The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 297 - AVS Forum
post #8881 of 8883 Old Today, 10:19 AM - Thread Starter
batpig's Avatar
Quoted: 573 Post(s)
Liked: 1218
Yes, just set Zone 2 input to "Source" (not available on the remote, but you can do it through the remote app or the web browser) and it will always mirror the main zone.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
batpig is online now
post #8882 of 8883 Old Today, 11:32 AM
Liked: 0
Problem with shut down
As per suggestion I am reposting this here
Oops the name of the receiver didnt carry over- I have the
Denon AVR-E400
Hi All,
I recently purchased this receiver- I just moved into a new house and my bedroom has speakers built into it as does my bathroom. I got the receiver refurbished from amazon and set it up with the bathroom speakers being zone 2. It will play those speakers up to about volume 49 (which is not that loud) - anything higher than that and the receiver shuts itself off (protection mode). I figured maybe I had messed something up so I had a professional installer come out and look at it, he couldn't get it to work as zone 2 but ran the bathroom speakers into the same port as the regular front speakers and it seemed to be working (though not multizone). Then this morning it shut off and went into protection mode again. Looking around online there seems to be many people having the same problem, some recommend going to a Dennon repair place but there is none in Nevada. I should note that prior to this I used my roomates old receiver and it ran all the speakers fine (but was not multi zone) so I can't imagine its a speaker/wire problem.
I have about one week before my amazon return period is up- so my question is is there something I can do to fix this? If not does anyone have a rec for a lower end multizone receiver?
Any help would be appreciated, thanks
To answer the questions asked there
Where are the most reports of common failure? Is it general shutdown or zone2 use only?
I can play the main zone (the 5.1 in the bedroom) at ear shattering volume and it never shuts off. It only shuts off when I play the bathroom speakers in zone 2- those play up to about volume 49 (which is not that loud) and once I go louder the receiver shuts off in a minute or less
Start with the basics. Can you connect just two speakers to the main zone front and play loud in each room by itself?
Yes
Is it a failure only when using zone2 or only when both zones are being used at the same time? Try to isolate what
connection scenarios work and what changes/additions were made to cause the shutdown.
It will shut off with just zone 2 when wired that way. This morning when the speakers were all set to the regular 5.1 (with the bathroom speakers doubled in) it shut off after about 10 minutes of playing (at not a loud volume)
Scott Phillips is online now
post #8883 of 8883 Old Today, 12:09 PM
kikkenit2's Avatar
Quoted: 95 Post(s)
Liked: 79
Scott, so far only the surround back/zone2 speaker binding posts are failing? Try reassigning those two channels to
surround back and see if still shuts off. Try to identify the speaker model/specs being used. The ohm ratings
are the most important. So you are saying zone2 fails even when zone1 is off (2 speakers driven only) or only
when all seven are playing together. Just 2 speakers only is really bad. Defective. Only when all 7 driven. Maybe not.
kikkenit2 is online now
Denon Avr 2309ci Receiver , Denon Avr4310ci Receiver , Denon , Denon Electronics , Polk Audio Monitor70 Series Ii Floorstanding Loudspeaker , Onkyo Tx Nr626 7 2 Channel Network Audio Video Receiver , Denon Avr E200 , Denon Avr E300 , Denon Avr E400 , Denon Avr X2000 7 1 Channel Home Theater Receiver , Denon Avr X3000 7 2 Channel Home Theater Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Denon Avr X1000 5 1 Channel Home Theater Receiver
