The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 369 - AVS | Home Theater Discussions And Reviews
post #11041 of 11041 Old Today, 11:01 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3593 Post(s)
Liked: 2154
Originally Posted by cgott42 View Post
I tried factory resetting 5x - but still didn't bring back to the original setup options as it was when I got it (again, I'm not asking how to go into setup, but wondering if it truly did a full factory reset if it didn't start in the same way it did when received)
Some good news - I tried using HDMI over Zone 2 - and it worked fine! I know that Zone 2 only has 1 HDMI out - but I'm ok with that. Is there any thing I'm missing if I just use it fully as Zone 2, and ignore the main zone 1?
It did do a factory reset if the front panel display flashed when you pressed the appropriate reset buttons and you held them for at least 4-5 seconds. Otherwise, using only the Zone 2 HDMI Out will limit you to only HDMI sources and then only from the rear panel HDMI inputs. Also, if the Zone 2 HDMI out is connected to a TV, the audio from the main zone surround speakers will be down mixed to 2CH stereo only. Have you tried the 2nd main Zone HDMI output?
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
