The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 330 - AVS Forum
post #9871 of 9887 Old 12-20-2014, 10:15 PM
Vader424242's Avatar
Quoted: 24 Post(s)
Liked: 44
It's not what is listed in AMP ASSIGN, rather what is listed in the Speakers - Manual Setup - Speaker configuration. If more speakers/subs are added then Audyssey must be run again.
^^^ Thanks!
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is online now
post #9872 of 9887 Old Yesterday, 08:15 AM
robertw11's Avatar
Quoted: 37 Post(s)
So I'm noticing a little bug in either my HTPC or the X2000. I have my HTPC connected via HDMI audio set to PCM, and the PC is set to 7.1. Unfortunately with 5.1 sources the PC or receiver send the rear audio to the surround backs not the rear L/R's as it should. Is there a setting where the X2000 can automatically take 5.1 sources and use Dolby PL for the rear channels to fill out all 7 channels?
Kuro'd
robertw11 is offline
post #9873 of 9887 Old Yesterday, 08:29 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2204 Post(s)
Liked: 1809
Huh? Surround Backs = Rear surrounds
DD PLIIx will simulate 7.1 audio from a 2.1/5.1 audio track.
"JD" – jd@avscience.com ; Direct line 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #9874 of 9887 Old Yesterday, 08:38 AM
mdavej's Avatar
Quoted: 610 Post(s)
Liked: 446
Originally Posted by batpig View Post
Yes, really. Denon got rid of the Channel Level menu for on the fly adjustments a couple of years ago. The newest models have brought it back but in a different form, allowing relative adjustments on the fly to the global baseline levels. But the X4000 generation has ONLY the global adjustment using internal test tones, unless you use an app like DeRemote or have a programmable universal or other control system that can send discrete level commands.
If anyone needs codes, I'd be glad to post them. Not sure if all pronto hex is already somewhere on your site or not. But it's easy enough to pull is from the master list I linked a few posts back.
mdavej is offline
post #9875 of 9887 Old Yesterday, 11:23 AM
Liked: 0
Hello all,
I'm new to this forum and I had a question that's been bugging me for a while now that I hope you guys can help me with.
I'm about to buy a PS4 in the next month coupled with a new 50 inch Sony TV (the Sony 50W805 to be exact) and I want to go all out and get proper surround sound as well so I'm
thinking of getting a Denon AVR X-1000 coupled with a Boston Acoustics XS 5.1 Soundware speakerset (I heard these are supposed to be really nice speakers for the price).
This is my first time I'm getting into ''hifi-audio'' if you want to call it that and I have no experience whatsoever with receivers and the like.
Now my question is basically, for those who have a PS4 and the X-1000, does true 5.1 surround work for you guys? It's been bugging me lately because I'm reading a lot of reports on the web about people not getting proper surround sound on their PS4's and other audio problems. I assume the best way to hook it up to my PS4 and TV would be to use only HDMI cables? I read the best way
to connect it would be connecting the PS4 with an HDMI cable to the receiver, and then an HDMI cable from the TV to the HDMI OUT port from the receiver. Is this correct? And what would be the best settings to use on the PS4?
I have a pretty small room so it might be overkill getting a 5.1 set but there are some amazing games coming out next year and I want to step up my gaming experiences by a big notch.
I'd really appreciate to get a firm combination whether this works 100% correctly or not so I can just buy everything I need next month without worries of it not working correctly because it's going to be a huge purchase I'm making but I want to be truly sure that I won't run into problems with this set.
Thanks very much in advance!
Nerd123 is offline
post #9876 of 9887 Old Yesterday, 12:22 PM
DG_
Quoted: 14 Post(s)
Liked: 0
I'm hoping someone here can help with with an issue I'm experiencing.
I have a Denon X4000 receiver and I am not getting a video signal.
Purchased this receiver recently new from an authorized dealer. Couple days ago I set it up by connecting my speakers, PS4, and running the audyssey calibration. Everything worked fine. I was out a couple of days and today when I turned everything on, I only receive an audio signal, but not video signal. I know the hdmi connection between the receiver and tv is working since I can see the osd when switching to other inputs.
Does anyone know what could be happening? Is the unit damaged?
