The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 413Likes
post #10441 of 12830 Old 02-11-2015, 11:52 PM
Peterpack's Avatar
Quoted: 78 Post(s)
Liked: 34
I just did the latest firmware update on my X3000
Anyone have any idea what has changed with this firmware ?
Peterpack is offline
post #10442 of 12830 Old 02-12-2015, 12:30 AM
jdsmoothie's Avatar
Quoted: 14565 Post(s)
Liked: 6914
Originally Posted by DaveyMac View Post
Thanks for the link , I think I figured it out. 0 is reference on movies. I just needed to offset it by 10. Still loud, but I can see that maybe being 'reference'
This has me really stumped though... I saved 'offset -10db' and -25 volume' to quick set button 1 on avr.... When I go from another quickset back to it - it momentarily displays 'OFFSET - 7db" on the AVR????? The 'source level' is set at 0, so it's not that. And as I said the DynEQ is set at -10db offset.
First note that for most, average TV watching volume is likely -40db to -20db and average movie/music listening volume is likely -30db to -10db. A very small minority will be able to listen at full reference movie volume of 0db as it is too loud in the home. The "Offset - 7db" you are seeing is the Dolby Digital Dialog Normalization offset embedded in the DD audio track and not something that can be changed. It can vary in range.
jdsmoothie is offline
post #10443 of 12830 Old 02-12-2015, 12:32 AM
jdsmoothie's Avatar
Liked: 6914
Firmware change log information is provided in post #6 when it becomes available.
post #10444 of 12830 Old 02-12-2015, 07:55 AM
mdavej's Avatar
Quoted: 2222 Post(s)
Liked: 972
Wow, do you know of a link that shows how to cast such wonderful spells? (i.e. program remote to do this)
Attached is a little screen shot of Remote Master and every possible Denon function added to my Charter remote.
http://www.hifi-remote.com/wiki/
mdavej is online now
post #10445 of 12830 Old 02-12-2015, 08:56 AM
family_man's Avatar
Originally Posted by family_man View Post
trnovak,
I am glad you posted. Interesting experiment you tried. I am coming to the conclusion as well that the Denon X4000 doesn't know how to handle the PS3 in zone 2. For me, it seems logical that when my Denon X4000 has zone 2 on the PS3 as a source and asking for PCM, it should request a different mix from the PS3 to allow for my 2 channel setup. Unfortunately its not.
Interesting to hear that the XBox 360 doesn't suffer that problem. I have an older cheaper blu-ray player at home that I might try that to see what the X4000 will do with it.
To follow up on my own experiment, last night I hooked up my older samsung blu-ray player and it worked as I hoped/expected. It pushed out DTS Master to zone 1 speakers until zone 2 was engaged, at which point it pushed stereo to both zones that could be easily understood.
So I guess there is just a bug in the X4000 (and maybe others) that doesn't work well with the PS3.
family_man is offline
post #10446 of 12830 Old 02-12-2015, 11:32 AM
scotsman8's Avatar
Quoted: 12 Post(s)
at the weekend I connected my Denon X4000 to my network and did the latest firmware upgrade. I have left it connected to the network and when I turn the amp on now it switches to direct airplay mode on its own, after I switch it back to the source I want it keeps switching itself to direct airplay mode again. After a few fights back and forth between me and the amp it eventually stays on the source that I want. After that it starts turning the volume down on itself and kind of the same process as the source change. I have unplugged the network cable and it appears that its acting right again.
scotsman8 is offline
post #10447 of 12830 Old 02-12-2015, 05:00 PM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
First time using the X4000 as a 5.1 receiver with my Xbox One. I'm confused on what the regular 5.1 (no effects besides Audyssey) mode is and where it is. Is it labeled "Multi ch in'? Not direct mode, but I'm playing a video game and just want the pure sound that Audyssey has calibrated.
james9120 is offline
post #10448 of 12830 Old 02-12-2015, 05:13 PM
jdsmoothie's Avatar
Liked: 6914
Whatever the audio that is playing ...Dolby Digital or DTS. Set Xbox to "straight decode" and Discovery to off.
post #10449 of 12830 Old 02-12-2015, 07:04 PM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
I have the Xbox on 5.1 uncompressed with discover off, thanks. So it should automatically play just the uncompressed 5.1 signal all the time?
post #10450 of 12830 Old 02-13-2015, 03:58 AM
Tom899's Avatar
Quoted: 91 Post(s)
Liked: 27
Lip-Sync - Need Help Please
I have a Denon x4000, Sony 40ES projector, Darbee Darblet, OPPO BDP-103 , a couple of TiVo's, Dune Smart Player, etc...
