The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #10711 of 12688 Old 03-01-2015, 11:57 AM
eurovw89's Avatar
Quoted: 14 Post(s)
Help with an issue:
My equipment:
TV - Panasonic 65gt60
Bluray - Panasonic DBT 330
AVR - Denon x4000
My issue is I started to watch Fury last night and have 'just' the video cut out during high action gun scenes.......but still have audio, power, etc...
I had tried still with issue:
1. Swapping out HMDI cables from Bluray player to AVR
2. Swapping out inputs on the AVR for the Bluray
3. Firmware updates on both AVR and player
4. Turned off all HDMI control
What I tried with no issue:
1. Plugging Bluray directly to TV
2. Play same movie (same scene) thru PS4
3. Play two different movies on Bluray player with no issues
I am wondering if it is a conflict between the player and AVR......has anyone seen, heard, or have any input? Anything would be greatly appreciated.
Jeff
eurovw89 is offline
post #10712 of 12688 Old 03-01-2015, 12:23 PM
nitra's Avatar
Liked: 56
Sounds like it's an issue with Cinavia. I've seen this happen before with other blurays.
What device are you playing Fury back from?
nitra is offline
post #10713 of 12688 Old 03-01-2015, 12:26 PM
eurovw89's Avatar
Quoted: 14 Post(s)
I played Fury on the Panasonic player which is where the issue is.....but play it on PS4 on issue
eurovw89 is offline
post #10714 of 12688 Old 03-01-2015, 12:28 PM
nitra's Avatar
Liked: 56
Odds are 95% it's Cinavia, you won't get a fix until they send out new firmware for the Bluray player.
Cinavia is an embedded copy protection, there was a brand new version that came on the Fury BR, hence the reason you're likely having an issue with it.
nitra is offline
post #10715 of 12688 Old 03-01-2015, 12:35 PM
eurovw89's Avatar
Quoted: 14 Post(s)
Even though my PS4 plays it correctly?
eurovw89 is offline
post #10716 of 12688 Old 03-01-2015, 12:38 PM
nitra's Avatar
Liked: 56
Yes, Sony were the ones that made Cinavia
nitra is offline
post #10717 of 12688 Old 03-01-2015, 12:44 PM
eurovw89's Avatar
Quoted: 14 Post(s)
yes, sony were the ones that made cinavia
lol...thats crazy and sucks. they should send out the update before they release the movie
eurovw89 is offline
post #10718 of 12688 Old 03-01-2015, 01:01 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
If it worked correctly plugging your blue-ray player directly to TV I wouldn't think cinavia would necessarily be the issue though it could be. It could also be some other HDCP type of issue where the content protection is not being passed correctly between TV (display device) and blu-ray when blu-ray is connected through AVR. I have seen bad HDMI cables cause this. To rule this out please connect blu-ray player you are having a problem with to the cable your PS4 is hooked up with and see if it plays. If that works replace HDMI cable between your player and the AVR.
bgoering is offline
post #10719 of 12688 Old 03-01-2015, 01:41 PM
eurovw89's Avatar
Quoted: 14 Post(s)
I have two spare HMDI cables and tried them both from the player to the AVR still same issue. I even played it in the PS4 and plugged it into the Bluray input
eurovw89 is offline
post #10720 of 12688 Old 03-01-2015, 02:27 PM
nitra's Avatar
Liked: 56
I wouldn't read too much into it, it's likely just copy protection gone wonky, at least you have another player that works correctly.
nitra is offline
post #10721 of 12688 Old 03-01-2015, 02:28 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
bgoering is offline
post #10722 of 12688 Old 03-01-2015, 02:42 PM
james9120's Avatar
Quoted: 98 Post(s)
Liked: 24
Just had a small panic attack about my refurbished X3000.
Turned it on and no inputs were working, and the only buttons that would work on both the remote and receiver were the input buttons. Setup button and everything didn't work.
Unplugged it for a few minutes and everything is back to normal. Weird.
james9120 is offline
post #10723 of 12688 Old 03-01-2015, 05:04 PM
ambesolman's Avatar
Quoted: 1078 Post(s)
Liked: 901
Help with an issue:
My equipment:
AVR - Denon x4000
Jeff
Haven't had this happen during a movie, but have when changing inputs. Most commonly when I've been listening to music then go to watch tv. All will be working fine for about a minute, then the screen goes black but still have audio. Only thing that fixes it is changing to a random input then back to TV and it works fine. Annoying yes, but easy to fix. Worth a try.