DG_ is offline
post #9877 of 9887 Old Yesterday, 12:27 PM
Quoted: 24 Post(s)
Liked: 44
Should the unit do this automagically? I noticed the other night that a Dolby Digital 5.1 input did not use PLIIx for the rears. I recall from my 2311CI (what I upgraded from), I had to specifically tell the unit how to decode for the rear surrounds. I cannot find where to do this on the X4000.
Peace... Vader
post #9878 of 9887 Old Yesterday, 12:59 PM
robertw11's Avatar
Quoted: 37 Post(s)
Can I enable that for only one input? In my case my PC input? Or is it a global setting?
If so how do I turn it off if I want to?
And finally, if it's global does it have an effect on 7.1 sources like Dolby True HD, DTS MA, or outputs like DD+ from Netflix that are 5.1?
Thank you again
post #9879 of 9887 Old Yesterday, 08:02 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1809
Yes, if you have previously selected that surround mode for 2.0/5.1 content. Press/hold the MOVIE button on the remote to see the available surround modes.
Vader424242 likes this.
Daily 8am – 8pm EST
post #9880 of 9887 Old Yesterday, 08:04 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1809
Thank you again
Selectable based on audio source and would apply to all 2.0/5.1 sources only as with a 7.1 source, there would be nothing to simulate.
Daily 8am – 8pm EST
post #9881 of 9887 Old Yesterday, 08:05 PM
Quoted: 24 Post(s)
Liked: 44
^^^ Thank you again!...
Peace... Vader
post #9882 of 9887 Old Yesterday, 08:06 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1809
To mitigate HDMI audio/video handshake issues, power on the TV first, wait 5 secs, AVR, wait 5 secs, and then finally source device.
Daily 8am – 8pm EST
post #9883 of 9887 Old Today, 06:52 AM
de8212's Avatar
Quoted: 83 Post(s)
I'm sure this is easy and covered somewhere but some of the terms kinda blend together and leave me a bit confused.
When I turn on my x3000, it says Offset -7db. What does that mean and should I do anything about it?
de8212 is online now
post #9884 of 9887 Old Today, 07:00 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1809
It is the Dolby Digital Dialogue normalization setting which is embedded in the audio track (p. 175 Owner's manual).
Daily 8am – 8pm EST
post #9885 of 9887 Old Today, 07:06 AM
de8212's Avatar
Quoted: 83 Post(s)
thanks jd.
post #9886 of 9887 Old Today, 08:00 AM
Chuck_IV's Avatar
Originally Posted by Chuck_IV View Post
So my X2000 which I had for a little over a year, seems to be developing a mind of it's own. The last couple months it has started doing some weird things.
1) We turn everything off at night and in the morning the receiver is on. It seems to be turning itself on over night.
2) we turn everything on and the X2000 will sometimes decide to turn back off, forcing us to turn it on again. It has also begun to once in a blue moon just turn off while watching TV.
3) From day one, it has always had an issue with My Directv receiver. We occasionally get 1 second blackouts. We have tried changing out all cables and also even tried a different model Directv receiver from another room, but same issue. This has been really getting on our nerves lately, on top of the other oddities.
I have tried numerous resets, going as far as to completely reset to whole unit, clearing it of all settings, but to no avail.
What are peoples thoughts on what I should do with this thing? Send it in for service? I'm just not sure they will see the oddities.
Try doing at least 4-5 microprocessor resets in a row. If still no joy, give a repair center a call.
Well, doing the resets didn't help. I still had the 1 second or so Blackouts and it was still turning off right after turning on. I even double checked it wasn't using the HDMI auto power sync too(I think it has to do with the way it's interacting with ARC on my Samsung TV).
I bought a Yamaha VX-R675 the other day to replace my failing Onkyo in my main TV room. I decided to put the Yamaha in place of the Denon X2000 and move the X2000 down to my main TV room. The Yamaha in place of the Denon no longer has the 1 second blackouts with Directv and doesn't have the sporatic power off issue that the Denon had(Yamaha VX-R675, Directv HR24, Samsung Smart TV, 2013 model).
Now, the Denon X2000 in my main TV room is working perfectly(knock on wood). I don't see the 1 second blackouts anymore with Directv and since this TV doesn't use ARC, no more sporadic power offs(Denon X2000, Directv HR34, Older Non-Smart Sony flatscreen HDTV).
The Denon driving my main TV room is probably the way to go anyway since I have a nice 7.1 setup in there. So all is good now.
Chuck_IV is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