I'm having Lip-Sync issues.
My sound is following the video. The x4000 seems to only adjust for audio delay (unless I'm missing something) which is going the wrong way.
My Oppo will go both ways but that's the only device.
Do any of you have ideas on how I might fix this?
-Tom
Tom899 is offline
post #10451 of 12830 Old 02-13-2015, 04:57 AM
jdsmoothie's Avatar
Liked: 6914
Yes, if you want to see DD/DTS as a surround mode, otherwise if the source does the uncompressing, you'll only see Mult CH IN regardless of whether DD/DTS.
james9120 likes this.
post #10452 of 12830 Old 02-13-2015, 05:00 AM
jdsmoothie's Avatar
Liked: 6914
AVRs only adjust for delay as the lip sync issue (if any) is usually caused as a result of the video processing being done by the AVR (which is why when the AVR does no better of a job then the TV itself, best to turn any AVR video processing off). Try setting Setup - Video - HDMI Set Up - Auto Lip Sync (p. 162 Owner's manual) to OFF. If still no joy, try setting Setup - Video - Output Settings - Video Conversion to OFF, noting that in doing so you will lose the Master Volume display on the TV as well as the GUI will no longer overlay on the source video, but rather on a black screen.
post #10453 of 12830 Old 02-13-2015, 06:18 AM
Tom899's Avatar
Quoted: 91 Post(s)
Liked: 27
Thanks JD, I will try these and report back. Appreciated!!
-Tom
Tom899 is offline
post #10454 of 12830 Old 02-13-2015, 06:24 AM
scotsman8's Avatar
Quoted: 12 Post(s)
anyone know whats going on with this?
post #10455 of 12830 Old 02-13-2015, 08:02 AM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
Did you try a factory reset? Or the microprocessor reset? Make sure your audio settings are backed up first.
Can someone explain what "reference" means to me like I'm 5? I read through the FAQ and still don't really understand it. What would you recommend for video games?
post #10456 of 12830 Old 02-13-2015, 08:13 AM
Dan in St. Louis's Avatar
Quoted: 159 Post(s)
Liked: 57
It is an arbitrary sound level that can be used to adjust the gain of different sources so they all play back at the same level. According to this post it would be about 105dB SPL (Sound Pressure Level) on peaks, which means 75 - 85dB average on most styles of music.
It is pretty loud -- more than my wife likes<G>!
---- Dan in Saint Louis
Dan in St. Louis is offline
post #10457 of 12830 Old 02-13-2015, 08:30 AM
jdsmoothie's Avatar
Liked: 6914
It's a movie volume level you would expect in a movie theater from 85db-105db (115db LFE). On the AVR, reference is noted as 80/0db depending on which scale you are using. As a general rule, you never want to go above this level, and in fact it's a good idea to set the Volume Limit to 80/0db (if not set lower) to ensure no one accidentally doesn't raise it above that level.
post #10458 of 12830 Old 02-13-2015, 02:42 PM
GrandPixel's Avatar
Quoted: 164 Post(s)
Liked: 44
With the AVR-E300, is it possible to place the unit in a closet or somewhere out of view, and connect a remote infrared receiver/transmitter placed next to the tv?
GrandPixel is offline
post #10459 of 12830 Old 02-13-2015, 03:08 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
I use an IR Repeater from Amazon and it works perfectly.
I would want my AVR to have airflow, so I wouldn't put it in a tight, closed space. Mine is on a shelf in the next room.
Soulburner is offline
post #10460 of 12830 Old 02-13-2015, 03:30 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
This has probably been asked, but:
If I buy used from Amazon instead of refurbished, do I still get what's left of the warranty?
post #10461 of 12830 Old 02-13-2015, 10:20 PM - Thread Starter
batpig's Avatar
Quoted: 3693 Post(s)
Liked: 3544
No. Warranty is non transferable for used receivers. Although if you were buying from a private party and they gave you the original purchase receipt you'd probably be fine.
You want to be carful. Amazon is an authorized dealer for new product, but Amazon Warehouse is not. An open box from an authorized dealer will carry full warranty, a refurb from an authorized refurb dealer will have 1yr warranty.
