The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 276 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #8251 of 12688 Old 07-19-2014, 10:40 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Originally Posted by Sk76 View Post
Planning to buy Denon X4000 and could see it is for sale on Abe's of Maine website for $829. It says brand new with warranty. Wondering how come as everywhere else it's $1299. Anyone with any experience or comments on the risks there may be
I don't know anything about that store, but I've heard horror stories along the lines of what mdavej mentioned regarding a lot of shady outfits in NYC. I've mainly read about them with regards to camera equipment, but the deals with electronics are the same. They offer an amazing price, well below what others typically do, then try to hook you with accessories, or say that model is out of stock but offer the one above it, then give you the run around if you do place the order. It's an endless nightmare. This definitely falls in the realm of if it sounds too good to be true, then it isn't.
Originally Posted by pbarach View Post
Apparently FedEx fixed my AVR, because Panurgy said they could't duplicate the complaint, cleaned up my AVR and sent it back without either of these problems (so far).
But... somehow my front left and right channels were now out of phase with each other. I know this wasn't the case before I sent the unit for repair, because my speaker cables are carefully color-coded, and I used the same test tracks (from a THX OptiMode DVD) to check this today as I used the last time I hooked up the AVR to the speakers. Anyway, I reversed the cables on one of the speakers, ran the phase test to make sure the five speakers were all in phase, and everything is working fine.
And miracle of miracles, I was able to reload my config file after only 3 tries
I reran Audyssey tonight since I added some stuff to the room and moved things around, and now it says my center is out of phase. I just ignored it. I ran the test twice and got the same error, and I don't know why it would think that. Had a similar issue with some other speakers where it often said the left was out of phase. I'm not sure what the deal is, but ignoring it seems fine.
Keith Mickunas is offline
post #8252 of 12688 Old 07-19-2014, 10:48 PM
pbarach's Avatar
Quoted: 323 Post(s)
Liked: 196
I wouldn't buy from Abe's unless Denon lists them as an authorized dealer. I did buy a couple of cameras from them. They were an authorized dealer, and I had no trouble with bait & switch or anything else with the sale.
My x4000 phase issue was unrelated to Audyssey. I did the tests using test tones from a reliable test source. The front speakers were out of phase with each other after their round trip to Panurgy, but they were in phase before the trip and with all the cables connected the same.
pbarach is offline
post #8253 of 12688 Old 07-20-2014, 07:28 PM
sofakng's Avatar
Quoted: 30 Post(s)
Can anybody give me any hints why my second zone isn't working?
I've purchased a refurbished AVR-X4000 so maybe it's defective but it's also possible I've configured something wrong.
Anyways, my second zone is just two speakers on my outside patio and I have them connected using the Surround Back L/R terminals. On the receiver, I've received "5.1ch + ZONE2" under Amp Assign. However, if I turn on Zone 2 and play anything it appears to be playing but I have no sound. I've verified that the speakers work because if I swap the primary Front L/R with my patio speakers it plays fine.
Do I have to configure anything else?
sofakng is offline
post #8254 of 12688 Old 07-20-2014, 07:47 PM
jdsmoothie's Avatar
Quoted: 12264 Post(s)
Liked: 5593
Is the source you are playing stereo 2.0? Is the source HDMI, digital, or analog? If HDMI, do you have ALL ZONE STERO selected or HDMI audio (Zone 2) set to "PCM" (p. 194 Owner's manual)?
jdsmoothie is offline
post #8255 of 12688 Old 07-20-2014, 07:56 PM
sofakng's Avatar
Quoted: 30 Post(s)
I'm using the built-in DLNA Media Player to play an MP3 off my network drive, and I've tried the built-in SiriusXM client. I only have speakers attached to Zone 2 and I don't have any HDMI cables, etc.
In General/ZONE 2 setup, HDMI is set to Through and Channel is set to Stereo.
It seems like I'm missing something because I never told "Zone 2" to use "Surround Back L/R" ...
sofakng is offline
post #8256 of 12688 Old 07-20-2014, 08:04 PM
jdsmoothie's Avatar
Liked: 5593
When AMP ASSIGN is set to "5.1 + Zone 2" the SBL/SBR speaker posts default to Zone 2. Power on Zone 2 using the remote and select the source you want to pass.
post #8257 of 12688 Old 07-20-2014, 08:08 PM
sofakng's Avatar
Quoted: 30 Post(s)
I'm using the web interface since the receiver is in my basement and the speakers are outside on my patio. I've also used the official Denon iOS application.
