The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 370 - AVS | Home Theater Discussions And Reviews
post #11071 of 11079 Old 04-25-2015, 09:19 AM
Okiedoke's Avatar
Pull the cable from the AVR's sub pre-out. Rub your finger over the tip. Hear static from the sub? If yes, could be an issue with the AVR. Try resetting the microprocessor on the sub (see post ##5 of this thread). If no, try a different cable.
I could hear a humming when I touched the tip of the cable so I reset the AVR's microprocessor. It works now! Thanks for the suggestions! It looks like before it kept remembering that there was no sub. After the reset, it showed the sub on screen. The bass seems a bit weak though even when I turn the sub volume knob all the way up. Wonder if it's lower wattage of the AVR, smaller driver on the sub, or the combo.
Okiedoke is offline
post #11072 of 11079 Old 04-25-2015, 09:34 AM
Okiedoke's Avatar
I found the sub volume setting in the AVR and turned it all the way up. Still nowhere near the bass of the PSW125 I have in the home theater setup, but I can hear (and actually feel) the bass now without trying.
Okiedoke is offline
post #11073 of 11079 Old 04-25-2015, 11:10 AM
Quoted: 45 Post(s)
Liked: 1
Hello. Is there any specefic mic model for x4000? Or we can use any mic for calibration? And also what is the mic model # and remote model #? Tia.
tapsilog is offline
post #11074 of 11079 Old 04-25-2015, 01:31 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 108
The mics are the same for all models.
http://www.accessories4less.com/make-a-store/item/maracm1h/marantz-acm1hb-audyssey-setup-microphone-for-marantz-onkyo-denon/1.html
Soulburner is online now
post #11075 of 11079 Old 04-25-2015, 02:31 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3706 Post(s)
Liked: 2176
Mic - You can use any of the following Audyssey mics DM-A409, ACM1H, or ACM1HB used on Denon, Marantz, and Onkyo AVRs the past 5 years.
Remote Control - RC1185 (note however, that if you need to purchase a remote, you may want to consider purchasing a Harmony remote instead which can then no only control the AVR but also your other components as well.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #11076 of 11079 Old 04-25-2015, 02:35 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2176
Most owners find that after running Audyssey, they generally prefer raising the subwoofer level about +5db, so you initially want it to be about -7db to -4db after Audyssey and then simply bump that level up +5db so that it's closer to 0db. Doing so will not only bump up the bass level to where most enjoy it, but also ensures the signal going from the AVR to the sub will be strong enough to kick the sub out of Auto mode.
post #11077 of 11079 Old 04-25-2015, 04:29 PM
Quoted: 45 Post(s)
Liked: 1
Thank you.
Mic - You can use any of the following Audyssey mics DM-409, ACM1H, or ACM1HB used on Denon, Marantz, and Onkyo AVRs the past 5 years.
I see. Because i have a local dealer display model x4000 dont have mic and remote. Do you have any idea how much x4000 now as used?
Also how huge upgrade from denon 2112ci xt to x4000 xt32?
tapsilog is offline
post #11078 of 11079 Old 04-25-2015, 04:36 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2176
Thank you.
You can purchase both mic and remote from one of the various Denon authorized parts distributors or on Amazon or eBay.
http://usa.denon.com/us/support/partsdistributors
Big difference going from 2112CI (MSRP $650) to X4000 (MSRP $1299).
post #11079 of 11079 Old 04-25-2015, 05:33 PM
Quoted: 45 Post(s)
Liked: 1
What about interms of sound quality?
tapsilog is offline
Denon Avr4310ci Receiver , dolby digital plus , netflix 5.1
