The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 343 - AVS Forum | Home Theater Discussions And Reviews
 415Likes
post #10261 of 12870 Old 01-25-2015, 01:30 PM
jdsmoothie's Avatar
Quoted: 15085 Post(s)
Liked: 7277
Same level but 5 years newer and likely more features.
jdsmoothie is offline
post #10262 of 12870 Old 01-25-2015, 01:33 PM
biglen's Avatar
Quoted: 109 Post(s)
Well, so much for that. I opened the box, and there is a VSX-40 in the box, not a 44. I'm steaming right now.
biglen is offline
post #10263 of 12870 Old 01-25-2015, 03:56 PM
jdsmoothie's Avatar
Liked: 7277
Makes more sense as to why the price was so low being as it's a 4 year old model.
post #10264 of 12870 Old 01-25-2015, 04:04 PM
biglen's Avatar
Quoted: 109 Post(s)
Someone pulled a fast one on them. When I took it back, we noticed all kinds of dust on the back of the unit, and the Best Buy inspection sheet that was in the box, said it was a VSX-44. The serial number on the sheet, didn't match the receiver either. I ended up grabbing a VSX-524-k for $199, and the audio is working perfect with the AFTV. Thanks again for all the info.
biglen is offline
post #10265 of 12870 Old 01-25-2015, 07:27 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
If you refer to p. 130 in the X2000 Owner's manual, you'll note there is an AMP ASSIGN = Front B setting which can play the same HDMI source as is playing to the Front A speakers.
So the problem is that if it's going to play a *different* source, it can't be HDMI.
Was this changed for the 2014 X2100W?
Thanks again.
Soulburner is offline
post #10266 of 12870 Old 01-26-2015, 03:51 AM
jdsmoothie's Avatar
Liked: 7277
Thanks again.
Correct. And no, rather the X3000/X3100W are the lowest models with this feature.
Soulburner likes this.
post #10267 of 12870 Old 01-26-2015, 05:50 PM
ThomasBorn's Avatar
I tried doing a quick search on this and came up with a sea of craziness so figured folks on here might know. I have a Denon x4000 powering my media room projector (main out) and speakers. Media room sounds and looks great. I then hooked up the other cloned output (not separate zone 2 out) to my living room tv and get no sound on it unless I turn the Denon AVR off since I have the passthrough enabled for sound. Outputs and Inputs are all using HDMI.
1. Can I get sound on both outputs when the AVR is on? Basically I want to be able to have the game on the living room tv and media room with audio in both.
2. If not, I assume I will need to hook my 2nd source cable box to the zone 2 output in order to get the sound in the living room?
ThomasBorn is offline
post #10268 of 12870 Old 01-26-2015, 05:55 PM
jdsmoothie's Avatar
Liked: 7277
1. Nope. HDMI Audio on main zone outputs can be set to either "TV" or "AVR" but not both.
2. Yup.
post #10269 of 12870 Old 01-26-2015, 06:02 PM
ThomasBorn's Avatar
Thanks JD for the quick reply!
post #10270 of 12870 Old 01-27-2015, 06:19 PM
wantamancave's Avatar
My X4000 receiver has arrived and needs much more time then I have available most weeknights after work I'm sure. In preparation for "the big move" I thought I'd ask for a little input. This is to be solely a HT room receiver so advanced output options I'm not concerned with. The watching or playing a game while listening to music from another source does intrigue me though so I will learn that trick. This will be running a 7.1 system of all Polk. The RC85i front, 255c-ls center, RC80i surrounds and rear, the sub is a PSW110. All set to small as always but with such a good tuning program inside what are suggestions for cross over?
wantamancave is offline
post #10271 of 12870 Old 01-27-2015, 10:28 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
I have the X4000. I have three TV's I want to run off it. Two TV's I want to play sound out the speakers attached to the AVR that is located in the same room as the two TV's. My question is, I want to just want to send the source to the third TV and play the sound out of the TV. Do I just hook the third TV to Zone 2 HDMI out? Do I than just turn Zone 2 on when I want to watch that TV?
