The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 286 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #8551 of 12688 Old 08-13-2014, 03:11 PM
ambesolman's Avatar
Quoted: 1078 Post(s)
Liked: 901
Originally Posted by ultimate_ed View Post
Hey folks,
Been enjoying my X4000 in my home theater since I got it from AVS a few months ago. But, there's one thing going on with it that I'm having trouble understanding.
I've found that, even though I don't have the volume limit set, it will never allow me to go above -6. When I try to turn it up beyone that, it will flash -5 on the display and then immediately go back to -6. It doesn't trip or give any indication that it is overheating, it just won't physically let me go beyond that, even though the manual indicates the top of the range should go to +18.
Now, I rarely go much above -10 with the setup that I have, but it has proven a bit of an annoyance when I really want to crank it. Is my receiver going into some kind of protection mode? I have been through the manual several times but I can't find something that would explain this behavior.
If this is using Airplay to stream from an iPhone, then normal, otherwise if with all sources, try a soft reset (unplug power cord for 10 minutes).
Yeah it's annoying, but I've found a couple of workarounds...
1) if you have an airport express, you can play through that without any limitation. You won't get the onscreen info though. Plus you can also stream through its wireless signal even if your internet goes out.
2) using the DeRemote app doesn't have this limitation but tops at "0". Has tons of other controls as well and worth the $5 IMO.
Hope this helps
ultimate_ed likes this.
ambesolman is offline
post #8552 of 12688 Old 08-13-2014, 03:21 PM
jdsmoothie's Avatar
Quoted: 12257 Post(s)
Liked: 5589
Originally Posted by roscolo View Post
I'm getting ready to add an amp to my Denon AVR-x1000 to drive my zone 2 speakers on the porch (2 polk patio200's, same as atrium 5's). I've seen recommended here for this purpose is the AudioSource amp100. I'm prepared to buy the amp100 today. First, a few questions:
Is there anything as good and cheaper than the amp100? I see these $30 - $50 miniamps. Don't know anything about 'em. I like the small size. Is there one of these miniamps that would work as well as the Amp100?
Looks like the Amp100 automatically shuts off and turns on when it detects a signal. I could see that being a huge advantage on a Zone 2 amp. Unless there is a long pause in the music. Anyone know how long a pause before the amp100 shuts off?
The Amp100 is $140 new on Amazon. It's $106 for a refurb from Amazon Warehouse. Any reason not to get the refurb?
Yes, the AMP 100 is a good choice, although it normally sells for $100 most of the year so not sure the reason for the sudden upsurge in price.
jdsmoothie is offline
post #8553 of 12688 Old 08-13-2014, 03:35 PM
ultimate_ed's Avatar
Now that you mention it, it has been during Airplay streaming when I've found myself hitting that volume level. I've not gone that high when watching a Blu-ray.
Did I miss that somewhere in the manual? Seems an oddly particular limitation.
Sent from my XT1060 using Tapatalk
ultimate_ed is offline
post #8554 of 12688 Old 08-13-2014, 03:38 PM
avkiller's Avatar
Quoted: 12 Post(s)
Hi,
I am just about to pull the trigger on a x4000, I would like to run two satellites and a svs sb-1000 sub on zone two. As the receiver has no sub pre out for zone 2 the only possible way I can see to do this (apart from buying another amp) is to run zone two speaker out to the high level speaker level input on the sub and then on to the satellites from there.
Would this work with zone 2 on the x4000 and if so how do you think the sound quality would compare to having a cheap secondary amp with sub pre out to run zone 2?
Appreciate the help.
avkiller is offline
post #8555 of 12688 Old 08-13-2014, 04:12 PM - Thread Starter
batpig's Avatar
Quoted: 3581 Post(s)
Liked: 3422
Originally Posted by avkiller View Post
Hi,
That method will work fine, and it's specifically the point of having high level (speaker wire) inputs/outputs on the subwoofer. That's how subs integrate with basic 2ch stereo setups without formal digital bass management capabilities -- which is basically what Zone 2 is.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #8556 of 12688 Old 08-13-2014, 04:14 PM - Thread Starter
batpig's Avatar
Liked: 3422
It's not mentioned in the manual AFAIK but I don't think it's an AVR restriction per se... I don't think anyone knows the root cause but it seems to only occur specifically when doing Airplay from an iDevice. So the limitation may be on the other side.
Setup Guide and FAQ
batpig is offline
post #8557 of 12688 Old 08-13-2014, 04:55 PM
avkiller's Avatar
Quoted: 12 Post(s)
Do you know if it would make any difference if I wire it from the Amp to the Sub and then from the sub to the Speakers instead of 2 separate sets of wires going from the amp to the sub and speakers?
Its a fairly long run of about 65ft to the zone 2 area.
Hope that makes sense :-)
avkiller is offline
post #8558 of 12688 Old 08-13-2014, 05:09 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
It would make most sense to go directly to the sub first, then to the speakers. You wouldn't want to connect both the speakers and the sub to the receiver's speaker outputs.
