The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 287 - AVS Forum | Home Theater Discussions And Reviews
 396Likes
post #8581 of 12686 Old 08-15-2014, 07:30 AM
Dan in St. Louis's Avatar
Quoted: 128 Post(s)
Liked: 39
Originally Posted by sofakng View Post
I'm left with one last problem. Trigger #2 works perfectly as described, but trigger #1 shows 8v when it's on and 12v when it's not. For example, with the exact same trigger settings, trigger #2 will show 12v and trigger #1 will only show 8v.
That sounds like hardware failure. If you are willing to put together a test cable, connect the "tip" of the mono plug (center conductor) to a 1000 ohm resistor, then in series to the + side of an LED, and the - side of the LED to the shell of the plug (ground). The LED will light when "triggered," showing that the trigger output can deliver at least 10 milliamps to the load. Test it on both outputs to be sure it is wired right.
If it doesn't light, try the "pull-the-power-cord" soft reset. If that doesn't work, try the "three-front-panel-buttons" (page 225) hard reset. If that doesn't work, the receiver is defective.
---- Dan in Saint Louis
Dan in St. Louis is offline
post #8582 of 12686 Old 08-15-2014, 07:34 AM
nmad's Avatar
Originally Posted by Padinn View Post
Okay thanks for the guidance. If I reduce the crossover frequency on the surrounds from 150hz to 120hz, am I going to lose any sound range?
Maybe I'm just thinking about it wrong and if left to 150 it will be fine.
Please read this, it will help you understanding bass management.
Sony VPL-HW40ES || 108" Projecta Screens HD Progressive 0.9 || Denon AVR-X2000 || 2x Dali Zensor 3 || Dali Zensor Vokal || 2x Dali Zensor 1 || SVS PB-2000
nmad is offline
post #8583 of 12686 Old 08-15-2014, 08:09 AM
Padinn's Avatar
Quoted: 26 Post(s)
Thanks read through it. I think I understood some of it. Looks like the general recommendation is 120hz for the smaller speakers I'm using.
Padinn is offline
post #8584 of 12686 Old 08-15-2014, 08:23 AM
nmad's Avatar
The SAT-TS11 satellite speakers have +/- 3" drivers and the following specifications: "The –3-dB point is at 188 Hz, and the –6-dB point is at 166 Hz."
In this case a higher crossover is needed for the satellite speakers. I would recommend 200 Hz. Leave the LPF for LFE at 120 Hz, this has nothing to do with the crossovers for the speakers.
nmad is offline
post #8585 of 12686 Old 08-15-2014, 08:45 AM
Padinn's Avatar
Quoted: 26 Post(s)
Thank you - very helpful for me.
Padinn is offline
post #8586 of 12686 Old 08-15-2014, 09:12 AM
jdsmoothie's Avatar
Quoted: 12242 Post(s)
Liked: 5576
If a speaker crossover is set to 150Hz, then by reducing it to 120Hz, you end up with the 120Hz - 150Hz band being un EQ'd, so the moral is you can always "raise" a crossover, but never "lower" it. You may want to try doing several Audyssey EQs as each one may be a little different depending on the mic positions used, all of which should be no more than 2-3' from the main listening position mic #1.
Regardless of the mfr's -3db specs, the speaker's crossover will be set based on how it reacts in your room, so if the speaker gets set to 150Hz, there is no reason to raise it higher unless you feel it sounds better by doing so. Generally the only crossovers you will want to raise are those set < 80Hz which you will want to raise to 80Hz and set the speaker to SMALL if set to LARGE.
jdsmoothie is offline
post #8587 of 12686 Old 08-15-2014, 01:10 PM
Temexter's Avatar
Liked: 0
Send a message via Skype™ to Temexter
Question AVR-X2000 washed colours after turn / HDMI passthrough
Hello gents (and ladies :-)
I have a annoying problem with AVR-X2000 and Panasonic TX-P42G20.
When i turn on my TV, the amp automatically turns on and sets input to CBL as set in setup (Video/HDMI Setup/HDMI Control). My Motorola IPTV box is always on. Naturally Motorola box is connected to "CBL/SAT" HDMI port and amp HDMI output to Panasonic HDMI2 (ARC). HDMI cables are high speed compatible, v1.4.
Everything works. But. After turning amp on, when Motorola box is already on the picture is significantly "washed out". Going to amps setup and back fixes the colors. I have tried changing Video/Output Settings/Video Mode, Video Conversion On/Off and activated i/p Scaler with diffrent settings with no avail :/ Moreover, setting amp's i/p scaler on does not produce proper picture with any settings, instead it is washede out and very greyish. Picture mode in TV is THX, which is in fact very nice...
Exactly same thing happens when i turn off the amp and IPTV box's signal is passed through to TV (HDMI settings are properly set).
Sometimes when i turn on the amp, it lacks sound from IPTV box. Turning off and on the amp fixes this, turning off/on the IPTV box or any settings (there's no options for HDMI and only picture setting is mode, which is set to 1080p50) does not.
