The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 359 - AVS | Home Theater Discussions And Reviews
post #10741 of 10766 Old Yesterday, 04:23 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3104 Post(s)
Liked: 2015
Originally Posted by Keenan View Post
I have a question about heat dispersion. I'm in the process of changing all my equipment around and trying to decide where to put what. My rack is a SANUS EFA31 which looks similar to the image below, I'm actually going to setup two separate racks side by side but that's not important,
I've made changes to it such as using 12" vs 8" pillars in a couple of sections.
My question is, will 2" of top room be enough for the X4000 with this style setup, considering that in the very near future, at a minimum, the front 3 channels will be driven by an external basic amplifier?
I suspect that it is but I wanted to see if the community had any comments, thanks!
The AVR will likely put out the same amount of heat regardless of whether using any on board amps or not as most of the heat comes from the video chip, so you'll likely want to add one or two PC fans to exhaust the heat away from the AVR.
Keenan likes this.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVS - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #10742 of 10766 Old Yesterday, 04:29 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2015
Originally Posted by dago52 View Post
I have an opportunity to score the X4000 at a really good price, but need some clarification first. I am running a 7.1 system in my living room. The system consist of L/C/R, front heights and dipole for my rear surrounds. I will eventually be adding a projector to the living room to watch movies. I would like to run the second zone to my bedroom with just an HDMI cable. my input sources are Xbox one, Apple Tv, and OTA HD antenna. I really don't want to purchase an external amp right now. So, the questions I have are below.
Can I just run an HDMI to my zone 2 tv (bedroom) and use the tv speakers?
Can I watch different sources at the time in both zones?
Or, do I need to consider a 9 channel amp?
1. Yes. The X4000 has (3) HDMI monitor outputs, (2) for the main zone(TV + PJ), and (1) for Zone 2.
2. Yes, with the caveat being if you are watching the same HDMI source in both zones, the main zone would be reduced to only 2CH audio as well and if the Zone 2 TV is a lower resolution than the main zone TV (eg. 720p), the main zone would be limited to only 720p as well.
3. Not if using the TV speakers for Zone 2, no. However, if you did want to add Zone 2 speakers, you can use either an old AVR or the following amp connected to the Zone 2 pre-outs:
http://www.amazon.com/AudioSource-AM.../dp/B00026BQJ6
ambesolman likes this.
post #10743 of 10766 Old Yesterday, 04:52 AM
dago52's Avatar
Quoted: 22 Post(s)
Thanks JD. My Apple TV is only 720p (2nd Gen). Will the 4520 allow me to play 1080p (Xbox One) in the main zone and 720P (Apple Tv) in the bedroom at the same time?
dago52 is offline
post #10744 of 10766 Old Yesterday, 05:16 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2015
Yes. No issue when playing different sources. The 4520CI has the added feature of using Zone 4 for the HDMI output, so you can still use Zones 2 and 3 for audio only if you prefer.
post #10745 of 10766 Old Yesterday, 06:11 AM
Liked: 0
X2000 shutting down?
Ok I have a denon x2000 that keeps shutting off at high volume. I have installed computer fans in my media cabinet to no avail. I have 7.1 all klipsch f3/s3. Any tips or suggestions to make it quit? Am I asking to much out of it to sustain 68-74 volume for an extended period of time? I like to have parties and friends control it with their phone and it can get pretty wild. How can I make my receiver keep up with us?!?
Webb24 is offline
post #10746 of 10766 Old Yesterday, 06:52 AM
dago52's Avatar
Quoted: 22 Post(s)
You may want to check your speaker wire. I had the same problem with a Sony and I changed my speaker wire to a 14/2 and it eliminated the shutdowns.
dago52 is offline
post #10747 of 10766 Old Yesterday, 06:58 AM
Liked: 0
I do have pretty thick speaker wire for my front L and front R. Its 12 gauge if im not mistaken. Pretty sure everything else is 14 gauge. Im wiring up more fans now and going to sit them directly on top of the unit. It would be a real pain to change speaker wire as everything is already ran through the wall and such but I am getting pretty desperate to try anything.
Webb24 is offline
post #10748 of 10766 Old Yesterday, 07:03 AM
dago52's Avatar
Quoted: 22 Post(s)
Sounds like your wire is ok. Is the receiver located in a cabinet or closet? If it's in a closet, you may want to add an exhaust fan. I have one installed on a thermostat and it is set to 75 degrees.
dago52 is offline
post #10749 of 10766 Old Yesterday, 07:13 AM
Liked: 0
It is in a cabinet and I have installed two small intake and exhaust fans in it. I am about to load it down with four more fans and see if they make a difference. If not I think I am going to send it in for repair.
Webb24 is offline
post #10750 of 10766 Old Yesterday, 08:06 AM
Doc.'s Avatar
I just received the x2000 recently and mine continuously shuts down at loud volume with my Klipsch rf82 II's. Pretty frustrating.
Doc. is offline
post #10751 of 10766 Old Yesterday, 08:15 AM
Liked: 0
Just curious but is yours in a cabinet or tight closet as well? Or is it for the most part in open air? Oh and I wonder why the hell do these things not have fans built into them? I love the unit as far as airplay and the iPhone app etc. but whats the use in having a 3k system if you can only listen to 50% constant volume reliability?
Webb24 is offline
post #10752 of 10766 Old Yesterday, 08:27 AM
Doc.'s Avatar
I have mine in an open cabinet but have also pulled it out to try and it didn't help.