Soulburner likes this.
batpig is offline
post #10462 of 12830 Old 02-13-2015, 11:59 PM
jdsmoothie's Avatar
Liked: 6914
Can you post a link to the IR Repeater as I'm sure other members would be interested as well?
post #10463 of 12830 Old 02-14-2015, 05:11 AM
de8212's Avatar
Quoted: 287 Post(s)
I noticed my x3000 said it had a fw update the other day. I didn't do it because I wanted to come here and see if others had updated and if there were any issues. This morning I was just looking at the web interface of the denon on my ipad. I accidentally clicked the Web Update button on the firmware tab. I wasn't even it the same room as the denon. By the time I got in there I noticed it was in a powercycle loop over and over. It did this about 15 times before I Got annoyed and just turned it off for a minute. Seems fine after I turned it on but I'm curious what might have happened!?
de8212 is offline
post #10464 of 12830 Old 02-14-2015, 08:08 AM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Before I got my URC Remotes set up I used http://www.amazon.com/X10-Powermid-P...id+ir+extender and they worked great. It is IR to RF then back to IR in your equipment room. One thing I liked about these is they have an actual power cord instead of ugly wall warts
bgoering is offline
post #10465 of 12830 Old 02-14-2015, 02:30 PM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
Does anyone else feel like Audyssey sets the surrounds too loud? Maybe its just me. I ran it exactly has instructed by the Audyssey page and the FAQ here
post #10466 of 12830 Old 02-14-2015, 02:35 PM - Thread Starter
batpig's Avatar
Liked: 3544
That's Dynamic EQ, it's ambiguous to use the term "Audyssey" as a generic because there are really multiple complementary features.
What DEQ does is well explained in the FAQ as is how to use Reference Level Offset to tone down what it's doing. By adjusting the RLO to 10 or 15 you will probably find a happy place where DEQ is maintaining a nice sense of surround immersion without annoying overboost, regardless of the volume you are listening at. You may then want to twiddle the sub up a few dB since you will also be diminishing the freq response boost portion of DEQ.
batpig is offline
post #10467 of 12830 Old 02-14-2015, 03:05 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
This is the one I use, but there are many others. Search for "IR Repeater":
http://smile.amazon.com/C2G-40430-Ac...ds=ir+repeater
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
post #10468 of 12830 Old 02-14-2015, 07:42 PM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
I played with this a bit, it makes video games 10 times better. I guess I'll leave it on 0db for movies, and 15db for video games.
post #10469 of 12830 Old 02-14-2015, 08:47 PM
bradenmcg's Avatar
Quoted: 13 Post(s)
I'm looking to upgrade an old AVR-789 to something more modern. I don't really care about Atmos, no way I'm going to run more wires and screw with more speakers at this point. Already have a 7.1 setup (surround back pair). Speakers are all Axiom, fronts are M80v2 or v3 so they are nominally 4 ohm speakers (although supposedly they are efficient enough to not put most Denons into protection - I didn't have any problems with the 789 and these speakers.
At this point I'd rather do a used / refurb / open box and top-end model, just for the extra features. The X4000 has come down quite a bit and can be had for $700-800 if you look around.
OTOH, the 4520ci is only around $1k.
Are the newer Denons (X-series) less tolerant of 4 ohm speakers? The 789 didn't have trouble with the M80s, even watching BD's pretty loud, but I've seen people saying that the X4000 is only good for 6-8 ohm and I don't want my AVR overheating/shutting off. That had me considering the 4520, plus the 4520 would allow me to bi-amp the M80s since it is a 9-amp receiver, or I could use the extra two channels for front height (no way I'm going to screw with additional rear speakers at this point, but front would be easy enough to cable & place).
Another wrinkle is the Marantz SR7008 - it seems to be basically an X4000 with 2 extra channels and theoretically better amp stages. There happens to be one selling near me for just under $1k (used, good condition). Should I jump on this instead of a 4520ci?
bradenmcg is offline
post #10470 of 12830 Old 02-15-2015, 04:59 AM
jdsmoothie's Avatar
Liked: 6914
Although there are numerous brands of IR repeaters on the market, not all work with Denon AVRs. The point of my post was to ask for a link of one that is actually being used with a Denon AVR and so proven to work.
assistance , dead , Denon , Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1 , receiver , support