Also when doing this you might look at 4 wire speaker cable. Monoprice and others have it, just basically four wires in one jacket, that'd be excellent for running from a receiver to the sub. Then you only have to pull one cable over that long distance.
ambesolman, nmad and avkiller like this.
Keith Mickunas is offline
post #8559 of 12688 Old 08-13-2014, 05:12 PM
sofakng's Avatar
Quoted: 30 Post(s)
One more question (sorry)...
I'm trying to get the 12v trigger outputs working and I'm using a multimeter to measure the voltage.
Trigger Out #1 is measuring 8v and Trigger Out #2 is measuring 12v. However, I have everything set to "Off" in the Trigger setup menu. What am I doing wrong?
If I use the RS232 commands "TR1 OFF" and "TR2 OFF" then the voltage goes to 0v but I'm not sure what I'm doing wrong.
sofakng is offline
post #8560 of 12688 Old 08-13-2014, 06:10 PM
gimpy's Avatar
Quoted: 23 Post(s)
Ok, buttons on Denon remote working fine now. Just needed to reed manual a little slower/closer :-\
Frank, "Still the one"
gimpy is offline
post #8561 of 12688 Old 08-14-2014, 12:15 AM
jdsmoothie's Avatar
Liked: 5589
Posts 1-6 provide helpful information
As a reminder ... on page 1 of this thread ....
Post 1-2: Features of each model
Post 3 - General info + Troubleshooting tips
Post 4 - Issues discussed in thread
Post 5 - Microprocessor/Network reset procedure
Post 6 - Firmware change log information
post #8562 of 12688 Old 08-14-2014, 08:11 AM
Dan in St. Louis's Avatar
Quoted: 128 Post(s)
Liked: 39
I don't know how your sub is wired, of course, but I recall some that recommended the method above. There were high-pass filters in the connections in the sub enclosure to the existing speakers, and low-pass filters matched to the same corner frequency for the sub. That reduced distortion in the stereo speakers because they no longer suffered the long cone motions from low bass.
---- Dan in Saint Louis
Dan in St. Louis is online now
post #8563 of 12688 Old 08-14-2014, 08:14 AM
Quoted: 128 Post(s)
Liked: 39
I noticed the same thing. The internal logic of the receiver interprets all "---" as all "ON." Set each trigger so some unused input is set "ON" and you will get the behavior you expected. See also message 8314.
post #8564 of 12688 Old 08-14-2014, 08:16 AM
mzaur's Avatar
Quoted: 12 Post(s)
Hey guys,
Just got an X1000 setup with 5.0 and am overall very happy with it. I'm just not clear on what the sound modes are (pure, movie, etc). The manual isn't very helpful in this regard.
If my source is DTS and I have Direct on, vs. Movie mode with the DTS SURROUND setting, what's the difference? Are the sound modes only useful to convert stereo to surround or do they also help when the input is surround? Which do you guys use for movies?
Cheers
mzaur is offline
post #8565 of 12688 Old 08-14-2014, 09:12 AM
jdsmoothie's Avatar
Liked: 5589
Direct - Audyssey OFF
DD/DTS - Audyssey ON
Generally you'll never want to use Direct or Pure Direct
mzaur likes this.
post #8566 of 12688 Old 08-14-2014, 09:24 AM
ndskurfer's Avatar
Quoted: 40 Post(s)
Liked: 52
I'm thinking of simplifying my processor end of the system by going from separates to a receiver. Any shortfalls in moving from an Outlaw 7500 amp (emotiva umc-200 processor) to a X4000 receiver and no external amp? I'm driving JTR T8-LP's. I don't listen at reference, but mainly concerned about dynamic range during high impact scenes. Main use is for movies.
Also, looking at the 4520, but the only additional benefit I will get is the added power, but wondering if that will matter?? My speakers are 98db efficient, but at 4 ohm... Would like to make the X4000 work at the current price, should I be looking at the 4520.
ndskurfer is offline
post #8567 of 12688 Old 08-14-2014, 12:05 PM
sofakng's Avatar
Quoted: 30 Post(s)
Thanks! I'll have to fool around with it a bit more when I get home tonight.
It's extremely unclear about how it's meant to work. The manual and UI sound like enabling anything to "ON" will cause it to turn on the trigger. For example, if you set "MAIN ZONE" to "ON" and "CBL/SAT" to "ON", then either turning on the main zone or switching the input to CBL/SAT would cause the trigger to turn on.
You can also set "MAIN ZONE", "ZONE 2" and "ZONE 3" to "ON" all at the same time which supports my theory but I'm still very confused on how it's meant to work.
Your description makes it sound like everything set to "ON" must be activated before the trigger will turn on. (i.e. "MAIN ZONE" set to "GAME" won't activate the trigger, but "MAIN ZONE" set to "CBL/SAT" will)
sofakng is offline
post #8568 of 12688 Old 08-14-2014, 12:32 PM
Quoted: 128 Post(s)
Liked: 39
Yes, that has been my experience. If "MAIN ZONE" and "AUX1" are "ON," then "MAIN ZONE + AUX1" will trigger -- but not "MAIN ZONE + DVD" or "ZONE 2 + AUX1."
