The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 365 - AVS | Home Theater Discussions And Reviews
post #10921 of 10928 Old 03-30-2015, 05:32 PM
bgoering's Avatar
Quoted: 107 Post(s)
Liked: 35
Thanks - so if I need video I would just play to Apple TV HDMI out to AVR in instead? That would put the video to the TV and the audio to external speakers?
I don't really want to use the TV speakers at all...
bgoering is online now
post #10922 of 10928 Old Yesterday, 05:50 AM
de8212's Avatar
Quoted: 114 Post(s)
If you just connect the Zone 2 HDMI Out to the patio TV (using either HDMI or an HDMI to ethernet extender kit), you can use the TV speakers for audio. Only HDMI sources will pass to the Zone 2 TV. If you don't want to use the TV's speakers but instead use a set of Zone 2 stereo speakers, you can connect the Surround Back speaker posts to the Zone 2 speakers and set them in the patio. Set the HDMI Audio (Zone 2) setting to "PCM" if using external speakers and ensure the AMP ASSIGN = 5.1 + Zone 2.
http://www.monoprice.com/Product?seq...FUpp7AodrXIAZA
Thanks. So, the kids could be in the new room watching tv, listening on some bookshelf speakers, etc. and I could be watching tv in my main room like normal. All I'd do is run the hdmi from main room to new room and 2 pair of speaker wires. Connect them to Surround Back and do the settings you mentioned???
I'm just a little confused on exactly how this would work. How do they turn on/off the x3000? Or do you literally have to turn it on in the main room and then go to the new room and turn on the tv and then you have sound?
Sorry for the questions.
de8212 is offline
post #10923 of 10928 Old Yesterday, 05:57 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3383 Post(s)
Liked: 2087
On the X3000, Zone 2 would have to be turned ON and a source selected. This can be done either in the main zone room using the stock remote control or on the X3000 front panel or in the Zone 2 room using a smart phone/tablet remote app.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #10924 of 10928 Old Yesterday, 08:57 AM
johnnymacIII's Avatar
Quoted: 84 Post(s)
I just ponied up for an x4000. I'm coming from a Yamaha rx-v375. I can't wait! Do most of you use this guide for Audyssey? I was only dealing with one position with YPAO on my 375.
http://www.hometheatershack.com/forums/audio-processing/68407-audyssey-multeq-faq-setup-guide.html#/forumsite/20818/topics/68407
johnnymacIII is online now
post #10925 of 10928 Old Yesterday, 09:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2087
Most folks use the Audyssey FAQ here on the forum ....
"Official" Audyssey thread (FAQ in post #51779)
johnnymacIII likes this.
post #10926 of 10928 Old Yesterday, 10:33 AM
Quoted: 84 Post(s)
post #10927 of 10928 Old Yesterday, 11:49 AM
AVS Club Gold
Keenan's Avatar
Quoted: 807 Post(s)
Liked: 628
I have a question about the 12V trigger. On Page 52 of the manual it says,
• If the permissible trigger input level for the connected device is larger than 12 V
DC/150 mA, or has shorted, the TRIGGER OUT jack cannot be used. In this case,
turn off the power to the unit, and disconnect it.
Does that mean if I have a device that will accept voltages between 5-20 volts such as the Emotiva XPA-5 as noted below,
When a trigger cable is connected to the Trigger Input (on the rear panel), and a trigger signal is
received (between 5-20 V - AC or DC), the XPA-5 will switch from Standby to On; when the trigger
signal ceases, the XPA-5 will return to Off.
The trigger is typically connected to the preamp or pre/pro that provides a signal source for the
XPA-5, and set to turn the XPA-5 on when the preamp or pre/pro is turned on.
that the X4000 will not trigger on the XPA-5, because the voltage range is higher(larger) than 12 V?
I ask for clarification as when I connect a monaural cable between the Trigger 1 Out on the X4000 to the Trigger Input on the XPA-5 it does not activate the XPA-5 when the X4000 is turned On from Standby.
On my previous 3806 this connection worked perfectly, albeit it was with Parasound amplifiers and not the Emotiva. Has something changed in the newer model Denons?
Keenan is offline
post #10928 of 10928 Old Today, 05:30 AM
AVS Club Gold
seggers's Avatar
Quoted: 37 Post(s)
Liked: 25
Keenan,
I use my X4000 to trigger, and turn off, my Emotiva UPA5. It has enough kick to get that going. The UPA gets its power from elsewhere.
Seggers
Mits 73835, Denon X4000, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, the internet, a NAS drive, a TiVo Series 3 and a Sony BDPS6200. There's also a Wii, but we don't talk about that...
seggers is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