Anyone having similar problems. With Panasonic Viera - or any TV?
I would really appreciate any hints or ideas, as this is quite annoying, although not game breaking
Denon AVR-X2000 | Front Wharfedale Diamond 7.2 Anniversary Edition | Center, Side & Back Panasonic SC-DT310 "set" | Panasonic Viera TX-P42G20 Silver | Yamaha HPH-200
Temexter is offline
post #8588 of 12686 Old 08-15-2014, 04:20 PM
ambesolman's Avatar
Quoted: 1077 Post(s)
Liked: 901
Guess this means that the set of sats I use for heights that audyssey set with a 250hz crossover, than my sub is trying to play up that high?
ambesolman is offline
post #8589 of 12686 Old 08-16-2014, 11:33 AM
Padinn's Avatar
Quoted: 26 Post(s)
That's my understanding (anything below 250 will be passed to your sub)
Padinn is offline
post #8590 of 12686 Old 08-16-2014, 05:08 PM
ArTourter's Avatar
Question Flickr not working
Has anyone encountered any issues with flickr and the X4000? Somehow it doesn't seem to work at all for me (cannot find any contact name, nor can it browse the all contents part) Other network functions work fine on the unit (internet radio). I have updated to the latest Firmware in case it was a know bug but to no avail. Any pointer would be appreciated.
Cheers
ArTourter is offline
post #8591 of 12686 Old 08-16-2014, 06:16 PM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
My x4000 has turned off automatically a few times recently. I've read of every possible problem. I have checked and fastened all wire on both ends. I some times hear crinkly sounds and that makes me think loose/frayed wire but I hear it in the middle of the room, I can't localize it. I have 14 gauge for the front and 16 gauge for the surrounds.
Help!
Main room (3D blu ray, PS4) - LG 65EG9600: Denon x4000, Klipsch RC-62II, RF-62II x2, RS-41II x2, SVS PC-12NSD + Klipsch RW12d
Couple small LCDs - PS2, PS1, Dreamcast, N64, 3DO, Saturn and other various retro game collections MINT COMPLETE games
Teremei is offline
post #8592 of 12686 Old 08-17-2014, 01:45 AM
jdsmoothie's Avatar
Liked: 5576
Help!
At what volume level? Does it do it with nothing connected to the AVR? Try disconnecting all speakers and add one back at a time to see if there is a short in one of the speakers.
post #8593 of 12686 Old 08-17-2014, 02:31 AM
Teremei's Avatar
Quoted: 468 Post(s)
Liked: 201
So a short in the actual speaker (not the wire?). I seem to hear it more toward the left SR. So I will look closely at that one first. Volume from -20 - reference. So no specific volume level, and it can go 45 minutes without happening so it's hard to test. I get my new klipsch surrounds next week so hopefully it's just one of my old polk bookshelves.
Teremei is offline
post #8594 of 12686 Old 08-17-2014, 04:29 AM
pbarach's Avatar
Quoted: 323 Post(s)
Liked: 195
Help!
Mine turned off and went into protection mode a number of times beginning about 7 months after purchase. I checked to make sure none of the connections were shorting out--they weren't. I mailed the unit to Panurgy for warranty service. They said that they cleaned the unit but could not duplicate the problem. Nevertheless, it somehow got fixed--I have had the x4000 back online for several weeks without any repetition of the problem.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #8595 of 12686 Old 08-17-2014, 09:00 AM
ambesolman's Avatar
Liked: 901
Mine kept shutting off too. Ended up being a loose connection inside a banana plug
post #8596 of 12686 Old 08-17-2014, 09:19 AM
whatupdet's Avatar
Quoted: 25 Post(s)
I bought a new X1000 back in May/June and I'm having troubles getting my blu-ray player to work on it. It did work but it's finicky and I've now tried 2 different blu-ray players and 2 different HDMI cables and the cables work because when I use it for my laptop-receiver it works. I tried setup assistant to see if I could get picture and audio through Denon but no go.
whatupdet is offline
post #8597 of 12686 Old 08-17-2014, 11:15 AM
jdsmoothie's Avatar
Liked: 5576
If the BDP has a Deep Color Output setting, set it to OFF. Also just because an HDMI cable works with one component is no guarantee it will work with another component.
post #8598 of 12686 Old 08-17-2014, 04:37 PM
Greg_Di's Avatar
Hi Everyone,
I had the X2000 for a few months now and it was working perfectly. I just had a weird issue happen.
I was playing Fifa 14 on PS4 and during the game the audio spiked and got really loud (did this by itself) and then the sound went out. I reset the unit and now it does not seem to be working.
The issue is when I turn on the AVR I got popup on my TV saying no signal detected ensure external device is connected to TV. Now when I turn off the AVR and have my PS4 on the image returns with no sound(even though the PS4 is only connected to my receiver) as soon as I turn the receiver back on screen goes black and I get the popup.
I tried different HDMI cables for both input and output on the receiver. I tried checking my other inputs (these are also not working as same popup comes up, was working fine yesterday) and I also did a soft reset.
