not make that distinction.
Old 07-15-2014, 11:29 AM
sofakng's Avatar
Quoted: 30 Post(s)
I'm not trying to disagree with you because I honestly don't know what is best (which is why I'm asking for help!)
However, Chris Kyriakakis (Audyssey employee) posted this on the Ask Audyssey forum:
Originally Posted by Chris Kyriakakis (Audyssey)
The first position should be in the center of the listening area. Usually, that is where the main seat is. If the seat is off to the side, we still recommend taking the first measurement in the center.
That's why I'm confused because I'm not sure if this information is outdated (it's from Februrary 28th, 2010) or not...
sofakng is offline
Old 07-15-2014, 11:48 AM
jdsmoothie's Avatar
Liked: 5502
He is simply implying that ideally the main listening position should be the center. Why not just try two separate Audyssey runs and decide which you prefer? First try arm rest as ##1, listen for a few days or weeks and then your seat as ##1 and stick with whichever you believe provides the best audio experience. Or better yet, just move the two seats so yours is in the center?
Old 07-15-2014, 11:56 AM - Thread Starter
batpig's Avatar
Liked: 3415
The big question is whether you want the whole couch to be "equal" in terms of sound quality or if you want to optimize for one side or the other.
The key thing to understand is that with any speaker setup there can only be ONE sweet spot where everything is perfectly calibrated, with all the sound balanced and arriving to that spot at the same time. Audyssey sets the levels and delays based on the first mic position, so that is the spot where things will be "perfect" in that sense. The additional mic positions just feed the algorithm more data about the distribution of acoustic problems in the room.
So it's really a "philosophical" question. If the couch is perfectly centered to the TV and you are equally likely to sit on either side (or if both people are equally sensitive to SQ) then it's probably best to have the first mic position be perfectly centered and then balance the additional measurements across both seats. If you will nearly always be on the left side instead of the right, and/or the other person doesn't care that much about perfect audio, then you should probably shift the first position that way to make sure the levels/delays are optimized for that spot.
If it's a small loveseat then honestly it's not that big of a deal either way, being a couple of feet left or right of the perfect sweet spot shouldn't be that big of a problem in practice with any decent speaker setup.
But in reference to Chris' quote above, I would NEVER recommend having the first mic position be WAY off center. For example there are compromised living room setups where the main listening position is a couch over to the side of the room. It would be silly to try and optimize for something that terribly wrong to begin with.
It's really all about degree ... your loveseat is still basically "centered" so measuring SLIGHTLY off center won't be a huge deal. Just decide if you'd like both seats to be "equal" or would rather bias towards one or the other.
drwinlied likes this.
Setup Guide and FAQ
Old 07-15-2014, 12:43 PM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 410
Going to ask again, as people apparently missed my question.
The bluetooth adapters for these models, do they require external power?
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
Old 07-15-2014, 12:47 PM - Thread Starter
batpig's Avatar
Liked: 3415
What bluetooth adapter? That seems like a question for whatever adapter you happen to buy, not specific to the receiver.
Setup Guide and FAQ
Old 07-15-2014, 12:49 PM
jdsmoothie's Avatar
Liked: 5502
Depends on the model you buy. If it doesn't come with power, then no.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