Doc. is offline
post #10753 of 10766 Old Yesterday, 08:44 AM
Liked: 0
Maybe some others can chime and give us and idea what they experience. I would hate to trade this thing off for something else but the main reason I got it was for parties. I never have any problems with movies or anything 50% volume or less. I will be trying the rest of my fans. I got 4 scrap computer fans that move quite a bit of air that I am going to set on top of it. Don't think my roommate would like me testing it while he sleeps so ill have to wait til later.
Webb24 is offline
post #10754 of 10766 Old Yesterday, 11:23 AM
Liked: 0
Well I think I answered my own question. I put four more fans directly on top of the unit in addition to the four I already added to the cabinet and I couldn't get it to shut down. Granted it wont be truly tested til my next party but I was playing on 74 volume for quite some time. Seems like this thing needs LOTS of moving air when playing at high volume.
Webb24 is offline
post #10755 of 10766 Old Yesterday, 01:13 PM
Wingsbr's Avatar
Man this x4000 sounds great...especially how it eq's the 2 subs. I'm thoroughly impressed with the spacialness, fidelity, and tight accurate bass
Wingsbr is offline
post #10756 of 10766 Old Yesterday, 02:39 PM
Doc.'s Avatar
I guess I'll have to buy some fans and try this myself. Let me know if this has solved your problem completely please. Thanks
Doc. is offline
post #10757 of 10766 Old Yesterday, 04:40 PM
AVS Club Gold
Keenan's Avatar
Quoted: 668 Post(s)
Liked: 562
Yes, I had read earlier that it was the video PCB that was generating most of the heat but figured that the amp section might be contributing some of its own as well. Thanks!
Keenan is online now
post #10758 of 10766 Old Yesterday, 07:28 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2015
You'd be surprised ... the AV8801 gets quite hot and it's a pre-pro.
Keenan likes this.
post #10759 of 10766 Old Yesterday, 07:55 PM
DavidBulluss's Avatar
About a year ago I was running my 2113 at fairly high volumes with music (about +10db or so) through zone 2 only. It started cutting out. Turn off, cool down, back on with the music. Eventually it was cutting out at lower levels and the stench of burning electronics became apparent. I took it in for a service at my local Denon agent. It came back having been fully tested tested, channels tweaked for correct balance, and a sheet saying no faults detected. All done under warranty (unexpected!). Funny thing was that even when the amp was off at the service place I could still smell the burnt electronics every time I turned the remainder of the system on (with a spare amp)... it ended up that the blu-ray player that had been sitting above it in the rack had been singed!. BR player survived, but it is mounted well above the amp! I am now using the 2113 in another system in the house in a music only system and all is perfect, and have bought an X3000 for the Home Theatre system.
Cheers!
DavidBulluss is offline
post #10760 of 10766 Old Today, 12:16 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 78
This video chip - is it the one used for conversion? And does it run cooler if I don't use conversion (I have it off as I have no need)?
*Under Construction*
To: AVR-X4000, Chane A3rx-c, Rythmik L12 (2)
Samsung PN64H5000 Recommended Settings
Soulburner is offline
post #10761 of 10766 Old Today, 01:27 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2015
On average, Denon models generally run only "warm" at best; however, AFAIK, whether video processing is used or not, there is no change in the unit's temp. The new "ECO" mode on the 2014 models can drop the temp as much as 10 degrees when enabled.
post #10762 of 10766 Old Today, 02:35 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 78
If I get bored I'll test it. Until then, I'll take your word for it
How about when people use a Harmony to power on the multi zone models, and it powers on all zones? Wouldn't it use more power vs turning on only the main zone (like with the Denon remote)? IIRC, that is the point of Eco mode - to power off unused amps.
post #10763 of 10766 Old Today, 02:46 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2015
The Harmony can be set to power on only one zone at a time. An AVR is going to draw about 90W when powered on without any load regardless of whether additional Zones are powered on. ECO mode reduces the overall power rather than shutting off unused amps which are always hot when powered on.
post #10764 of 10766 Old Today, 06:37 AM
Liked: 0
I can report that this has completely solved my problem. Had a party last night and couldn't get the thing to cut off at all. I am sure these guys are experts here but I cant see the video processing making any heat. Mine only gets hot at high audio volume with my TV turned off. I had never had it shut off when watching movies or playing video games. I am going to wire my fans to a toggle switch, that way I can have them off when watching movies ( they are kinda loud) and be able to flip them on easily when I want to jam music. I will say it wasnt unit I directly set fans on the top of the unit before I solved this. I tried to add side intake fans and two exhaust fans to my cabinet and it still shut down. Once I added the four directly on the unit blowing down into it would it not shut off.
Webb24 is offline
post #10765 of 10766 Unread Today, 09:15 AM
acex008's Avatar
My AVR-X1100W that I bought refurbed from A4L on January 23, 2015 started power cycling very rapidly on me last night after watching about 15 minutes of video... I hit the power button and unplugged it from the wall. Once I plugged it back in it kept power cycling right away without me even hitting the power button. The front indicator LED would blink red each time it clicked loudly...
A4L is willing to refund my full purchase price if I buy another one and ship my broken one back to them. Trouble is, I'd be out the shipping costs and would have to wait for my refund.
Or I could ship it to a Denon repair shop and Denon would refund my shipping costs. Trouble is, I'd have to wait for it to get shipped back.
What do you guys think I should do?
acex008 is online now
post #10766 of 10766 Unread Today, 11:18 AM
AVS Club Gold
seggers's Avatar
Quoted: 33 Post(s)
Liked: 25
If it were me, I'd ship it to Denon. You're going to have to wait regardless.
Seggers
Mits 73835, Denon X4000, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, the internet, a NAS drive, a TiVo Series 3 and an Oppo 103 (bye bye PS3). There's also a Wii, but we don't talk about that...
seggers is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