That is, it is an "AND" function, not "OR."
post #8569 of 12688 Old 08-14-2014, 01:11 PM
jdsmoothie's Avatar
Liked: 5589
The X4000 will likely meet your needs power wise. The 4520CI is the flagship model mfr'd in Japan with better quality components and 32 bit DACs and 4 Zone capability able to power 4-ohm speakers to reference volume levels without additional amplification.
post #8570 of 12688 Old 08-14-2014, 01:14 PM
sofakng's Avatar
Quoted: 30 Post(s)
Hmmm, why does it let you select multiple modes then?
For example, you can set MAIN ZONE, CBL/SAT, and GAME all to ON. However, MAIN ZONE can only be CBL/SAT or GAME so the trigger condition will never be met?
sofakng is offline
post #8571 of 12688 Old 08-14-2014, 01:48 PM
ndskurfer's Avatar
Quoted: 40 Post(s)
Liked: 52
Thanks for your quick response. No concerns on power on higher impact scenes with the x4000 if running at -10db to -15db for movies? The other specs I'm ok with. The 4-ohm at reference claim for the 4520 vs x4000 is the only item that has me concerned, even though I will not be running that hot, I also don't want to tax it near its limit..
post #8572 of 12688 Old 08-14-2014, 01:54 PM
jdsmoothie's Avatar
Liked: 5589
Not likely at that speaker sensitivity, however, I wouldn't let go of the Outlaw amp until that has been confirmed.
post #8573 of 12688 Old 08-14-2014, 02:07 PM
Quoted: 128 Post(s)
Liked: 39
My best guess is that it is because you might want to trigger something on more than one Source or Zone, like (MAIN ZONE) AND (CBL/SAT or Blu-ray) for a projector.
post #8574 of 12688 Old 08-14-2014, 03:58 PM
sofakng's Avatar
Quoted: 30 Post(s)
I think you're right... I've just tested it and it appears there are three groups:
Zone
Source
HDMI Monitor
If you select two sources in the trigger setup, either one being selected will satisfy the criteria and turn the trigger on.
I'm left with one last problem. Trigger #2 works perfectly as described, but trigger #1 shows 8v when it's on and 12v when it's not. For example, with the exact same trigger settings, trigger #2 will show 12v and trigger #1 will only show 8v.
I'm using a mono 6' cable.
sofakng is offline
post #8575 of 12688 Old 08-14-2014, 04:44 PM
pbarach's Avatar
Quoted: 323 Post(s)
Liked: 196
I get better dynamic range using a Carver m1.0t (200 wpc) for my front left and right channels than I do with the x4000--and this is in stereo (not MCH) with reasonably efficient 8 ohm speakers (and a sub) playing at around -20 dB in a small, well-damped room. The Carver is perhaps a little bright in my system, but Audyssey completely tames that.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #8576 of 12688 Old 08-15-2014, 07:07 AM
Padinn's Avatar
Quoted: 26 Post(s)
Hey folks,
I have the Denon AVR-X2000 and for my birthday picked up a few new speakers to enable the 7.1 sound. I have questions regarding crossover frequency and speaker setup. My setup currently is:
Pioneer FS-52 FR/FL speakers
Harman Kardeon TS-16 5.1 system (4x SAT-TS11 for Surround Speakers, Cen-TS11 Center, HK-TS 210SUB)
You can find specs on the HK stuff here:http://www.harmankardon.com/images/m...or16_OM_EN.pdf
I ran Audessey and it set the crossover frequency for all the HK speakers to 150hz, but the LFE remained at 120 hz. I think this means I'm losing 30hz of sound from the surround system. Should I up the LFE to 150 hz, or lower the crossover frequency on the satellites to 120hz?
I do have all speakers set to small. Thanks in advance for the guidance.
Padinn is offline
post #8577 of 12688 Old 08-15-2014, 07:13 AM
jdsmoothie's Avatar
Liked: 5589
LFE (20Hz -120Hz) is the .1 in 5.1/7.1 audio and is separate from what goes to the speakers so 120Hz is the default LFE setting and should remain there or be lowered if desired.
post #8578 of 12688 Old 08-15-2014, 07:15 AM
nmad's Avatar
No, the LPF for LFE should remain at 120 hz because this is only for the LFE channel.
edit: jdsmoothie was faster :P
Sony VPL-HW40ES || 108" Projecta Screens HD Progressive 0.9 || Denon AVR-X2000 || 2x Dali Zensor 3 || Dali Zensor Vokal || 2x Dali Zensor 1 || SVS PB-2000
nmad is offline
post #8579 of 12688 Old 08-15-2014, 07:18 AM
Padinn's Avatar
Quoted: 26 Post(s)
Okay thanks for the guidance. If I reduce the crossover frequency on the surrounds from 150hz to 120hz, am I going to lose any sound range?
Maybe I'm just thinking about it wrong and if left to 150 it will be fine.
Padinn is offline
post #8580 of 12688 Old 08-15-2014, 07:28 AM
Padinn's Avatar
Quoted: 26 Post(s)
I did find this review:
http://www.soundandvision.com/conten...glance-ratings
Which gives some guidance on the frequency range of the center and satellite channels.
Padinn is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