Thsnks,
Ken
Denon X6200W - Klipsch KLF-10 Fronts - Klipsch KLF-C7 Center - Klipsch KLF-C7 X 2 Surrounds - Klipsch RB-61 II Back surround -OSD ACE850 ceiling x 4 Atmos - Dual HSU VTF-3 MK4 Subs - 4 Dayton Audio BST-1 Bass Shakers with SA230 Amp - BenQ W1070 projector - 106" Antra fixed Screen
Soupy1970 is offline
post #10272 of 12870 Old 01-27-2015, 11:02 PM - Thread Starter
batpig's Avatar
Quoted: 3706 Post(s)
Liked: 3577
Run Audyssey, then afterwards change any large speakers back to small. Also any large speaker will have a default 40hz crossover so you'll probably want to raise those to 60 or 80hz. Everything else just leave as Audyssey sets it.
Side note but you'll probably want to upgrade the sub and/or add a second sub at some point. The PSW110 is pretty mediocre for a dedicated HT.
batpig is offline
post #10273 of 12870 Old 01-27-2015, 11:03 PM - Thread Starter
batpig's Avatar
Liked: 3577
Thsnks,
Ken
Correct, that's the function of Zone 2 HDMI. It's an independent matrix output intended to let you share sources with another HDMI receiver or display in a different room.
batpig is offline
post #10274 of 12870 Old 01-28-2015, 02:06 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
And if I have a TV and some speakers in another room on Monitor 2 / Zone 2, is that volume control independent of the main zone? Basically, can two people use this without changing each other's volumes?
I'm also not sure if you can run Audyssey on Zone 2, so those speakers would have no EQ?
Otherwise, I'm about to pull the trigger on the X3000.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
post #10275 of 12870 Old 01-28-2015, 03:44 AM
jdsmoothie's Avatar
Liked: 7277
1. Yes. Zone 2 volume is independent from main zone volume.
2. Correct. Audyssey only works on main zone.
post #10276 of 12870 Old 01-28-2015, 12:45 PM
joeyvaz's Avatar
Quoted: 73 Post(s)
Liked: 30
I ordered and received my AVR-4000 on New Years Eve. I've set it up and ran Audyssey. All is fine, but I'm having one "issue" I can't figure out. When I want to change the listening mode, I hit the corresponding button on the remote. The sound stops for a moment (as if the mode changes) and the display on the receiver blinks, but the mode stays the same. Doesn't matter if it is on a music or movie mode. Same results. I then connect my Denon App on my cellphone (Note Edge) and I can chose any of the available modes. music stops for a split second, mode changes, and display on AVR corresponds to the mode chosen on my phone.
Bad remote? Or issue with receiver?
joeyvaz is offline
post #10277 of 12870 Old 01-28-2015, 12:56 PM
Randyman...'s Avatar
Quoted: 30 Post(s)
The "Modes" remember whatever sound-field mode you had it in previously IIRC.
So, select "Movie", and then select the desired sound-field mode you want associated with "Movie" (press and hold the MOVIE button to change modes). Then select "Music", and then select whatever sound mode you prefer for Music (press and hold the MUSIC button to change modes).
Now when you recall "Movie" mode, it will recall that last sound-field setting you selected while in Movie mode. Hope I remembered correctly
joeyvaz likes this.
Randyman... is offline
post #10278 of 12870 Old 01-28-2015, 12:58 PM
jdsmoothie's Avatar
Liked: 7277
Yes, the mode will stay the same unless you change the mode by pressing/holding the MOVIE button which will then display all of the available surround modes.
joeyvaz likes this.
post #10279 of 12870 Old 01-29-2015, 06:42 AM
Got the 4000 set up last night and ran Audessey but I think I may have placed the microphone incorrectly. I did front row in three positions, and back row as well. The raised seating bar area is too far away for the mic so I skipped. Surrounds are way too loud for my liking compared to the fronts. I did move the whole setup to low and cross over for fronts is at 80, center is at 120 and the surrounds and rear at 100 which helped the subwoofer. The sub was set at -4db which I brought up to 2 for better fill. Should I just rerun the calibration?
post #10280 of 12870 Old 01-29-2015, 07:09 AM
jdsmoothie's Avatar
Liked: 7277
Are you using a camera tripod or mic boom stand with the mic at ear height or above seat backs (whichever is higher)? All 7 additional mic positions should ideally be no more than 2' from the #1 main listening position (ie. primary focus is on main listening position).
post #10281 of 12870 Old 01-29-2015, 01:12 PM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
I got a refurbished X1000 from accessories4less. The first one was completely defective. No video or sound at all, so I exchanged it for another. Just hooked the replacement up and it started doing the thing where it thinks the headphones are plugged in off and on. I blew into the headphone jack and it worked for a while, then I heard a click and the sound went out for a second then came back. I then got a q-tip with alcohol and swabbed around inside the headphone jack. It's good so far, I'm just a little worried. Could it be a more serious problem that a lil dust or am I okay with keeping this one?