I'm worried the receiver is defective because it sounds like I'm doing everything correctly...
Also, I just received the receiver about two weeks ago and I did multiple microprocessor resets as suggested in the FAQ because the unit was refurbished.
sofakng is offline
post #8258 of 12688 Old 07-20-2014, 08:28 PM
jdsmoothie's Avatar
Liked: 5593
With the network source playing in the main zone, set Zone 2 to ON and to "Source" and if still no joy, it would seem you got a defective refurbished unit.
post #8259 of 12688 Old 07-21-2014, 04:09 AM
almgren's Avatar
No sound u nless CBL/SAT or TV turned on
OK, I have a starnge thing. I just changed my sat box, and now it seems that the Denon X4000 does not priduce any sound unless the box or my TV is turned on (one of them is sufficient).
I set my Denon to play radio, but no sound comes out unless one of these 2 is turned on.
I tried to turn on my Blue Ray but that has no effect,
There must be a setting somewhere I have missed
christian
almgren is offline
post #8260 of 12688 Old 07-21-2014, 04:14 AM
jdsmoothie's Avatar
Liked: 5593
This occurs with some TVs in the chain. First try a soft reset, but setting the X4000 to Standby and then unplugging the power cord for 10 minutes. Then try the radio. If still no joy, try disconnecting the cable box to see if that is the culprit. If yes, connect the cable box (HDMI) to the TV with cable box (optical) to the X4000.
post #8261 of 12688 Old 07-21-2014, 04:53 AM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Try changing the "through" setting to "pcm".
Tom Grooms is offline
post #8262 of 12688 Old 07-21-2014, 06:30 AM
JZ50's Avatar
Sk76
Would definitely give AVS a call for Denon pricing. Purchased X4000 awhile back and received great price and great service!!
ambesolman likes this.
JZ50 is offline
post #8263 of 12688 Old 07-21-2014, 08:41 AM
jollyguy23's Avatar
HI,
A newbie question. I purchased the x4000 recently and trying to set things up. I ran the audessey last night. Since i have the def tech fronts with the sub built in (and two dedicated subs), i was following instructions on page 1 of this thread to set the fronts from Large to small. The issue is i do not know where to set this to small? Also any recommendations for crossover? I have a 7.2 set up (two dedicated subs and not the ones from the def tech fronts).
Thanks in advance for the help!
jollyguy23 is offline
post #8264 of 12688 Old 07-21-2014, 08:51 AM
jdsmoothie's Avatar
Liked: 5593
Use the Setup - Speakers - Manual Setup to set the FL/FR to SMALL/60Hz or SMALL/80Hz whichever you prefer.
post #8265 of 12688 Old 07-21-2014, 08:58 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 57
Apologies if this is a redundant question, did a search but couldn't easily find an answer. I bought the X4000 as a temporary replacement for my AVP pre-amp that went off to the shop for repair. The plan is to move the 4000 to my second system when I get the AVP back. AVP went in becaue the center channel was having issues...
The 4000 is having similar issues, be it watching TV from my Shaw Arris PVR or watching my Roku & Netflix, the center channel from their dolbly digital feeds totally craps out. The dialog becomes totally inaudible. The only way to hear it is to switch the 4000 into stereo mode.
Anyone have an idea what may be the cause or remedy? Did I trip onto a defective 4000?
rnrgagne is offline
post #8266 of 12688 Old 07-21-2014, 09:06 AM
jollyguy23's Avatar
Thanks so much. Just one follow up question. DO i have to run audessey again after making this change? I assume NO but want to confirm. Thanks once again!
post #8267 of 12688 Old 07-21-2014, 10:02 AM
jdsmoothie's Avatar
Liked: 5593
Correct. No you do not.
post #8268 of 12688 Old 07-21-2014, 10:11 AM
jdsmoothie's Avatar
Liked: 5593
Try swapping the FL and center speakers to see if the issue is the center speaker. If not, then reset the microprocessor (p. 225). And if still no joy, then exchange it.
post #8269 of 12688 Old 07-21-2014, 12:06 PM
asarose247's Avatar
Quoted: 705 Post(s)
Liked: 468
first, thanks to jd for a good price, smooth transaction and speedy delivery.
the short question and one problem at a time : when selecting with the music button, ALL I EVER GET IS STEREO MODE, using my cable hookup at a source, so What am I missing?
thanks
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #8270 of 12688 Old 07-21-2014, 01:00 PM
jdsmoothie's Avatar
Liked: 5593
Press/hold the MOVIE or MUSIC buttons to get all the available surround modes. Also make sure your cable box is set to pass DD 5.1.
post #8271 of 12688 Old 07-21-2014, 01:00 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
thanks
Hi asarose, try holding down the Music button and it will pop up with additonal option.