Also when I used to turn on the Denon and just the TV with no external sources on, I would always get the Denon splash screen on my TV. This does not show up now and the remote for the denon will not let me access my setup.
Any idea what could be happening here?
Greg_Di is offline
post #8599 of 12686 Old 08-17-2014, 04:41 PM
jdsmoothie's Avatar
Liked: 5576
Try doing a soft reset (unplug unit for 10 minutes).
post #8600 of 12686 Old 08-17-2014, 05:18 PM
Greg_Di's Avatar
I have tried and still same thing. I want it to come back even for a few minutes so that I can backup my settings before trying a microprocessor reset.
Greg_Di is offline
post #8601 of 12686 Old 08-17-2014, 05:26 PM
jdsmoothie's Avatar
Liked: 5576
post #8602 of 12686 Old 08-17-2014, 06:58 PM
jhachey's Avatar
Quoted: 27 Post(s)
I am using the Zone 2 outputs on my X4000 to power a pair of Klipsch KHO-7 outdoor speakers mounted on the wall under the eaves on my back patio. The patio is about 15 feet by 15 feet with the prime listening area about 10 to 15 feet from the speakers. The Klipschs do a pretty reasonable job (and it's not like my goal is to blow the neighbors away with my music), but I've begun to wonder how much better they might sound if I bought a passive subwoofer with a built-in crossover to filter the low frequencies, allowing the Klipschs to focus on the middle and high end.
Any thoughts / suggestions?
jhachey is offline
post #8603 of 12686 Old 08-17-2014, 07:07 PM
jdsmoothie's Avatar
Liked: 5576
You'd want to buy a "powered" subwoofer with both input/output speaker posts, although if playing only music, may not be much of a difference.
post #8604 of 12686 Old 08-17-2014, 07:22 PM
jhachey's Avatar
Quoted: 27 Post(s)
I only play music on the patio, so maybe not worth the effort / cost?
jhachey is offline
post #8605 of 12686 Old 08-17-2014, 07:34 PM
ambesolman's Avatar
Liked: 901
Depends on if they play low enough for you at the levels you listen. I have the Polk atrium sat30/sub10 set on my deck. The sat has only a 3.5" mid behind a 3/4" tweeter so it won't play as low as yours will alone. But they are wired into the sub10 which had a 10" diver and a 200w amp. While it doesn't play as low as my HT sub (hsu vtf 3), it sounds great and I always have enough bass regardless of volume.
Really depends on if they put out enough bass on their own to YOU. Can't hurt to try if you've got money to burn
post #8606 of 12686 Old 08-17-2014, 08:26 PM
Greg_Di's Avatar
I have read through the troubleshooting and faq but none list my problem. I cannot even get into the setup when the receiver is on, remote not responding. Only let me switch outputs. When I turn the AVR off the video comes back (even though it shouldn't since all my external devices plug in through avr) as soon as I turn it on video is gone
EDIT:
I tried the micro processor reset and still nothing, it looks like it is not detecting the HDMI out. Looks like I will have to call Denon tomorrow
Greg_Di is offline
post #8607 of 12686 Old 08-18-2014, 06:25 AM
jdsmoothie's Avatar
Liked: 5576
If you have tried at least 4-5 microprocessor resets in a row and still have the issue, then yes, time to call for warranty repair. Check Denon's website to see if there are any authorized repair facilities in your local area.
post #8608 of 12686 Old 08-18-2014, 06:46 AM
almgren's Avatar
OK, A while ago I asked abot my X4000 that needed either TV och Tivo to be turned on to play any sound.
NOw I did a soft reset, to no avail
I then really started to go through each and every settig in the setup, and here is the fun of it.
I had Trigger Out turned ON, when it shoule be OFF
If I removed The Tivo box it worked good anyway, but when I inserted the Tivo it started its strange behavior
solution: Turn Trigger Out to off.
Christian
almgren is offline
post #8609 of 12686 Old 08-18-2014, 07:38 AM
Neverlies's Avatar
I've begun having relatively frequent HDMI handshake issues with my DirectTV satellite box, resulting in either no video signal, no audio signal, or neither (which seems to be the new norm). Soft resets don't typically fix the problem, only hard resets (I've switched HDMI cables and don't believe that to be the problem).
I have not updated firmware on this unit (purchased new from JD back in May or so) but I'm starting to think these Denons are buggy.
Is there a way to avoid the persistent HDMI handshake issues? I never had them with my Yamaha, and going the route of plugging the HDMI cable directly into the TV and using an optical cable from the satellite box to the Denon pretty much defeats the whole purpose of why I bought it in the first place?
Suggestions?
"The price of apathy towards public affairs is to be ruled by evil men."
Neverlies is offline
post #8610 of 12686 Old 08-18-2014, 09:58 AM
jdsmoothie's Avatar
Liked: 5576
What model DTV DVR are you using? I've had no issues using a DTV Genie with my X4000. Have you tried changing the power on sequence? What generally works best is to power on TV first, wait 4-5 seconds, AVR, wait 4-5 seconds, then finally the DTV box.
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