UPDATE - Did it again after the q-tip thing. Grrr
squeakybirnbaum is offline
post #10282 of 12870 Old 01-29-2015, 02:20 PM
ryangs's Avatar
I'm going to be setting up an E400 for my parents, and want to check my understanding of the Zone 2 feature. They'll have 5.1 in the main room and stereo (zone 2) in the second room. The sources they'll want to play simultaneously are TiVo, FM radio, CD and AirPlay. That means I'll need to run analog (RCA) cables from the TiVo in addition to the HDMI, correct? FM should work, I assume. The CD player is analog, so that's also fine. What about built-in AirPlay? Am I missing anything here?
They have a Logitech Harmony remote, which I figure I'll be able to program to seamlessly turn on Zone 2 for the proper sources. Any gotchas here?
Thanks in advance for any advice.
ryangs is offline
post #10283 of 12870 Old 01-29-2015, 02:31 PM - Thread Starter
batpig's Avatar
Liked: 3577
Your understanding is correct. Although note that if they just want to be able to output Tivo to BOTH zones simultaneously, you don't actually need the analog cables, because the All Zone Stereo feature can broadcast ANY signal to Zone 2 simultanous with main zone. If they want fully independent Zone 2 output for the Tivo, then yes you will need the analog RCA's.
The built-in network streaming (like Airplay) already goes to Zone 2 natively, so no worries there. The only "gotcha" is that Airplay streams initially "hijack" the main zone, so for example if someone is watching the Tivo in main zone, and wants to play music to Zone 2 via Airplay, when the Airplay connection starts the main zone will switch away from the Tivo and lock onto the Airplay stream. At that point, you can manually turn on Zone 2 and select Airplay as the Zone 2 source, and then you can switch main zone back to the Tivo and Airplay will continue in Zone 2.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10284 of 12870 Old 01-29-2015, 02:48 PM
ryangs's Avatar
Originally Posted by batpig View Post
...Although note that if they just want to be able to output Tivo to BOTH zones simultaneously, you don't actually need the analog cables, because the All Zone Stereo feature can broadcast ANY signal to Zone 2 simultanous with main zone..
Oh, interesting. I'll have to play with that. No 5.1 in the main zone when you're doing this, right?
ryangs is offline
post #10285 of 12870 Old 01-29-2015, 03:53 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 986
Right.
I wrote a simple macro (4 or 5 steps I think) for my remote to toggle all zone with one button press since no discrete command for that exists.
mdavej is online now
post #10286 of 12870 Old 01-29-2015, 04:07 PM - Thread Starter
batpig's Avatar
Liked: 3577
Right, it basically creates a stereo downmix for all zones, so when All Zone Stereo is active the main zone is restricted to either be stereo or multich stereo surround mode.
Setup Guide and FAQ
batpig is offline
post #10287 of 12870 Old 01-29-2015, 04:16 PM
joeyvaz's Avatar
Quoted: 73 Post(s)
Liked: 30
Thanks, that was it. I was thinking it would react the same as my Onkyo 818 whereby pressing the button toggles through the available modes.
joeyvaz is offline
post #10288 of 12870 Old 01-29-2015, 05:50 PM
ambesolman's Avatar
Quoted: 1098 Post(s)
Liked: 921
No, that would make too much sense
Sent using Tapatalk since the mobile version is still
ambesolman is offline
post #10289 of 12870 Old 01-29-2015, 11:16 PM
Liked: 0
Separate balance for all chan stereo?
In AVR-X4000 the front/surround balance is off in the all channel stereo mode (mid-rear and far-rear surround speakers dominate the front). If I adjust their levels in setup, the back surround is almost not present when watching movies. Is it possible to set the speaker levels/balance per sound mode?
Azaqui is offline
post #10290 of 12870 Old 01-30-2015, 07:47 AM - Thread Starter
batpig's Avatar
Liked: 3577
It's Dynamic EQ. It boosts the surrounds (in addition to adjusting freq response) to maintain surround immersion during movies. But not appropriate for all ch stereo listening.
Instead of adjusting surround levels which (as you found) also mucks up movie performance, either turn DEQ off for all ch stereo listening or adjust the Ref Level Offset parameter to 10-15db which will tone down how much DEQ is boosting. You could also try some of the other music surround upmix modes like Pro Logic II Music.
batpig is offline
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