JChin is offline
post #8272 of 12688 Old 07-21-2014, 01:34 PM - Thread Starter
batpig's Avatar
Quoted: 3581 Post(s)
Liked: 3422
@asarose247 -- See also here: http://batpigworld.com/wp/?p=150
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #8273 of 12688 Old 07-21-2014, 11:03 PM
asarose247's Avatar
Quoted: 705 Post(s)
Liked: 468
thank you, jd, batpig and Jchin
as I figured, the problem is . . . me
here is a "I wonder what would happen wrt optimization . . .
I use Sub 1 out to feed 1 channel of my Inuke6000 running the SubMaximis, I've got some DSP eq done there but it needs re-checking wrt the new X4000
Sub 2 is split, one leg feeds a signal to a BASH 300 running the 2 Clark shakers on my couch and the other leg feeds a BASH 300 pushing a 30" THTLP
I can run the Sub EQ and turn things on/off so the system can do the best work for each sub and then I suppose, run it again with them both on.
this is a which came first chicken or egg ? and each room and setup is different but anyone with any such back and forth experience is invited to speak up and put their .02 in
curious to hear what's been discovered . . .
thanks
addendum : some other info
Until I can wire the 2 THTLP's together (yes there is a second one) in a series parallel config to run off the other channel of the Inuke (at 8ohms I can still get about 1K to drive both and no they will not be co-located, it just more wire as my entire room is 14+ x 28 and total volume is 5Kft^3 . Too much just might be enough.
post #8274 of 12688 Old 07-22-2014, 06:12 AM
sofakng's Avatar
Quoted: 30 Post(s)
OK - So I was able to get "5.1ch + ZONE 3" but for some reason if I use "5.1ch + ZONE 2", I don't get any audio from the speakers. (I also tested setting Amp Assign to 7.1 and the SBL/SBR also worked fine with the test tones, etc)
Any idea what could be causing zone 2 to not work?
It doesn't matter because I can just use zone 3 instead of zone 2, but I'm still worried about the possibility of my receiver being defective.
sofakng is offline
post #8275 of 12688 Old 07-22-2014, 06:23 AM
Quoted: 31 Post(s)
Liked: 6
Originally Posted by JZ50 View Post
Sk76
Can you share the price if it's ok
Sk76 is offline
post #8276 of 12688 Old 07-23-2014, 10:06 AM
Liked: 0
AVR-X4000 multizone issues
Guys I have bit of a problem; i am only using one zone - the main zone; however i get no audio from speakers off the cable hdmi until zone 2 is turned on. The volume etc is still being controlled by main zone but the moment i turn zone 2 off speakers go dead.... any help would be appreciated
apiasecki is offline
post #8277 of 12688 Old 07-23-2014, 11:11 AM
jdsmoothie's Avatar
Liked: 5593
If Zone 2 is powered ON and not passing any source, then you may want to try a soft reset (unplug for 10 minutes) and if still no joy, a microprocessor reset (post #5 of this thread).
post #8278 of 12688 Old 07-23-2014, 11:12 AM
jdsmoothie's Avatar
Liked: 5593
What is the AMP ASSIGN setting on? What speakers are connected? Have you tried a soft reset (unplug power cord for 10 minutes)?
post #8279 of 12688 Old 07-23-2014, 11:53 AM
sofakng's Avatar
Quoted: 30 Post(s)
Will the microprocessor reset erase my settings and MultEQ configuration?
Also, yesterday the receiver completely locked up on me. The physical zone on/off buttons worked but the IR, RS232, and web gui commands didn't respond. I unplugged the receiver for 5 seconds and plugged it back in and everything is working again.
I'm still a little concerned the refurbished unit I received might be defective...
Are random lockups somewhat normal? (i.e. a known issue)
sofakng is offline
post #8280 of 12688 Old 07-23-2014, 12:13 PM
jdsmoothie's Avatar
Liked: 5593
Yes, all settings are returned to factory defaults, although you can use the SAVE/LOAD procedure as noted in post #4 of this thread. Random lockups can happen from time to time, but are not a "known" issue. If you are concerned, call Denon and have exchange the unit for another refurb.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