Sent using Tapatalk since the mobile version is still
ambesolman is online now
post #10724 of 12688 Old 03-01-2015, 07:25 PM
Keenan's Avatar
Quoted: 2219 Post(s)
Liked: 2017
I have a question about heat dispersion. I'm in the process of changing all my equipment around and trying to decide where to put what. My rack is a SANUS EFA31 which looks similar to the image below, I'm actually going to setup two separate racks side by side but that's not important,
I've made changes to it such as using 12" vs 8" pillars in a couple of sections.
My question is, will 2" of top room be enough for the X4000 with this style setup, considering that in the very near future, at a minimum, the front 3 channels will be driven by an external basic amplifier?
I suspect that it is but I wanted to see if the community had any comments, thanks!
Keenan is online now
post #10725 of 12688 Old 03-01-2015, 07:27 PM
nitra's Avatar
Liked: 56
I would want to make sure there's at least 3" on top of the unit free space.
That said, 2" likely won't kill anything.
nitra is offline
post #10726 of 12688 Old 03-01-2015, 07:28 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
I have an opportunity to score the X4000 at a really good price, but need some clarification first. I am running a 7.1 system in my living room. The system consist of L/C/R, front heights and dipole for my rear surrounds. I will eventually be adding a projector to the living room to watch movies. I would like to run the second zone to my bedroom with just an HDMI cable. my input sources are Xbox one, Apple Tv, and OTA HD antenna. I really don't want to purchase an external amp right now. So, the questions I have are below.
Can I just run an HDMI to my zone 2 tv (bedroom) and use the tv speakers?
Can I watch different sources at the time in both zones?
Or, do I need to consider a 9 channel amp?
dago52 is offline
post #10727 of 12688 Old 03-01-2015, 08:31 PM
ambesolman's Avatar
Liked: 901
1. Yes
2. As long as they aren't both Hdmi sources
3. No
post #10728 of 12688 Old 03-01-2015, 08:50 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Originally Posted by ambesolman View Post
1. Yes
3. No
Thanks for the input. So just clarify, the second zone cannot use an HDMI source while zone one is active. Doesn't sound it will work in my application. Example, I will be playing Xbox in the living room while the wife is watching Apple Tv in the bedroom. Both sources are connected via HDMI. Is there another option that will allow me utilize two HDMI sources in two zones at the same time?
dago52 is offline
post #10729 of 12688 Old 03-01-2015, 09:03 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
4520ci has 4 zones with zone 4 being hdmi. Zone 4 can watch a different hdmi source than the main zone.
Edit: Look at the first post of this thread as it has a rundown of the key differences between the X4000 and the 4520.
bgoering is offline
post #10730 of 12688 Old 03-01-2015, 09:31 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Thanks, it looks like the 4520ci is a receiver to consider. Any other options that I should consider?
dago52 is offline
post #10731 of 12688 Old 03-01-2015, 09:47 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi dago52, X4000 will perform what you want. I'm watch cable TV in one room (7.1) and another room ATV via HDMI Zone 2 using TV speakers.
JChin is offline
post #10732 of 12688 Old 03-01-2015, 09:50 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Is your cable via HDMI or OTA?
dago52 is offline
post #10733 of 12688 Old 03-01-2015, 09:54 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Cable box via HDMI.
JChin is offline
post #10734 of 12688 Old 03-01-2015, 09:59 PM
dago52's Avatar
Quoted: 104 Post(s)
Liked: 67
Cable box via HDMI.
Can you watch both zones at the some time or only one zone at a time?
dago52 is offline
post #10735 of 12688 Old 03-01-2015, 10:11 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Yes, both at the same time.
ambesolman likes this.
JChin is offline
post #10736 of 12688 Old 03-01-2015, 11:01 PM
ambesolman's Avatar
Liked: 901
Could've sworn jd posted to the contrary in the past, but good to know I'm wrong about it. Thanks for the clarification
post #10737 of 12688 Old 03-01-2015, 11:12 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
It's the lower models that have that limitation.
Soulburner is offline
post #10738 of 12688 Old 03-01-2015, 11:28 PM
DavidBulluss's Avatar
The X3000 does it as well... feature lost from X2000 down.
DavidBulluss is offline
post #10739 of 12688 Old 03-02-2015, 12:55 AM
Keenan's Avatar
Liked: 2017
Yes, I'm thinking 2" would be the bare minimum, and if I feel it's still getting too warm I can always use a silent fan on it.
post #10740 of 12688 Old 03-02-2015, 04:23 AM
jdsmoothie's Avatar
Quoted: 12261 Post(s)
Liked: 5589
The AVR will likely put out the same amount of heat regardless of whether using any on board amps or not as most of the heat comes from the video chip, so you'll likely want to add one or two PC fans to exhaust the heat away from the AVR.
Keenan likes this.
jdsmoothie is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
